Question about Frigidaire Affinity ATF7000E Front Load Washer
I have the Frigidaire Affinity Front Load Washer and my problem is that the washer fills up with water above door line if door is closed if door is open it keeps flowing to the floor. I read the manual and did the troubleshoot of running the spin only cycle and it still does it. Also, new error is that the door locked for no reason on its own bottom line I think it may be a electronic error or internal computer problem. What you think/ and please help before I have to replace the floor because its on the 2nd floor in my hous. Thanks for your help.
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in SW France
Sorry but being remote, not on site and answering problems on-line, there would be nothing we could advise in this situation other than you calling in an engineer.
1) the water level sensing is obviously malfunctioning and 2) there might be a knock-on effect with the door locking because it possibly has water in it when it shouldn't.
The sooner you have it fixed the better all round!
Sorry again,
John C
Posted on Mar 17, 2011
Water will not come in to affinity washer
Good Afternoon friend, thank you for your post!
I understand that water is not entering your Frigidaire Affinity washer. If the washing machine thinks that the door or lid is not closed, the water will not enter the machine. I recommend that you verify that there are not any visible defects with the door latching mechanism. I also recommend that you visually inspect the water inlet hose to make sure that it is not twisted or restricted. Lastly, please verify that the water supply faucet is completely open and not closed. You may want to avoid running water in other areas of your house while the washer fills. If these troubleshooting steps do not resolve your issue, I recommend that you allow a professional to properly diagnose your washer for you in order to avoid purchasing any unnecessary parts. -NS
Mar 01, 2015 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire Affinity ATF6000F Front Load...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Problem with water in tub of front load washer
Two possibilities here - bad valve, not closing completely when off or you have a bad control that is sending residual voltage to the valve when it is off. Contact a service technician.
Aug 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Front end loader washer door does not line up to close
Check to see if the door is sagging. If so, contact Frigidaire you might be able to adjust the door and save money rather than replace the switch.
Aug 02, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
Frigidaire affinity washer doesn't start
Try holding the 'options' & 'select' buttons together till the door lock button comes on. This is the child lock function. You can do it again for the lock to come off. Hold down for over 3 seconds
Please reply or rate.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
