I've set up my toshiba 22BV500B and i need to find out how to reset my Tv because i cant seem to find the setup option for installation
3 Suggested Answers
  • 317 Answers
SOURCE: I would like a Toshiba
try
operatingguides.com
or
servicemanuals.co.uk
Posted on Jul 05, 2011
  • 1746 Answers
SOURCE: There was an electrical storm close to our home,
Hi, You should have unplugged your set in a storm like that. You should have had a surge protector too. I believe you will be looking at a big repair bill. Good luck.
Posted on Jul 19, 2011
I have a toshiba 42HL196 tv and i am trying to connect it to an external antenna. I cant find a channel scan option in the setup menu. The menu on my tv is not the same as the toshiba video.
First check the current source. Press the Input button on the TV (second from the left) or on the remote (below 9) until the correct Antenna input (Ant 1) is selected. Make sure that the antenna is connected to Ant 1 (the RF connection closest to the back HDMI ports). You only use Ant 2 if you have a coaxial (RF) cable connection. Then press Menu and then try the Setup menu again. You should be able to access the Installation menu and Terrestrial sub-menu now. Change the Input Configuration for Ant 1 to Antenna before attempting to Program Channels.
If this doesn't work, try resetting the TV to the factory settings. You'll have to access the Menu, go to the Installation sub-menu and then select the System Status and then System Information. Select Factory Defaults and enter the PIN. See the manual for the default PIN if you haven't changed it. Then confirm the reset. The manual is available from the product support page: http://support.toshiba.com/support/modelHome?freeText=2841536 . The direct link to the manual is http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2846615/42hl196_om_e.pdf . See page 29 for the PIN. Then try accessing the Terrestrial menu and scanning for channels.
I hope this helps.
Jan 31, 2017 | Toshiba Televison & Video
My toshiba flatscreen says retail unlock on it an it wont do nothyn.. how i fix it without original remote
You can reset and eliminate the lock on some televisions without the remote.. Hold the power button for five seconds. The television will automatically restart. If the lock is still on, unplug the television and remove the battery from the back panel of the television. Wait several hours before reconnecting the plug and reattaching the battery.
You say you have a Universal remote. If you have not done so yet use the procedures that came with your remote to install it on your Toshiba. After using the install procedures you should at least be able to power on and off the TV.
power the TV on and then do the following:
TOSHIBA specific advertisements or "Retail Lock" at anytime when operating, perform the following procedure:
  1. Using the remote control, press 1, 2, 3, 4 in this order. This will release the "Retail Lock" mode.
  2. Perform a factory reset of the TV
  3. Resetting Factory Defaults:
To reset all settings and channels to their factory default values:
1 Press the MENU button and open the Installation menu.
2 Highlight Reset TV, and then press the ENTER button.
3 Enter your PIN code (If a PIN code has been set).
4 A con?rmation screen appears. Select Yes, and press the ENTER button. The TV will turn off automatically.
Then do the following:
  1. Power on the TV. You will be prompted to perform the first time setup.
  2. Be sure to set the Location option to Home.
  3. Continue with the first time setup.
The "Retail Lock" should be disabled and you can now use all the functions of the TV.
hope that helps
Jan 23, 2015 | RCA Televison & Video
Toshiba 32BL505B- 32 inch TV - Lack of settings - No Installation, or TV Settings.. Please Help
1. Press the menu button on the remote
2. Once the menu comes up press the numbers 7935 in succesion
3. This should bring up the hotel menu, turn off the hotel mode at the top of this screen
4. Then press the menu button to exit out of the menu and next time you press the menu button there should 6 icons available
Jan 10, 2013 | Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
There was an electrical storm close to our home, we had a flash of lightning. Now we can't get a picture to show. The menu works, but nothing from satellite, Wii and DVD. Is there a way to reset...
Jul 19, 2011 | Panasonic Viera TH-42PX80U Plasma TV
I would like a Toshiba 22BV500B TV manual please.
try
operatingguides.com
or
Jul 05, 2011 | Toshiba Televison & Video
Manual for 22bv500b
Please click on the link below to download the manual for your TV:
http://www.toshiba-om.net/LCD/PDF/English/Country_Specific/BV500-22-English-Specific.pdf">Toshiba 22BV500B User Manual
The manual will open in a new browser window or you can click on the link with your right mouse button and choose "Save Target As..." from the pop-up menu to save it directly to your PC. You will need to have Adobe Reader or another PDF file viewer installed on your PC to open the file
Click here to download Adobe Reader
Hope this helps. If you have any difficulty downloading the manual or need further assistance with your TV, please let me know.
Regards,
BElectric.
Apr 27, 2011 | Toshiba Televison & Video
Toshiba regza 37" reset defaults
Unplug the TV for some time (usually 1hr is plenty) and it should reset to factory settings.
Mar 14, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
My wife tried to set initially install digital & analogue on my new TV set (Toshiba 32BV500B32 in) and didn't succeed. I would now like to reset the TV or get it back to the original as new settings...
Unplug the tv about a day,go into the tv Menu goto SETUP go down to resetting.Tv now should erase all the old memories setting and the resetting ensure going back to factory setting.
Dec 20, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
