Question about Armitron 40/8125BLK Digital Sport Watch
Can not set the right day - Armitron 40/8125BLK Digital Sport Watch
    Sergeant:
  • 302 Answers
Can you set anything? Like the date or time?
Posted on Mar 17, 2011
I set the date right but it doesn't say the right day
Day if set according to year.If you set the right year,you will have the right day.
Oct 07, 2013 | Casio G-Shock GW300CA-1V Wrist Watch
Aeo watch instructions
To set the time and date (must be done in this order) 1. Press MODE 3 times, then press START to change the seconds. 2. Press RESET to change the minutes, then press START until you get to the right minute. 3. Press RESET to change the hour, then press START until you get to the right hour. Note: If it says "H" on the right circle, it should read 24HOURS, otherwise it should read "A" for AM and "P" for PM. 4. Press RESET to set the date, then press START until you get to the right date 5. Press RESET to set the month, then press START until you get to the right number. 6. Press RESET to change the day of the week, then press START untilyou get to the right day. 6. Press MODE when done. Hope this helps
May 28, 2013 | Watches
Just trying to find an instruction manual for a wittnauer 2002 watch
This Watch has no Batteries Its a manual Automatic 15 jewel watch.
It has a perpetual calendar that is set manually by turning the bottom right stemIt has day which is set from center winding stemIt has date which is set by pressing the top right press pin
The easiest way to set the calender is to match the small red numbers(year 2000 and up)to the month at the bottom using the lower right stem.The top calender should show the right day against one of three dates
Value for a good one Up to 200 dollars in original box
Jun 04, 2011 | Watches
I just bought a Kenneth Cole Unlisted mens watch. There is no instructions on how to set the day and date. Is it broken out of the box or are those dials just fakes? Jens
The Mode button on the bottom left hand side will set your "SET" buttons to work.
The first push of your Mode button will activate your Stop Watch. Press the top right button to time your subject. Press it again to stop timing your subject.
Pressing the bottom right button will reset your Stop Watch to zero.
Press the Mode button to release your Stop Watch function and return to the Telling Time function.
Press the Mode button twice and you'll be able to set your Alarm function. Your Hour number will be flashing. Press the top right button to set your Alarm Hour. If you Alarm Hour is for the afternoon or evening continue pushing until a "P" appears by your hour number . This will be your afternoon/evening hour. If there is no "P" that, of course, will be your morning hour.
Press the bottom right button to adjust the minute number of your Alarm function. Your minute number will be flashing. Again, using the top right button, you'll be able to adjust your minute number.
(If you hold any number changing button for a long time, the numbers will flash through rapidly.)
Press the mode button to release your Alarm setting function.
Press the Mode button three times to set the Time of Day on your watch. At this point you'll also need to push the bottom left button to activate your Time of Day function. after pressing the bottom right button your minute number will start flashing. Press the top right button again to adjust your minute number. Once that's done, press the mode button to release your time of day function.
Hope this helps!
Oct 18, 2010 | Kenneth Cole Watches
How to change the day on a citizen bullhead watch
To set the day, pull out the setting crown to the first notch. Turning it will change the date. To set the day, depress the chrono reset button, i.e. the right button and that should move the day.
phantomwatch
Aug 13, 2010 | Citizen Watches
Can you set the time going counter clockwise on a watch
yes, you can set the time counter-clockwise on a watch. The only difficulty that may arise from this is making sure the date window (if you have one) syncs up; but a 1 hr change for time change will not make a difference. For best results start setting with your day window reading 1 day before the current day and begin turning clockwise. Right when the day/date changes the watch is reading 12am(midnight); set accordingly.
Nov 03, 2009 | Bulova Watch
I have an automatic watch that shows the day of the week, I can't set it so that it changes from day to day correctly. I've changed it to correct day right after midnight and by the end of the day, it's...
hi,
first you kepp the day and date set yesterday's , for example today is 31st and monday so you set 30th and sunday , now keep rolling time by key till day and date has complitaly changed,remind that do not roll anty clock, it may be damages to your watch,now when you get change day and date its a midnight of 31st and monday, now set the time and get started ,
Aug 30, 2009 | Invicta Corduba Leather 3809 Watch for...
Change day but not date on Timex Expedition
HI..
HERE IS STEPS FOR SETTING OF YOUR WATCH... STEP3 EXPLAINS THE SETTING OF DAY,DATE.....
  • Step 1 Push in the lower right button until you see the seconds flash. Press the upper right button to run the seconds display down to zero. Push the bottom left button to get into the mode to set the hours. Press the top right button to scroll through the numbers. Watch that you choose a.m. or p.m. correctly.
  • Step 2 Press the bottom left button to get into the mode to set the minutes. Again, push the top right button to scroll through the numbers until you reach the correct time.
  • Step 3 Repeat the process from Step 2 four times to set the month, date and day of the week and to change to military time if you wish. Push the bottom right button to save your settings. You'll notice the colon between the numbers will start to flash.
  • THANK YOU
  • Jul 28, 2009 | Timex Expedition Outdoor Athletics Watch...
    Setting day and date on timex watch
    Pull the stem out part of the way not all of the way. This will allow you to change the date quickly without the day moving.
    Nov 26, 2008 | Timex 27191 Wristwatch
    I cant set the correct day on my digital watch ,The watch has CG onit and is WR 100FT
    press mode 3 times to get to time set. then press reset to choose (hour, minute, seconds, day, month, date) and press start to change them. press mode again when finished.
    Oct 16, 2008 | Freestyle Digital 79801 Watch
    Armitron 40/8125BLK  Digital Sport Watch Logo
    26 people viewed this question
    Top Armitron Watches Experts
    Ansel Alberto
    Ansel Alberto
    Bill Boyd
    Are you an Armitron Watch Expert? Answer questions, earn points and help others
