Question about Meade Optics
How3 do you remove the mirror from ETX-125-EC for cleaning?
  • 3,186 Answers
YOU DO NOT! This is a Maksutov style telescope. These must be collimated on an optical bench if the tube is dis-assembled. Meade can do the cleaning properly and or Dr. Clay in Arkansas.
http://www.meade.com/support/index.html
http://www.arksky.org/supercharge.htm
Posted on Mar 19, 2011
I had to clean the inside of my ext90 mean telescope due to cockroaches inside took a dump on the circular mirror. I took it apart but I can not figure it out hoe to put it back together. I need inside...
Go to the Mighty ETX web site:
http://www.weasner.com/etx/menu.html
There are many pictures and technical documents there that will show you how to dis-assemble and reassemble these telescopes.
May 05, 2011 | Meade ETX-90EC (325 x 90mm) Telescope
The flip mirror is stuck in the down position and i need to know how to remove the tube to get at the mirror
Go to the Mighty ETX web site and search for disassemble instructions:
Oct 28, 2010 | Meade ETX-70 (240 x 70mm) Telescope
I have an older ETX Astro Telescope or ETX spotting scope. A small rectangular mirror has come loose in the main body of the telescope. It appears undamaged. Is there a manual that shows me how to place...
This is a known issue with the older ETX scopes. You can use silicon sealant or a small amount of hot glue -- and just put the mirror back on it's small platform.
However you might need to disassemble the rear of the scope to do this. See this web site for instructions on disassembly.
Sep 08, 2010 | Meade Optics
Can't focus my meade etx-125. have turned focusing control more than 80x in both directions. Is there an stop on the focusing system. Originally had the electric focusing system on the scope couldn't focus...
yup there is a mechanical stop to prevent you from cracking the mirror by retracting or extending it too far.. once you break the pin off it needs to go to the factory for dis-assembly as they have to remove the primary to get to it and realign it my 105 did same thing....word of advise use a cable extender for focus not an electric focuser they fail to tell you that it can over run the built in stops making your scope useless...i may be mistaken but i believe the max turns is 25 or about for end to end focusing adjustment on the 125
Sep 28, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Can't focus on anything at all
Here is the manual-- read it cover to cover--
http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/ETX-90%20w-autostar%20man.pdf
1. Take off the lens cap
2. Put your lowest magnification eyepiece into the telescope on the TOP eyepiece port-- there is a lever on the side which rotates the diagonal mirror between the top and rear ports --- can you see light through the telescope? If not turn the lever.
3. During the day practice focusing on a distant object at least 100 yards away-- the image will be upside down -- this is not a problem-- no UP or Down in space.!
4. The lowest magnification eyepiece is the one with the LARGEST number on it.
Jan 02, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Broken connection ETX 90 EC
Yes the stripped bolt can be fixed by you --
Go to this site and search for "Stripped Dec bolt" -- instructions for repairing are on this site--
Also this will help you--
http://www.weasner.com/etx/techtips/etxtu.htm
Oct 23, 2008 | Optics
LOOSE FOCUS SHAFT
OK, that model has an internal adjustment. A good source for all kinds of information and tips on the ETX series is available from:
Jun 20, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
ETX 125 Loose image when focusing
The ETX family (and other Meade LX telescopes), use a moving mirror system for focus. The focus knob moves the main mirror in and out. For smooth operation, there is some slack on the central tube that allows the mirror to rock slightly as it moves. That is a normal condition, and the movement is magnified, the greater the magnification of the eyepiece.
Jun 15, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Secondary mirror
Answer would be too long here. See Mike Weasner's site below. Everything you wanted to know but were afraid to ask. I am not promoting, just a member.
Nov 20, 2007 | Meade ETX-125EC (500 x 127mm) Telescope
Optics Logo
239 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
