Question about Tecumseh 5hp Engine Snow King Mtd Blowers Lh195sp67517
I have no spark when cranking this engine over, i feel it is the coil. how do i replace the coil
90 model Plymouth grand Voyager cranks no fire replaced coil and SBEC
Check for sparks. If no sparks, test crankshaft sensor. If sparks good, check fuel pressure at injector rail. Not sure which engine you have...tbi versus mfi.
Do It Yourself Diagnosis and Repair
Aug 11, 2017 | Plymouth Cars & Trucks
Engine stop
If theres no spark from the spark plugs then you would have to replace them?
Jul 12, 2008 | 1993 Toyota Corolla
P0302 mis fire, lacks power
Pull the spark plug of cylinder 2. Put the coil on the spark plug. Ground the sparkplug and have someone crank the engine. See if you see a spark. If you have no spark switch coils with another cylinder. If still no spark it could be one of the wires going to the ignition coil. If there is a spark do you smell gas at the spark plug hole? Could be no fuel to the cylinder.
Apr 22, 2014 | 2008 Ford Escape
Troubleshooting engine
Yes you are heading in right right direction. Check to see if there is spark out of coil. Spark at coil means replace distributor or rotor. No spark at coil replace ignition module or crank sensor good luck. Oh yea crank sensor is cheaper i would try that first if there is spark out of coil.
Apr 18, 2014 | 2001 Ford Explorer Sport
My ktm cut out now won't start and got no spark
have u tried a new plug ? is power gettin to coil , put plug in cap and hold against a good earth point on head and crank over and see if plug sparks , if you dont see a spark try holding the plug and crank engine and if you dont feel voltage in your hand then remove cap off ht lead and repeat and if no voltage then check kill switch , if ok then check coil wires etc !
Nov 15, 2013 | KTM Motorcycles
My 1994 oldsmobile 98 regency won't start
Check fuel pressure,spark.If no spark possible crank sensor or ignition module.If no fuel pressure tap the bottom of the fuel tank with a mallet while someone is cranking the vehicle if it starts then you will need a fuel pump.Also if you have spark and fuel but the engine feels like it bucking while turning over,take a hair dryer and heat the coils up.you may have a bad coil pack.After they get warmed it night then start as the coil resistance changes.
Dec 02, 2010 | 1994 Oldsmobile Ninety Eight Regency
Wont start
is the your car engine cranking when you try to start, first check spark plugs ignition coils, remove one ignition coil and spark plug fix the spark plug in to the ignition coil then connect ignition coil to wiring and keep spark plug body touching on ground of engine head mettle parts, ask some one to crank engine then you can see is the plug sparking or not, do the same way to all the coils and plug otherwise you have to buy a ignition spark tester, is the all the coils and spark plugs are OK then check the fuel pump, it's sitting in under rear seat, before that do one thing disconnect oxygen (O2) sensor wiring and crank engine, the thing is if your oxygen sensor completely dead fuel pump will stop working, if engine start after disconnect O2 sensor, replace new O2 sensor, otherwise need to check fuel pump relay fuse and fuel pump. is this information helped you? please vote me and give a comment.
Oct 15, 2010 | 1998 BMW M3
OK 1997 gmc sierra 5.7liter 4x4 replaced coil and
Doesnt this engine use a crank position sensor? mounted on timing chain cover.I would check that first
Oct 17, 2009 | 1997 GMC Sierra
Galant Special Edition 1994 Motor does not start
this maybe caused by no fuel or faulty fuel pump, ignition coil, wire and plug crank position sensor. first check for spark by removing on spark plug wire and put a spark plug in the spark plug wire boot, donot touch the plug only the boot have someone crank the car over. if you see spark, that part of the ignition is good. if not, check the coil resistance if should 40 to 80 ohm with a volt meter pf not replace. if ok, but no spark check the igniton control madule make sure the coil and module are receiving current. if not check the fuse that feels them. if it is ok, check distributor cap and rotor. if rotor and cap are fine, check for fuel at either the fuel filter, the fuel return line or removing some spark plug and see if they are wet. if there is no fuel check the fuel pump and the fuse and relay that control the pump. if there is fuel with high pressure but there is no spark, check the crank sensor for signal with a volt meter while cranking the vehicle
Jan 02, 2009 | 1993 Mitsubishi Galant
Tecumseh 5hp  Engine Snow King Mtd Blowers Lh195sp67517 Logo
21 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
