Question about IBM 6262 Printer
IBM 6262 Model 12: Status Code 1120 Hammer Failed Set Error. Technician on site has done: replaced both Hammer Driver Cards, Replaced the Blower Unit, Replaced all Hammer Blocks. Also can the DC Distribution PCB P/N 839040 be used in place of P/N 839080 and work?
3 Suggested Answers
  • 13 Answers
SOURCE: IBM Infoprint1120 and Lexmark T520 toner cartridges.
You cannot use Lexmark toner cartridges in IBM models and vice-versa because the toner carts have a smartchip that identifies the toner to the printer. IBM printers expect to see IBM toners and Lexmark machines expect to see Lexmark toners. If you put the wrong cartridge in you will get '32' Unsupported print cartridge error.
Some refillers may swap the smartchip when they refill cartridges and this would be the only reason why you may have seen it done before.. IS your current toner a refilled one? It's technically possible to make an IBM printer into a Lexmark printer to accept Lexmark toners by replacing the System Board... but why would you bother doing that...just use the right toner.
Posted on May 28, 2009
  • 910 Answers
SOURCE: Getting an error message on
Sorry if this is a little vague but this is all I've been able to find in the 30 minutes we get to review a problem.
K102 is a control relay and the error indicates it's faulty.
The only place I've found that may be able to supply a replacement is at the link below although I suspect this would be a job for a printer engineer.
http://www.theprinterplace.net/cgi-bin/fccgi.exe?w3exec=TowerApp&FormName=PartSearch&PartNumbers=062H2734
I'll keep looking to see if I can find any further reference to this relay or a service manual showing its location.
p.s. Model No. is 6262-D22
Posted on Aug 10, 2011
Printer not printing first 3 left characters
There are 2 kinds of 6262 that have vastly different hammer asm, but most likely you have a hammer issue. If it is a 12 or 14 you would need
IBM 5665720 HAMMER COIL 6262 Refurbished
It can also be a cable or card, but those normally have errors reported.
PS I don't know why the wrong pick is coming up for that part on fixya, but the site has no pic as the part is super old.
Nov 04, 2015 | IBM 6262 Printer
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Need print driver for ibm 1120 using win 7 64 bit
You can download the BM InfoPrint 1xxx AIX Print Driver from the IBM support WEB site. Please click on this link and select your model printer to download :- http://www-01.ibm.com/support/docview.wss?rs=95&context=SRATEW&dc=D400&uid=psd1P4000313&loc=en_US&cs=utf-8&lang=en
Dec 12, 2012 | IBM Infoprint 1120 Laser Printer
Bad DirectSound driver. Please install proper drivers or select another device in configuration. Error code: 88780078 for IBM think pad
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows XP or Vista devicedrivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true You can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
Dec 18, 2010 | IBM ThinkPad Soundcard
Missig driver
try to search in the internet the driver of your printer
Oct 30, 2010 | IBM Infoprint 1120 Laser Printer
May 19, 2009 | IBM Infoprint 1120 Laser Printer
IBM R50e SOUND DRIVER
Visit this link for your sound driver:-
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-55042
Don't try to update BIOS now. It should be done only when asked to or the error message "update BIOS" appears on the screen..............sodeep
Apr 20, 2009 | IBM Computers & Internet
Infoprint 1120 929 service toner sensor error code
The problem is caused by one of the following (normally it's the cartridge that's faulty, very common on Lexmark's and IBM Infoprints)
The toner sensor is not operating properly, the developer
drive assembly is not operating properly or the print
cartridge is defective
Jun 09, 2008 | IBM Infoprint 1120 Laser Printer
164 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
