Question about Braun Cruzer 3 Electric Shaver
My shaver braun cruzer 4 is blocked by hair. I can not open it for cleaning. is a design problem
  • 5 Answers
SOURCE: how to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
Posted on Jan 07, 2009
brector3
  • 1625 Answers
SOURCE: braun 5614 battery replacement. where
You will find replacement batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-battery-nimh-2-batteries-p-105.html
Start by removing the foil and cutter. To open the shaver body, start by removing the two round screw covers on the bottom by prying them out. Then remove screws. The insides of the shaver can then be slid out through the top. Batteries simply unsnap from their connectors. Install new batteries and reassemble in reverse order
Posted on Oct 20, 2010
SOURCE: Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Posted on Sep 02, 2008
SOURCE: Braun Model 549 series electric shaver
broken screen braun 549
Posted on May 29, 2010
brector3
  • 1625 Answers
SOURCE: disassemble a braun Clean & renew razor cleaner
To open model 8985 you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
If replacement parts are required, you will find all components for this model at shaveroutlet.com
Posted on Jun 13, 2010
How to replace battery braun shaver series 1
I don't know about this specific model of Braun shaver (I have a Braun Model 7526).
I have looked at the instructions for a couple of models of Braun Shaver, and the instructions are similar so it may help you to replace the batteries in yours.
Here is one of the instructions:
Braun 7526 battery problem
http://www.fixya.com/support/t1171024-braun_7526_battery_problem
Open the shaver:
3) Using a small torq driver remove the 4 screws
4) Open shaver
6) Remove and replace circuit board with batteries (or solder in the new batteries)
And here is a link to instructions for a few different ones:
http://www.fixya.com/support/t1094906-needs_new_batters_open_razor_7526
http://www.fixya.com/support/t6710169-change_battery_cost
http://www.fixya.com/support/t771258-braun_battery_replacement
Nov 16, 2015 | Braun Series 7 9585 Hair Trimmer
I just purchased a new braun cruzer 4 z-60 wet and dry I charged it for 5 hours It seems to be fully charged It does work at all???
you have to see the charging limit of the shavers. Please see the helping book. Your problem will be solved
May 29, 2011 | Braun Health & Beauty
The trimming blades of my Shaver do not work. my hair got stuck in it. It seem the blades do not move across each other.
Assuming you have cleaned and lubed the blades, then you need to dismantle requiring a torx screwdriver.
Firstly, take off the top cover and remove the foil itself. There are two torx screws there, and another one where the power charger goes in at the bottom.
Once those 3 are removed, pull apart the main black/grey sections. There are 2 more screws holding the battery in place, remove them and the battery. Next bit is tricky - where the 2 grey 'dimples' are, gently loosen the two sections which should leave the black slider holding the trimmer and just one side of the grey outer shell. It felt to me it was going to break, but came apart without issue.
I couldn't work out how to seperate the black trimmer section here, but you can buy replacement trimmer sections so assuming it's possible somehow. From here, I cleaned, and soaked the blades with lube overnight. Then put back together again.
Feb 03, 2011 | Braun Cruzer 3 Electric Shaver
Removing BRAUN 1775 Cutter Block
Hi Miller1292
Braun have great user manuals with good pictorial instructions on how to service your shaver. To get a copy for your shaver, go to this site
Be sure to pick one that is in English:) Thanks for using FixYa, a FixYa rating for my solution would be awesome. Cheers
regards
robotek
May 07, 2008 | Braun FreeControl 1775 Hair Trimmer
Trimmer malfunction
I had same problem, at first I could not find out how to seperate the small silver cover with the on/off switch from the rest. After removing the 3 torx screws, 1 at the power entrance, and 2 under the shaver blade. You can remove the black cover. I also removed 2 more torx screws to separate the battery, from the rest, (don't know if thats really necessary). The silver covers are 'clicked' into eachother. When lifted the part where the battery part was screwed into, the silver parts became partly seperated, then you can pull the part apart.
I cleaned/washed the trimmer part with wd40 contact spray.
Assembled the parts, and made sure that the little plastic nodge was came into the trimmer.
Cleaned it all (removed leaking wd 40) and works fine again.
Hopefully this is helpfull to anyone.
Goodluck,
Adrian
Dec 25, 2006 | Braun Cruzer 3 Electric Shaver
Problem shaving
People, never ever buy the Braun body cruzer!!!! It does not mather which version/type you buy, with 'all' versions the big trimmer fails to work after aprox, 18-24 months.
I have bought three version of them, the first one stopped working totally after about a year. With the second one the large trimmer blade did not work anymore, so I bought the newest cruzer version (shaver #3 by then) in the hope Braun would have solved this problem. But NO, the same thing happend. After 18 months the trimmer is broke and I can throw my shaver in the bin because you buy this thing for the trimmer.
Now about 3 years later I have in total bought 3 cruzer shavers from Braun and all are broke (i am also almost broke, those things are pretty expensive here). And of course Braun does not help, they just say you are beyond warranty or did not take good care of the product. But I did, I keeped it clean with the little brushes, I put oil on blades/parts, and when I had shaved in the shower I made dry.... so I wonder what Braun means with "taking good care for your product" but i think they mean something like: buy a new one and give us some more of your money.
I will NEVER buy a Braun product again! And be warned people, don't say you where not warned for this product when you buy one and is goes broke within a year.
Sep 16, 2006 | Braun Cruzer 3 Electric Shaver
Braun Cruzer 3 Electric Shaver Logo
1,315 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
