I have D-link wlan router there is a problem mostly of ip conflict. Please provide me with the solution
    Scholar:
  • 172 Answers
The first thing, I recommened is to reset you D-link router.. Second, you can access D-link router console by using http://192.168.0.1 , if the IP is matching to your known IP...Most likely your problem will be solved after the first step....
Thanks for choosing Fixya..............
Sandeep
Posted on Mar 17, 2011
  • ahmednawaz20 Mar 18, 2011
    thanks i will try this one then i will tell u that it worked or not. u mean to say hard reset.? and one more thing i'm using bridge connection.
I am having STC modem, and TP LINK WR740N router, i could't able to connect to internet.
Does your modem have a built-in router? if so it might be an ip conflict. try to connect a patch cable directly to your modem and do an ipconfig in your command window. If you get something like 192.168.xx.xx it is most probably an ip conflict in that your router is in the same ip range. try resetting your of your router to something like 192.168.7.1 and try again.
Jul 30, 2011 | AGPtek TPLink TLWR740N IEEE 80211bgn 4port...
How to Chang the password of wlan
With most wireless routers you can go to their default IP address in your web browser. Open up Firefox, Internet Explorer, or the browser of your choosing and type in to the URL bar:
192.168.0.1
This is the most common IP address for wireless routers and should bring you to the wlan's configuration page. Enter your wireless routers default password and then look around in the configuration for where you can change your password (usually on the first page that pops up).
If you can tell me the exact WLAN you have, I can further assist you and tell you exactly where in that configuration page you can change your password.
Please be sure to be connected to your wireless router before attempting to navigate to 192.168.0.1 as this method will not work if you're connected to another network!
Jul 24, 2011 | Computers & Internet
Internet problem: I have configured my new TP LINK WA500G as an Access Point with DHCP enabled, connected to a router with fixed IP. All the tested devices (android tablet, WM phone, W7 and W XP...
please note that if your router DHCP is open you must close the access point DHCP if the twoic is open DHCP make a conflict and internet is stoped
best regards
Apr 21, 2011 | TP-LINK TL-WA500G 54Mbps Wireless Access...
I have a weird problem with my switch . It doesn't give me internet acces when i try to connect my pc with it but when i connect a router to the switch it does work . I tried everything : restarting my...
Do your service provider limits number of ip address (10.10.10.10) you can have? if they provide only one, you would need to use a router to share one public ip address. Sometimes it records the network address of your network device (00:00:00:00), and won't give u another ip if the device changed. If you have two routers in your network, turn off the dhcp on the second router, and use LAN ports and do not use the WLAN on the second router. if you want to manage the second router, give it an static ip from the first router. Bad port? Bad cable? Modem => router => PC/IPOD/switch or modem => router => PC/IPOD/Switch/ 2nd Router without dhcp and no WLAN ) Good luck
Jun 16, 2017 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I have two computers plugged into the srx200, there are conflicts when we both try to get on the internet at the same time. Would having indentical ip addresses have something to do with it?
Most of the cases at problems like these is that both the computers use the same ip address. I suggest you to change the ip settings to auto, so that each computer will get an ip from the router and no conflicts will occur.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 04, 2010 | Linksys 4-port Wirelss Router W/srx200...
Getting Disconnected
Either you hava an IP conflict (two devices use the same IP address eg printer/laptop/ ethernet adapter/ wlan card etc. etc.. Look at the device map and check all IP addresses, if in conflict: give another one manually. Ips like 192.168.1.1 can be changed by giving another number to the last "space" behind the point (192.168.1. (1-99). Every device must have a unique one. Vista normally does that but sometimles the IPs are preset andf cannot be changed by VISTA.
2nd possibility: You have an onboard "N/G" or "A" adapter and / or ethernat card and a USB or external WLan adapter, all activated in parallel. Makes the firewall go crazy, disconnects adapters constantly, which try to reconnect.Disdable all but one. Then enable one after the other to find the "impossible" combination or just use one.
Jul 26, 2010 | D-Link DIR-625 (790069292637) Wireless...
IP conflict on dlink WLAN router
If you are using static IP address on your computers then please switch over to dynamic IP. Also, please turn off all the devices on your network and then first turn on the modem and then dLink router and then your computers. This should resolve the issue.
Feel free to reply if the issue persists.
Regards
Anand
Mar 13, 2010 | Computers & Internet
D-Link AirPlus Xtreme G DI-624
Using the Configuration Menu
Note: if you have changed the default IP Address assigned to the DI-624, make sure to enter the correct IP Address.
 Open the web browser
 Type in the IP Address of
the Router (http://192.168.0.1)
12 Type admin in the User Name field
Leave the Password blank
Click OK
Home > Wizard
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
.13
Using the Configuration Menu (continued)
Home > Wireless
Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
SSID-
Channel-
6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP-
Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-624 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption-
Select the level of encryption desired: 64-bit, or 128-bit.
Key Type-
Select HEX or ASCII.
Keys 1-4-
Input up to 4 WEP keys; select the one you wish to use.14
Home > WAN > Dynamic IP Address
DI-754
Dynamic
IP Address-
Choose Dynamic IP Address to obtain IP Address information automatically from your ISP. Select this option if your ISP does not give you any IP numbers to use. This option is commonly used for Cable modem services.
Host Name-
The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address-
The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone
MAC Address-
The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the "Clone MAC Address" button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Enter a DNS Address if you do not wish to use the one provided by your ISP.
Primary/
Secondary DNS Address-
MTU-
Enter an MTU value only if required by your ISP. Otherwise, leave it at the default setting.15
Home > WAN > Static IP Address
Static IP Address-
Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address-
Input the public IP Address provided by your ISP.
Subnet Mask-
Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP
Gateway Address-
Input the public IP address of the ISP to which you are connecting.
Primary
DNS Address-
Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary
DNS Address-
This is optional.
Aug 27, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router issues
Hi Pzarek,
The first thing that comes to mind is that your Linksys modem is using the same IP address as the router and it's causing a conflict. The quickest way to find out if there is a conflict is to get into the administration setup on the router and manually change the IP address of the router itself (currently it's most likely 192.168.1.1 - change it to 192.168.1.250). Linksys has most of its devices that provide dynamic IPs set to 192.168.1.1 by default so I would suggest that.
To log into the router (assuming you have your computer plugged into the router):
Bring up Internet Explorer and type in 192.168.1.1 into the address bar.
When it asks for a username/password, type in 'admin' for the username and 'admin' for the password (without the quotes).
You can change the IP address from 192.168.1.1 to 192.168.1.250 on the first page that comes up.
If you're unable to access the setup, make sure the router is powered up and hold in the Reset button on the back for 30 full seconds. At that point the information provided will allow you to access it.
Ben
Feb 18, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
David Payne
David Payne
