Question about BUFFALO Shop HD-CX1.0TU2 1 TB USB 2.0 Hard Drive
I have plugged my hdd in and its not loading my files or anything and not lettin me formt it or anything
    Scholar:
    New Friend:
  • 135 Answers
From my experience, Buffalo is the worst brand when it comes to External Hard Drives. I had two of em already become faulty. I hope you have warranty because it sounds like you have a physical problem with the Drive. If it is not picked up by the computer, then that is not good because it will be most difficult to use file recovery programs. You may have to take it to data recovery specialists who can repair physical damage OR you can open it up and connect it directly into a desktop computer as another Hard Drive. (Sometimes possible if you know how). Good Luck
kc
Posted on Mar 17, 2011
View drawing in jef format
You need a view program to see stitch files as images. Viking has one at this link.
http://new.husqvarnaviking.com/en-CA/Software/6D-Explorer-Plug-in
Feb 06, 2014 | Janome Sewing Machines
Tip
Instaling operation system when a Sata Hdd is not seen
I will show a trick about how to install an operation system when you have an erased sata Hdd ..and cause of the lack of a raid driver it is blocking the boot and not let you boot even from cd ...
Insert the boot-able installation cd ...choose to boot first from cd ..and to trick the computer just remove the power supply from the Sata Hdd ...This way you will make it go on and boot from cd ...Keep in mind that the primary drivers and files that are loaded when the installation starts ..are not stored on the hdd..so it will not see the drive missing ...after it starts to load files...and before getting to the agreement ..just plug the supply back to the Hdd.. in this point the primary drivers will be already loaded ..and the computer it is already seeing the hard drive ...and will continue the installation like on any other one without any problems...
Good Luck !
on Feb 02, 2010 | Computers & Internet
I have an iomega eGo portable hard drive - i am able to load my music and files onto it from my pc - but when I plug it into my android superpad tablet, it tells me its damaged and that i need to reformat...
What is the format system for the external HDD? Is it NTFS or FAT?
If it is formatted on a PC then it might be NTFS and android will not recognise NTFS. You might have to plug it back into the pc and change the format system by reformatting the external HDD in FAT32 or exFAT.
To format the HDD (Hard disk drive) plug it into windows and when it appears on the screen (This Pc or My Computer screen) next to your C: drive, right click the HDD and select format and when the format window opens select the "File system" drop down menu and change it from NTFS. Then format it and plug it into your tablet to test it.
Oct 07, 2017 | Computers & Internet
Ntlrd is missing
hi
First I would backup the hard drive (save important data, docs, pics, files etc..). to do that without loosing data (hope the hard drive is not deleted or formatted prior to this)
you need and external box (ide/sata hdd caddy or cable) where you put your hdd in and plug it in ,externaly to an other pc or laptop.
if the other pc/laptop see your hdd then it' good news. try searching for you files and docs e.g.(C:\Documents and Settings\Student\My Documents )
after the backup try scanning your hdd using CHKDSK /f /r from the command prompt (start-run-cmd-enter then type chkdsk (disk letter) /f /r + enter) this might take few minutes.
put the hdd back and restart, see if it will work. If not, you might need to re-install the operating system.
hope this solution helped.
tekspotcouk
Sep 11, 2009 | Dell Inspiron 6400 Notebook
Yo nothin lettin me adding my music to my philips limewire aint doing ****
try this playa........plug the philips to th pc.........now go to my computer (you should see a new icon) yeah click on it to open it up..........now find the folder that has the music tracks in it and open that up.......(see all your mp3 files) click and drag (or copy and paste) on anything you want to have on philips........using limewire remember to share files
Jun 04, 2009 | iLO MP3 Player
No recognized by any PC I try to plug in
Hi are u sure the hard disk was not complitly full if yes try to use anothe backup software such as easy recover pro or so and copy all the data from your hdd to another location but befor udo so please be sure
1. shut down your system shut down the hdd plug the power properly to your hdd and connect the usb or firewire then connect the medium to your system and start the hdd and then start your system ...if it detected its fine...
2. if still dosent detect check in disk management by right clicking on my computer icon go to manage and then disk management if u see the hdd over there and showing status a forigen just right click on the word and say import forigen disk .and should work
if the status shows unalocated right click on it and say intialize hdd ..
if shows helthy and be sure have a drive letter on if not then please right click on the hdd strap and say add or change drive letter and use any abailable drive letter
thanks
good luck
Aug 27, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
I am trying to install a WD 250GB Passort V2 External USB 2.0 - 2-50" Portable Hard Drive but unfortunately my Windows XP doesn't want to know it. I have had it just over a week now and when I first...
Did you try a different usb port? is the cable plugged in correctly? check device manager and monitor it once the ext. hdd is plugged and report back with the result plz.
Jun 16, 2008 | Computers & Internet
I have an old atari 1040st . having loading problems . Sometimes it locks up or it just won't load
4 solutions:
1.) HDD has bad sectors: use Windows Recovery console "chkdsk /r", or replace HDD
2.) Opertaing system stuffed: Windows repair installation.
3.) HDD heavy fragmented: defragment HDD
4.) Out of memory: Reconfigre Page file and VRam settings and OR install additional Memory
Apr 16, 2008 | Computers & Internet
Not responding after flashing "loading" for 1 minute then get message R-Lk --:-- on display
Hard drive issue or power supply. Power supply prone to bad capacitors (look for leakage/swollen tops)
If hard drive faulty you'll need a new one which is no small task. Disk contains firmware and custom file system and smallest I've got image is 10.7gig
Feb 02, 2008 | JVC DR-MH30S DVD Recorder
BUFFALO Shop HD-CX1.0TU2 1 TB USB 2.0 Hard Drive Logo
141 people viewed this question
Top BUFFALO Computers & Internet Experts
john smith
Cosma Papouis
Cosma Papouis
Are you a BUFFALO Computer and Internet Expert? Answer questions, earn points and help others
