Question about Sony Dual Shock 3 Controller for PlayStation 3
I bought a dual shock controller but the little reset button at the back doesn't have a button in it, so can't reset. What can I do. The lights are blinking when I plug in the usb cable, but that's it. Nothing happens. Do I have to leave it to charge?
    Scholar:
  • 105 Answers
You need to use a paperclip to press the reset button. Unfold the paperclip and push it into the reset hole which is to the right of the screw above the sticker on the back of the controller.
Once you have reset it, plug in the USB cable and press the round button to sync with the PS3.
Hope this helps,
Chris
Posted on Mar 17, 2011
Brand new Sony dual shock 3 analogs not responding like my other ps3 controllers
Take it back to the shop if it is under warrantee. Don't mess with it and destroy your warrantee.
Mar 11, 2014 | Sony Dual Shock 3 Controller for...
My mad catz dual force ps2 controller wont work
you will need a dual shock 2 ps2 controller. The mad catz controller is probably a dual shock 1 controller. Some games require the dual shock 2. It should say on the back of the game if the dual shock 2 is required. If it says something along the lines of "pressure sensitivity" or "pressure sensitive" on the back of the game case (where it says "1 player" or "2 player") ... then you will need a dual shock 2 controller. If this is not the case and it only says "analog controller" and "vibration" then you won't need the dual shock 2 controller. If the controller doesn't work for any games or even on the console main screen, then it must be the controller that is broken. Try turning the system on without a game in it and see if the controller works. Hope this helped :-)
Oct 16, 2012 | Mad Catz PS2 Dual Force Controller
Dual shock 3 controller will no longer stay synced to my system. When I turn on the PS3 I can press the Home button and four lights will flash but the control won't connect wirelessly. When I plug in the...
Have you recently tried using the controller for a different system.
If so, you will need to get a safety pin or something similar to press the little 'reset' button on the back of the controller. Once you press this button, connect the controller using the USB cable and you should be ok.
If this doesn't work, your wifi card has gone bad and will need to be replaced.
To check your wifi card, which controls everything wireless, try connecting your PS3 to wi fi. If you can connect then your card is good. If not, then you will need to have it replaced. Good luck.
Jan 20, 2011 | Sony Dual Shock 3 Controller for...
My dual shock 3 do not sync with my ps3. When I push ps button to sync it plug on the usb cable I got the no. 1 and 2 light than stay on. Thanks!
At the top back part of the controller there is a little pin hole button. With the console on, press the PS button and then the little button inside the pin hole to sync the controller.
If i've helped you please give me a good rating.
V/r,
Don
May 09, 2010 | Sony Playstation 3 (PS3) Console
All light blinking then two lights stay on and no button works, i can only turn on my console (pres ps button) via usb connected to this controller. tried to reset controller, turned off console and turned...
Ok, you've probably already figured this out, but you are in possession of a worthless POS fake PS3 controller. Congratulations: http://www.youtube.com/watch?v=mji_PLB7Tb0
Don't feel bad - i just bought a used white ps3 controller from gamestop and it was FAKE. they better take this back....
Sep 18, 2009 | Sony Dual Shock 3 Controller for...
All lights on Dualshock 3 blink 5 times, then do nothing.
On the back of you dualshock pad next to the L2 button there is a tiny small hole witch looks like it could be a screw hole ! well this is the reset button once you have pushed this you will be able to conect your pad to your usb cable and it work on your console again
Aug 30, 2009 | Sony Dual Shock 3 Controller for...
Dual Shock 3 Doesn't seem to work at all
i have the perfect solution...
step 1- plug usb into controller, make sure the system is off
step 2- press thee reset button on the back of the controller then turn your system on with the systems on-button
step 3- once the system is on, press the ps button.
step 4- remove the usb and then pres ps again
step 5- it workz, gud lukk!
Apr 12, 2009 | Sony Dual Shock 3 Controller for...
Triangle button sticking
Try a little rubbing alchahol on a Q-tip. do not drip in to controller, just rub around the button and press the button a few times. might have to do it a few times, let it dry before doing it again. It will break down what ever is sticky.
Jan 28, 2009 | Sony Dual Shock 3 Controller for...
Sony Dual Shock 3 Controller for PlayStation 3 Logo
127 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
