Question about Electrolux Epic 6500 Vacuum
Model 6500sr cuts off at highest control setting even with new bag, what could be causing this problem?
  • 694 Answers
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Posted on Mar 18, 2011
Need replacement bags for my Electrolux EPIC 6500SR. What kind of bags do I need? And where do I get them?
Hello, barb
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my own personal time
to see if I can help. Even though this a Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about vacuum cleaners and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/vacuum-cleaner.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just tried to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry.I do not get paid to help people on the site, I do it cause I like to help.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 01, 2011 | Electrolux Epic 6500 Vacuum
My Henry Hoover cut out and will not work. Emptied bag and replaced fuse but no success.
If no burning or smelling, maybe nothing to do with motor, and if caused by the safety cut-out, it will need about an hour to cool down, and then check filter, bag, and drop coin through hose, pipes and the floor tool, to check for blockages and to stop it running hot. Damaged cable, worn carbon brushes, broken electrical rewind electrical contacts or even the printed circuit board (later models) are the most likely causes.
Jul 08, 2011 | Hoover Vacuums
Just bought vacuum 2 weeks ago, guests arriving soon RE: suction very very weak...help !
YOU HAVE FORGOTTEN TO GIVE DETAILS LIKE MAKE, MODEL ETC. TRY REPLACING THE COLLECTION BAG WITH A NEW ONE, ALSO SEE IF THE LOCKING IS FULLY IN PLACE. IF THERE IS A INTENSITY CONTROL PLACE IT TO THE HIGHEST LEVEL.
REGARDS
Jul 03, 2011 | Kenmore Vacuums
I replaced the motor in my 6500SR Epic vacuum cleaner. Now I have 3 clear plastic hoses for air flow. I know where two of them go, Im not sure where the third air hose goes? Jan
All three are connected to the control valve assembly.
The long one goes through the hole in the bag container and to the door and inside.
One goes to the bottom of the bag container.
The last one goes to...I can't remember right off. Check areas it will reach for the nipple it fits on.
Jan 20, 2011 | Electrolux Vacuums
My epic 6500SR is not working. The power comes on
This is usually caused by your full bag indicator shutoff switch.
The control valve has gone bad. This is the dial on the top of the vacuum that has numbers on it.
You cannot bypass this problem from outside the machine.
The part can be bought at the local outlet. Go to www.aerusonline.com and find A local dealer. It is not too expensive to fix, and is a common problem on later model electroux vacuums.
Mar 15, 2010 | Electrolux Epic 6500 Vacuum
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
Brush roller on Hoover upright stops turning
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Dec 13, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacum keeps turning off with warning lights
Actually the problem is that you need to change your control valve. The motor has an internal thermostat on it already so the chances of you burning the motor out are very slim. By changing the control valve, you will solve your problem. Very simple and quick fix.
Sep 22, 2008 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Can I fix height adjusment?
all i no is on the bottom of unit there is 2 smaller wheels that control the height adj. see if that the prob.
Mar 01, 2008 | Hoover U6434-900 Bagged Upright Vacuum
Vacuums Logo
70 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
