Question about Hitachi 50GX49B 50" Rear Projection Television
Hello could you please answer a question for me--is my 50gx49b hd compatable to watch hd channels-i just gotan hd box but the hd channels are all colors and lines -Thank You for your help Jim
  • 902 Answers
Change the hd output to 720p if that doesnt workt hen 480p othwerise your tv cant do it. if you are using hdmi try using component cables. also if you are using rca cables red white and yellow that is why
please let me know
Posted on Mar 17, 2011
I want to use an RCA F27645 for OTA channels only. What type of converter/antenna do I need?
If you are in the US, you will need a digital decoder box along with a digital antenna. You set has an analog tuner installed and is no longer compatible with broadcast signals, thus the need for the digital decoder box. Although the channels are digital, they will not be HD; your set is not capable of handing HD resolutions. Thus, you will only get SD broadcast channels. That will limit you to what you can watch as many broadcasters have gone full HD, while others still broadcast the 480i signal as well.
Aug 10, 2016 | RCA Televison & Video
Why my jvc television hd61z456 not showing in high definition
What is the signal source that you are watching on your HD61Z456?
The problem you describe usually happens when you aren't using an HD source or have downgraded the signal by the composite input on your TV. (Composite cables only support 480i SD signals.)
You will only see 720p HD content from HD sources, if you use HD compatible inputs. Some OTA channels are also broadcast as only analog signals (usually the -2 and higher sub-channels). If you have cable or satellite, make sure that you have the HD programming and have tuned to the HD version of the channel.
The HDMI and component inputs both support HD signals.
I hope this helps. If you are watching an HD source and the problem persists, I recommend trying new video cables. Next, check if you are getting interference from your devices by using a cable with a Ferrite core. See http://www.monoprice.com/Category?c_id=102&cp_id=10240 for HDMI cables with Ferrite cores. The cores help block interference. If you have very long cable runs, check the behavior with shorter cables between the source and the TV.
(I am assuming you aren't using an SD set top box (VCR, older cable box, low end digital-to-analog converter).)
Dec 19, 2013 | Televison & Video
We have a Model # 50GX49B 50" inch TV, That our
You need to set the antenna input back to ANT A (1), you are ANT B (2) right now that why you are not seeing any signals.
Use the INPUT button on the remote to scroll through until you see ANT A which is the one your kid use for the cable connection,
You should download this user manual:
http://www.retrevo.com/support/Hitachi-50GX49B-TVs-manual/id/371bh845/t/2/
Let me know if it works.
Dec 31, 2010 | Hitachi 50GX49B 50" Rear Projection...
Magnavox 52 inch HD Tv connected to a Dish Network HD Satellite Box. If you watch a channel with HD programming and then tune to a analog channel there is no sound. The tv has to be turned off and back...
have you tryed to go to setting and letting it yout tv know that you want sound onto the hd channels.? if you have any more problems joust contact you coustmer service for dish network. problalby your tv is not compatible and you need an hd receiver. i have dish network myself and just upgraded my receive to hd.
best of luck- JD
Nov 18, 2009 | Philips Televison & Video
With the new HD transfer. We just have atenna...we just bought a HD TV. Is there a way of connecting the DVD Recorder so I can watch one channel and tape another with this new system
A lot of your question depends on your DVD recorder, but there IS a way to connect them so you can watch one channel and record another one.
First - if you have an HD compatible DVD recorder (one that will allow you to select channel 8, 8.1, 8.2, etc) then you could simply split your antenna signal BEFORE the TV or DVD recorder. Then you can select one channel to watch on your TV while selecting and recording a different channel on the DVD recorder. If your DVD recorder is connected to your TV's Video Input, you should be able to monitor DVD recorder's activity by selecting the "Video Input" on your TV.
If you DON'T have an HD DVD recorder, then you will need to get a converter box to put between the Antenna signal and the DVD recorder. You can then set the converter box to the channel you want and the DVD recorder can be set to record it.
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
HD ready?
It was not a problem. It is just a question. Is it HD ready or not without a converter box or cable?
I will go to a store and ask a tech if you can not answer.
thanks
Jan 14, 2009 | Akai LCT3201TD 32 in. LCD Television
May sharp lc-52sb55u
Well, there is a way to have the clearest possable picture. Get HD cable TV box that is HDMI compatable and watch only HD channels. Or buy a blu-ray player, hook it up via HDMI and only watch blu-ray disc in 1080p!
Jan 06, 2009 | Sharp LC52SB55U LCD TV
Record and watch different channels with freesat
I believe that the Humax can only output 1 channel and because it has no built in hdd and twin channel capabilty that is all you can record 1 channel (unlike sky +/sky HD) so that means also that unless you watch a different source (like the picture from your aerial (terrestial channels)) you are stuck with having to watch the channel you record
Oct 12, 2008 | Televison & Video
Hitachi 50GX49B 50" Rear Projection Television Logo
62 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
