Question about Simplex Kaba Ilco Unican 1000 keyless lock
Iv'e got a Simplex L1000 series combination that needs the Outside Lever Assembly-Right Hand and Outside Sleeve Assembly changed on it. I have the parts needed but I can't figure out how to remove the Outside Lever from the Front Lock Housing.
  • 963 Answers
Here is a link to the Kaba Ilco web page which has a grid chart, including the L1000 series lock:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Of particular interest to you will be the Manual (page 10) and Parts List, which shows an exploded view of the lockset. Hopefully this will give you the info that you need.
On the same webpage you will also find a link "Contact Us" for further technical information and parts.
Also on that page is a link to get Adobe Reader. If you don't already have it installed on your computer, you will need it to open the PDF files for the manual and parts list.
Hope this helps. Good luck!
Posted on May 19, 2011
  • shelby_peek May 19, 2011
    I had the original question. For others viewing and needing the answer it's as follows:
    After looking and removing the internal parts I still couldn't find the solution, so I ended up sending it to a locksmith to replace the parts. They told me later that ALL internal parts from the Front Lock Housing needed to be removed, then rotate outside lever 180 degrees. Using spanner wrench depress the front knob retainer, then outside lever should slide off. Remove Drive Assemply and Front knob retainer from rear of front lock housing.
    *The key was rotating the lever 180 degrees. Nowhere in the directions was this mentioned nor was it mentioned in the email reply I received from Simplex.. So for all you out there, Good Luck! And make sure to add this key step to your directions.
How do I change the handles from right to left?
If you don't have the print instructions for your lock, go to this web page:
On the grid, go across from L1000 to the "Manuals" column & click on PDF, which will download the file of the manual for your lock.
If you cannot open the file to view it, you need to install Adobe Reader first. You can get the download (free) from here:
http://get.adobe.com/reader/
Now you should have the manual for reference.
Someone else who was wanting to change the handle sent me this information:
"I've got a Simplex L1000 series combination that needs the Outside Lever Assembly-Right Hand and Outside Sleeve Assembly changed on it. I have the parts needed but I can't figure out how to remove the Outside Lever from the Front Lock Housing.
I had the original question. For others viewing and needing the answer it's as follows: After looking and removing the internal parts I still couldn't find the solution, so I ended up sending it to a locksmith to replace the parts. They told me later that ALL internal parts from the Front Lock Housing needed to be removed, then rotate outside lever 180 degrees. Using spanner wrench depress the front knob retainer, then outside lever should slide off. Remove Drive Assemply and Front knob retainer from rear of front lock housing. *The key was rotating the lever 180 degrees. Nowhere in the directions was this mentioned nor was it mentioned in the email reply I received from Simplex.. So for all you out there, Good Luck! And make sure to add this key step to your directions."
As you will find in the manual, you need a special spanner wrench for this operation.
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Aug 11, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
My lock is not working. How can I remove the mechanism from the outside
The mechanism is not removable for the outside, for that would defeat the purpose of the lock if any would-be entrant could just do that!
I am including a link to the grid of information for the L1000 lock, where you can find PDF links to the Manual, Parts List, and Tips. Tips has reprogramming and troubleshooting information.
In order to view PDF files, you will need to have Adobe Reader installed on your computer. There is a link to get Adobe Reader on the Literature Grid Page:
I found this instruction elsewhere on the FIXYA site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVER TIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:Spanner Wrench $9.00) referred to can be purchased from this site:
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
May 23, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Need to find instructions to change combination on Kaba L 1000 keyless lock.
I found this instruction elsewhere on this site ( thanks to pctuneup191):
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
Good Luck!
Feb 24, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
We have a Simplex LL101126D41 Combination lock and tried to change the code following the instructions for an earlier model (on that does not have the handle). Now the lock will not recognize the new nor...
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
this site:
aspx?id=13
Good Luck!
Feb 11, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Need a instruction manual for programing of KABA lock. Model No. E-760 K
REMOVE THE KEY.
Good Luck!
Dec 22, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
How do I change the combination on my Unican 1000 keyless lock? thx john
The door must be open.
On models with the passage feature, make sure the passage feature is disengaged: turn knob or key should be in vertical position (A) (see figure 1).
1. Insert the DF-59 control key (B) into the combination change plug
assembly (
C) and unscrew the cylinder by turning the key
c
ounterclockwise. Remove the combination change plug to gain access to the combination change sleeve (see figure 1).
2. Turn the outside knob/lever once clockwise (all the way, until it stops) then release. The latch should not retract (see figure 4).
3. Enter the existing combination. On new installations, use the factory- set combination: depress 2 and 4 simultaneously, (release), then 3
(r
elease). You should feel a slight click as each button is depressed.
4. Insert the spanner wrench as shown in figure 2 to engage the combina- tion change sleeve (A). Gently turn the spanner wrench clockwise to the stop position (a slight click should be felt), then turn the spanner wrench counter-clockwise to the stop position (A) (see figure 3). Remove the spanner wrench.
5. Turn the outside knob/lever once clockwise all the way until it stops, then release. The latch should not retract (see figure 4).
6. Choose your new combination, write it down, then enter the new combination-depress buttons carefully (a slight click should be felt as each button is depressed).
Note: You can use one button or all five for a combination, but each button can only be used once. You can depress two or more buttons simultaneously as a step in the combination.
7. Turn the outside knob/lever clockwise once, all the way, until it stops, hold in position and make sure the latch is retracted (see figure 5).
R
elease the knob/lever.
Note: If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution.
1000/L1000 Series FAQ
Changing the Code/Combination
hope this helps
and here is the link to the change code web site
http://www.locksonline.co.uk/files/pdf/Simplex_1000_CodeChange.pdf
good luck
please take the time to rank my advice
merry christmas
Dec 07, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Need to know how to reprogram the code on a Simplex Kaba IIco Unican 1000 keyless lock
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
Good Luck!
Dec 05, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
I NEED TO RESET THE SIMPLEX 5 BUTTON LOCK, BUT I DON'T REMEMBER THE CODE, HOW DO RESET IT???
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
this site:
aspx?id=13
Good Luck!
Nov 22, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Forgot code to Unican L1000 lock. How can you reset code?
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
You will find a link to download the manual for your model on this page:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Oct 29, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
How do I change the combination to a Unican 1000 Right Lever cipher lock
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
Sep 20, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
258 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
