Question about Mackie Music
How do i setup my mackie 1202 - Mackie Music
  • Mackie Master
  • 5,603 Answers
Please view videos on YouTube. Search for "mixer setup". There are a bunch, and the information and techniqes are the same for almost any of the analog mixers. You might refine the search to Mackie mixers.
Posted on Mar 18, 2011
5 Suggested Answers
young red
  • 3 Answers
SOURCE: bad transormer in my Mackie 1202 20 watt mixer
how u hook up a mixer
Posted on Jul 31, 2009
  • 5603 Answers
SOURCE: type pf op amp in a Behringer XENYX 1204USB Mixer
Behringer uses 4580's in appropriate packaging everywhere. There are 339 comparators for the level indicator area.
The Mackies uses both NJM2068 and NJM4560M
The 2068' are used in most of the low noise areas and the 4560 is used in the 75Hz high pass filter for example.
Posted on Jul 23, 2010
gwcoan
  • 49 Answers
SOURCE: Mackie 1202. Channel 1 & 2 dead. Bought from
This could be caused by one or more of numerous issues. Generally speaking, it will most likely be a job for an electronics technician and could become expensive, depending on the root cause. If the seller of the console did not list this problem in the product description in the auction, I would definitely contact them and negotiate a reduction in price after you establish the cost of repair. A shop would be able to give you a "ballpark" idea of the cost (at least a minimum to even look at the console). You also should have the option to return the unit to the seller, unless specified otherwise, for a refund.
Posted on Nov 02, 2010
sparky1500
  • 1066 Answers
SOURCE: How can I connect my mackie mixer 1202-vlz3 to my
use the xlr (3 prong) main left and right outputs of the board. get xlr to 1/4 inch cables. one end will be 3 prong, to plug into the mixer, then the other end will be a mono 1/4 inch plug, like a big headphone plug. Then you have to get a dual mono 1/4 inch to stereo 1/8 inch adapter and plug it noto the line in. if there is no lone in, but a microphone jack instead, you will get a mono signal instead of a stereo signal. in this case, just use 1 channel of the mixer, instead of both of the stereo outs, and use a single mono 1/4 inch to mono 1/8 inch adapter.
the xlr to 1/4 inch cables can be purchased at a music store. the 1/4 inch to 1/8 inch adapters will probably need to be purchased at radio shack.
Posted on Nov 30, 2010
Need a power transformer for a Mackie 1202-VLZ mixer
The transformer itself will have the codes you need to replace it either printed on it or on a label stuck to it. Mouser should have what you need.
Sep 16, 2014 | Music
No power in Mackie TH-15A
i) I assume the fuse you mentioned was in the mains plug - did you also check the fuse in the TH15A mains input socket? This is accessed by pulling out the tab in the bottom section of the socket (below the centre pin). This is a 3.15Amp antisurge fuse, 20mm type.
ii) If this fuse has blown, then replace it & all may be well ...... but if it blows again, then move to step iii).
iii) With mains disconnected, remove rear panel (outer screws) & check the power supply PCB for damaged components, especially R111 & R112 (100ohms). If the latter are burnt or open circuited, then the amplifier module may have blown.
regards, Dave
Aug 20, 2014 | Mackie TH-15A Active DJ Powered THUMP...
Mackie 1202. Channel 1 & 2 dead. Bought from ebay. Simple fix?
Nov 02, 2010 | Mackie 1202vlz3 12 Channel Mixer
I need a new mains transformer for my Mackie 1402vlz3 mixer but can't locate on in the UK. NB 1402vlz, not 1202 vlz as per the product below. (Can't get 1402 on the categories). Where can I source one, or...
Your best bet is to contact Mackie directly for a distributor in the UK.
The contact information is listed below.
Dan
LOUD Technologies Europe PLC GENERAL CONTACT Unit 1 Century Point, Halifax Road. Cressex Business Park
High Wycombe, BUCKS, HP12 3SL, UK
Phone: + 44 (0) 1494 557 398
SALES Email: eusales@loudtechinc.com
SERVICE Email: euservice@loudtechinc.com
Aug 20, 2010 | Mackie 1202vlz3 12 Channel Mixer
Type pf op amp in a Behringer XENYX 1204USB Mixer and a Mackie - 1202-VLZ3
Jul 22, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Computer->M-Audio-FastTrackPro USB->trs outputs 1/2->linein 11-12 of mackie 1202-vlz3. How can i get stereo sound out of the mackie?
Use TRS to TRS balanced cables from the M Audio to the line in 11 and 12.
Set the pan controls for the 11 and 12 to opposite directions to split the stereo to left and right main outputs. (otherwise both main outs mix the left and right and you get mono result.
Feb 05, 2010 | Mackie 1202vlz3 12 Channel Mixer
Music Logo
358 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Are you a Mackie Music Expert? Answer questions, earn points and help others
