Question about Dishwashers
Broken door spring - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 18, 2011
My garage door will not open. I pulled on the emergency rope to see if that would help but it did not.
Your torsion spring is probably broken. After you pull on the emergency rope, press the remote, that should move the chain and emergency lock out of the way, then you and 1 or 2 other people may be able to lift the door up if you really need to get the vehicle out. It depends if it is a single or double door or wood or metal, how heavy it will be. This can be dangerous and it could fall down on you. Check your torsion spring above the top of the door when closed, if there are two pieces then it is broken (on a single door.) A double door will have two springs, one on each side. One may be broken. You will need to get all the springs replaced, it counterbalances the door. If you have a garage door with arms on it, then the compression/extension spring is probably broken. If you are mechanically inclined, you can replace them, it is dangerous, be sure to watch a UTUBE video on it.
Dec 21, 2014 | Building Materials
Door well close but not open
This could be a broken torsion spring. See link below to see what a broken one looks like.
Replacing Broken Torsion Spring on Single Spring Garage Door
Oct 05, 2014 | Building Materials
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Garage door does not open. goes up about 4 inches. disconnected from opener and still can't open. checked wheels in frame move by hand. opener works when not attached to door.
You probably have a broken torsion spring. If you have a spring on a shaft above the door (usually 2 if it is a double door) then you have a torsion spring. From this shaft you have a 2 cables wound on a drum going down to the bottom of the door. If it is a single door, then this cable will be loose. If you have a double door, then most likely one spring is broken. This allows the door to open slightly, until one side is trying to lift(good spring) and the other side cannot (broken spring) Unless you are an EXTREMELY CONFIDENT DIYer then you should leave this do a door repairman as winding a torsion spring is dangerous, and can break bones or even kill. Now if your door has extension springs on each side of the track,with a pully and cable, then these can easily be replaced yourself. Check that cables are connected to the springs and the door and that one didn't break or come loose or cable off pully and binding.
Oct 21, 2010 | Garden
The door spring is broken and the door falls open
there is springs on left and right side held by string and spring. one is broken.letme know how it turned out.
Feb 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Garage door take about 20 button pushes to open all the way, what is the spring supposed to look like? Is there one on each side or just one piece that should be connected? I just don't know if my spring...
to find out if your spring is broken wthout knowing you can spray a paint line all across the spring and then when you open the door the paint should go into a swirl if the spring is good if not the spring is broken.
Feb 02, 2010 | liftmaster Chamberlain Garage Door Opener...
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
Door spring broken
the door links are broken need to get new ones and replace
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
My garage door opener only opens the door 2 feet high and stops, what could be the problem?
You could have a broken door spring or the drive gear is going bad. You need to remove the cover to check the gear. It is white nylon and is just in front of the motor. You can also increase the 'up force' which is a control on the rear of the motor unit.
Oct 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
Owen Barnes
