Question about 2wire (1000-400108-001) Router
Help please how can i configure my 2wire 1701hg gateway with verizon online because they want me to buy their equipment but i refuse to buy more equipment please i need your help
  • 659 Answers
Please go here to find the solution to your issue from the 2wire.com website.
http://www.2wire.com/index.php?p=268
Posted on Aug 02, 2008
Need detailed help setting up my 2wire 1701hg gateway. I have high speed att dsl internet. I tryed already but att redirects me to there website, I tried calling them but they keep trying to charge mt 49$...
I can help you to configure the modem... Before that i need answers for certain questions....
How many lights are litup in your modem...? Do u have the light called "Internet and DSL" lit up in your modem ? Do you know the connection type ??? PPPoE If so do u know what is the Username and password ??
May 23, 2011 | 2wire (1000-100052-000) 802.11g/b Wireless...
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Broadband yellow light
I'd hate to say this but the 1701 was abandoned and buried a long time ago :( 2Wire was no longer supporting it when Arris bought them out and Arris will just tell you time for a new one. Even electronics with non-moving parts eventually wear out. If you're renting the 1701 time to buy a replacement and save those monthly fees (typical payoff is 10 months or so). Your ISP will have a list of compatible modems, although you might have to deal directly with their customer service to put a new gateway on your line.
Mar 24, 2017 | Computers & Internet
I have a two wire router trying to hook up to run my laptop
You need to run from the DSL modem into the ethernet port at the very top of the 1701hg. Use your other 4 ports below to send one the computer and one to your vonage. You will no longer need to "jump" though your vontage unit. Other than connecting the power cables, you are all hooked up.
Jan 21, 2009 | 2wire 2700HG-B Router (2700HGB)
Set up wireless internet access using HG1701 2wire router
Check with this tip
Detail on this Wlan Router
"Connect power cord to router.
Wall Plate -> Router (using phone cord).
Router -> PC (using network cable).
  1. Power on router, when the lights settle, start the PC.
  2. Start IE in PC, type 192.168.1.254 in the address bar and press enter.
  3. Start configuring using the Telco's suplied info, namely PPPoE username and password. All other function works by default.
  4. The WEP key is the 10 digit number underneath the router (not the 12 digits S/N number).
Jan 18, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Install 2wire 1701hg without installation CD
I have the same modem.
You don't need any installation cd.
Just follow the instructions at this web page:
http://support.2wire.com/?page=view&article=60
Nov 04, 2008 | 2wire (1000-400108-001) Router
2Wire 1701hg gateway- Broadband Access problem
hi! have you used this other identical 2wire modem before? if this other 2wire modem (is it the same 1701hg?) well you may need to configure the settings first. also 1000 series modems usually have 3 lights on it; power, broadband link, and local network. if these 3 lights are on, you may need to access the modem's user interface. assuming that all lights are green, on your computer directly attached to the 2wire, open up any browser, type in gateway.2wire.net. it will give you the network at a glance page. click on run system setup wizard, type in the system password. on the ppp authentication page, please check if it has your username & password (this is the one that you set up on your internet acct w/ your ISP), the next screen will establish a connection. (please tell me if you've got any error messages...)
Apr 06, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 1701HG Gateway Router VPN Setup
Go to http://gateway.2wire.net and click on the firewall icon. Click on firewall settings and, if prompted, enter your system password to reach the advanced settings page. select the computer that will function as the VPN server. In the left column, select PPTP server. click on Add, then done. or try changing the IP scheme to the 172.16.0.0/255.255.0.0 or 10.0.0.0/255.255.0.0 schemes by accessing gateway.2wire.net, go to home network icon, then advanced settings. but if you manually configure or disable dhcp, be sure to write down the subnet mask & IP assigned to the 2wire then click on save. if all else fails, run it on DMZPlus mode, however this solution will allow all inbound traffic to the computer. if it still doesn't work on DMZPlus mode, the VPN is either using the same IP scheme, is using IPSec 50 or 51, or will not work with the 2Wire gateway.
Jan 30, 2008 | 2wire (1000-400108-001) Router
My 2Wire Gateway modem died
don't even try. the components are far too small. go to pacific geeks dot com and buy a new modem. I got one there for $4.50.
Jan 22, 2008 | 2wire HomePortal 100 Network Adapter
2wire (1000-400108-001) Router Logo
157 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
