Question about Ricoh Aficio 450 Copier
When I try to copy something some of the page gets cut off. It is the right size paper so reducing the size won't fix anything. And I have done this successfully many times before...
  • santosj27
    santosj27 Mar 17, 2011
    You are taking the copies from the glass or the feder????
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
Sep 17, 2017 | Office Equipment & Supplies
Having reduced 3 inches missing copy print of Legal page (8.5 x 13)
Hi..
me too having same problem in MS Office..but finally i observed sometimes paper sizes or faulty..so try to reduce the paper size..
Apr 05, 2014 | Konica Minolta Bizhub 500...
I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
Press Copy until Reduce/Enlarge appears in the top line of the dis
The following options are available in the Reduce/Enlarge menu.
you will have three choices.
Reduce/Enlarge
Actual Size
Custom 100%
Full Page 91%
Legal > Ltr 72%
Also:
Use Photo Fit to Page when you want to automatically enlarge your original
photo to fill the printable area of the paper size loaded in the paper tray.
Photo Fit to Page only enlarges original photos that are standard photo sizes. The
standard photo sizes are as follows:
• 3.5 by 5 inches (9 by 13 cm)
• 4 by 6 inches (10 by 15 cm)
• 5 by 7 inches (13 by 18 cm)
• 6 by 8 inches (15 by 20 cm)
• 8 by 10 inches (25 by 25 cm)
For originals containing text or photos that are not a standard size, use Reduce/
Enlarge.
Manual is HERE Copy functions start on page 27.
Mar 27, 2011 | Office Equipment & Supplies
How to do copies,ie what buttons do i press
Making a Single Copy
Place the original face down in the ADF.
2 Press Copy/Help twice.
To cancel, press Stop.
Do NOT pull on the paper while copying is in progress.
Copy Options: Single or Multiple Copies,
Reduce/Enlarge, Sort/Stack
You can choose additional copy options. First, you can select the number of copies. Next, you can
choose whether multiple copies will be STACKED (all copies of page 1, then all copies of page 2, etc.)
or SORTED (collated). Finally, you can choose an enlargement or reduction ratio. To automatically
reduce the copy to the paper size you have set for the paper tray, select AUTO. To reduce the copy by
a fixed percentage, choose 93%, 87%, 75% or 50%. Or, to enlarge the copy, select 150%, 125% or
120%. To copy a document at its original size, select 100%.
1 Place the original face down in the ADF.
2 Press Copy/Help.
3 Enter the number of copies you want (1-99).
For example: Press 9 for nine copies.
To start copying now, press Copy/Help.
If you would like to select additional copy options, like
SORT, ENLARGE or REDUCE, press Menu/Set.
Oct 02, 2009 | Brother FAX-T74 Plain Paper Thermal...
MFC-6490CW, photocopy of 11x17 document prints 8 1/2 x 11 full scale image on 11x17 sheet. The image is centered on the 8 1/2 dimension, and located at one end of the 17 dimension. The rest of the 11x17...
First make sure you are not using "fit to page" as this feature does not work for legal size documents. To fix this problem we need to check several things. First, Press Copy, Load your document, press 1 for number of copies, press the up/down arrow until you get to "paper size" then choose legal (for 11x17). Press OK
It is also possible that your machine is set to reduce/enlarge size to less/more than 100%. If the first solution did not work start over, press copy, load document, enter 1 for number of copies, press up/down arrow to choose "enlarge/reduce" then use right/left arrows to choose 100% (again, do not choose 'fit to page') press OK. Once you have done this, you can set these as default if you like. Press Copy, press up/down arrow to choose new setting, press OK, press 1 to choose YES, press stop/exit.
Apr 18, 2009 | Brother Office Equipment & Supplies
Printing Problem
My first copy comes perfect second copy the yellow color is getting shake
Nov 20, 2008 | Xerox DocuColor 12 Printer
Cannot reduce size from 11x17 to letter
The NP6551 is an analogue copier, using only mirrors and lenses. It has no way of rotating the image. If you want to reduce a 11x17 to a 8.5x11 both peices of paper need to be fed in the same direction, ie short edge first. Change one of your trays to LTR-R ('R' for Reduction) or feed the LTR paper in thru the bypass in the long direction. If you use te bypass you must specify the paper size as LTR-R, you cannot use FREE.
Jul 26, 2008 | Canon NP 6551 Black and White Copier
Lexmark X5100 printer. I copied a small item 3x3 and doubled its size. Now when I try to copy a full page only one small corner is reproduced. It appears I lost a default setting. How do I get a full page...
If you are using your All-In-One without it being attached to a computer and scanning a document that is getting cut off on the edges:
1 Move the document to a different place on the glass.
2 On the operator panel, press the Reduce/Enlarge button
repeatedly until Fit to Page appears.
3 Press Select.
If you are using your All-In-One attached to a computer:
2 From the software, select a copy setting with autocrop on (Color Photo or Black and White Photo) to make sure that autocrop finds the object and prints it completely.
1 From your desktop, double-click the Lexmark X5100 Series
All-In-One Center
icon. The All-In-One Main Page appears.
2 Click Preview Now to see your scanned image.
3 Select a quantity and color for your copies.
Note: To choose a paper size or further customize your copy
job, click See More Copy Settings.
4 Click Copy Now.
Note: When autocrop is on, the object (wherever it is placed
on the glass) will be printed in the upper left corner of the
page. This might make your copy look different from the
original.
try the above and post back so I know if your issue is fixed or you need more assistance
Jul 12, 2008 | Office Equipment & Supplies
Ricoh Aficio 450 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
