Question about LaCie Computers & Internet
When I connect my lacie to my computer my computer does not detect it. There is no light on the lacie. I have had the lacie for 3 years and have never had a problem
    Scholar:
  • 72 Answers
Since you didn't specify the model number, I can only guess that it is a USB model.
Assuming this is the case, your BIOS setup in CMOS memory may have become corrupted. You will have to enter SETUP when you first boot the computer, usually by pressing the Delete key, F2, or something else. When you boot, it usually tells you what you need to do to enter SETUP.
Navigate to the menus for both USB and hard drive configurations and make sure they are set up according to the parameters of your drive. USB must be enabled, and the computer should be able to detect the drive in BIOS, if it has not become corrupted.
Posted on Mar 17, 2011
My computer will not detect my LaCie external hard drive
Hi, Try to restart your computer while it is connected. It may detect it then. Good luck.
Sep 23, 2011 | LaCie Computers & Internet
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My lacie hard disk 1tb all of a sudden isnt
Just contact www.lacie.com great support. their answer for my drive was to reboot the drive. For me it worked.
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Jan 27, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Cannot detect LaCie mini hub HD.
Try a new power supply. $19.99 at Lacie. It worked for me.
Dec 20, 2009 | LaCie Computers & Internet
My computer is not detecting my LaCie Hard Drive
there is a usb port inside hd .box /many time it is damage and also usb cablle damage . so once time change this thing one by one to check. there is a rare chance to damage hdd. we have facinge many time same problem. this hdd and laptop hdd are same. only potr is diffrent, (nepal)
Oct 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
I can't connect to Edmini via LAN nor USB. LAN computer doesn't detect then I tried to check edmini from browser then I get this message /www/cgi-bin/public/sharelist: line 246: cannot create temp file...
Just contact www.lacie.com great support. there answer for my drive was to upgrade the drive version and to reboot the drive. Maybe the last thing is enough. For me it worked.
If necessary update driver http://www.lacie.com/nl/support/drivers/driver.htm?id=10156
Jul 29, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Not detected
Check that power is on and that the usb cable is firmly connected at both ends.  If running the usb through a hub try a direct connection to the computer usb port.
May 29, 2009 | LaCie 301103U 500 GB USB 2.0 Hard Drive
Drive is not ready-error message when i connect Lacie 320gb
Check BIOS for detection of hard disk and if detected operating system may need driver or corrupt
Apr 13, 2008 | Computers & Internet
Computers & Internet Logo
103 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
