Question about Delta 36-979 10" Left-Tilt Contractor's Saw
10 inch lest tilt Unisaw will not tilt to complete verticle --only goes to 88.5.
    Problem Solver:
  • 13 Answers
There is an adjustment under the table top. It usually is a bolt with a lock nut that allows you to adjust the table to a predetermined angle every time. You can adjust the amount that the table will go by unlocking the lock nut and then turning the bolt the correct direction allowing the table to come to a full 90 degrees. Once you have the table a 90 degrees lock the bolt down with the lock nut. This will aloow you to change the tilt of the table to something other than 90 degrees and then come back to the 90 degrees by turning the adjusting wheel until it bottoms out against the locked doen adjusting bolt.
Posted on Mar 17, 2011
Difficulty raising and lowering the blade on Delta rockwell10" unisaw 34-450
Ok, basic question...is the lock engaged? It is the small knob at the center of the adjustment wheel. Is it possible the screw has been galled?
Here is the manual- http://content.powermatic.com/manuals/1791227K_man.pdf
May 27, 2014 | Powermatic 1791227K Model 64 10" Artisan...
TABLE IS PLUG MOTOR IS NOT RUNING
There may be an overload reset button on the motor (usually red). Check for a reset
Oct 23, 2012 | Delta 36L352 10" 3 HP 220V Single Phase...
Delta table saw shuts off at strange intervals, let it sit for 5-10 minutes and it starts back up and works for a while?
IF THE MOTOR GETS HOT THERE IS A THERMAL TRIP LOCATED IN THE WINDINGS, this will cut the power to the motor to prevent a burnout ,get the motor serviced
Aug 26, 2012 | Delta 10" 3 Hp, 230V, Single Phase, Right...
How tight should the belts on my unisaw be?
I'd say so when you push on them in the middle you get about 3/4" deflection, snug but not guitar string tight either.
May 12, 2010 | Delta 10" 3 Hp, 230V, Single Phase, Right...
Unisaw Jet Lock rip fence set-up
Go online to OWWM.com and download the manual. Don't forget to make a contribution. This will give you the step by step instructions for setting up fence. The jetlock is pretty easy.
May 23, 2009 | Delta 10" 3 Hp, 230V, Single Phase, Right...
Wobbly tilt wheel
Remove horn pad . After removing the large nut SCRIBE A LINE ON THE CENTER SHAFT and the STEERING WHEEL, Using a steering wheel puller, remove steering wheel. Now comes the tricky part. Remove signal stalk ( just pull out a couple of inches ),and 4-way flasher knob. Disconnect multiple connector of signal switch. Remove 3 screws holing switch down. Gently pull upward on switch to expose lower steering bowl. The large bolts are LOOSE that secure it, so the reason for the wobble. Tighten bolts, and reverse procedure.
Mar 31, 2009 | Oldsmobile 88 Cars & Trucks
Delta unisaw W/LVC
I think this is what you're looking for:
http://media.ptg-online.com/media/dm/OwnersManuals/20040331153155_En438-01-655-0002-04-01-04.pdf
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 29, 2009 | Delta Machinery 3 HP Left Tilt Unisaw with...
Delta 36-979 10" Left-Tilt Contractor's Saw Logo
214 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Delta Saw Expert? Answer questions, earn points and help others
