Question about Canon DR-9080C Path-Through Scanner
Unknown error. Canon DR-2050C/2080C Driver version 2.2.10412.07001 (-4523)
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
I have many years repairing Canon scanners so I hope my suggestion helps you out.
In my experience with the problem your having I have found that the bios needs to be flashed on the particular model scanner you have. You will need to contact your local canon dealer to have this done because they have diagnostic software to do this with. Also they can run the diagnostic software to tell if there are any other issues that need to be addressed on your scanner while they are there.
I hope this helps you out if not let me know.
Posted on Apr 01, 2011
How can i get capture perfect software for my canon dr 2080c?
Go to their official webpage, and try to find software... or just download this Driver Update Software for XP Vista 7 8 and make the update. I hope I have helped. Have a nice day
Paul
Jan 18, 2011 | Canon DR 2080C Path-Through Scanner
Is there a canon dr 2080c driver for Windows 7?
look in optional updates in windows. thats the cool thing with 7
Dec 26, 2010 | Canon DR 2080C Path-Through Scanner
Line appearing on document
Clean the glass thoroughly with a damp cloth.
S. Mohan
Sep 30, 2009 | Canon DR 2080C Path-Through Scanner
Installed driver twice for Canon DR-2050c. Still
Pls run checkdisc/scandisk on your Comp. Your OS may be corrupted. Just to verify try scanning by connecting to a formatted newly loaded OS Computer.
S. Mohan
Sep 09, 2009 | Canon DR-2580C Path-Through Scanner
I recently set up a new DELL optilplex 760. When I go to install my Canon DR-2080c I get an error stating "Device Not Found". I've uninstalled and reinstalled many times but still no luck. Can anyone help...
Have you installed device driver? It is just not enough if you install scanning software. Also trya different USB port o a different USB cable.
S. Mohan, India
Jun 04, 2009 | Canon DR 2080C Path-Through Scanner
Canon dr 2050c
i want the driver for canon dr-2050c
Aug 14, 2008 | Canon DR-2050C Path-Through Scanner
My Canon DR-2050C keeps jamming when I try to scan more than 1 page???
I finally solved my problem. Now it works like new.
Cause:
- The spring that returns the next sheet detector (small black plastic rocker arm between the two rollers on the back side) came off. So the scanner cannot detect transition from one page to the next. This spring is located inside the device and you cannot fix it from the outside.
- You know if you have this problem if you don't hear a "click" sound after each page is scanned. Without the spring attached the rocker will not return on every page. When it doesn't return the scanner think it is still on the first page and will not scan the next page. The "click" after each page is NORMAL. Without the click is the first sign your spring came off.
Solution (Only recommended for people handy with hardware and the unit is no longer under warranty)
1. Turn off power and unplug the device.
2. Pop off the plastic cover to the back of the scanner
3. Remove the screws that holds the plastic cover to the back.
4. Remove the screw by pushing on the retainer clips. DO NOT loosen any gears or motors.
5. Locate the rocker arm and re-connect the (very small) spring
6. Warning - if the LED light pipe falls out be careful how you put it back. This is a transparent widget at the top to route a LED light to the top of the device to indicate the power on status.
Sorry I didn't take pictures. If this sounds too complicated, send it to Canon for repair. Took me about a day to figure out exactly what was wrong and how to disassemble the scanner to fix it.
Good luck.
Jul 11, 2008 | Canon DR-2050C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
1,092 people viewed this question
old marine
old marine
