Question about Vtech Whiz Kid Learning System by
Every this is fine exept pen it was broken i mean my son put it in his mouth so some of the wires were disconnected.
    Genius:
  • 1,157 Answers
Hi pks353,
The pen needs to be replaced. If you need to replace any parts for your VTech products, you can order them by calling the manufacturer. You can contact them via phone, fax, email at the contact information listed below.
P: 1.800.521.2010
F: 1.847.400.3601
E: vtechkids@vtechkids.com
Hope it helps.
Thank you for using FixYa.
Posted on Mar 17, 2011
Hi my name is Dean, I have a range rover sport, I recently bought & fitted LED tail lights, the lights work fine until I put the vehicle into reverse then all the tail lights go out exept reverse?
I suggest you suspect faulty grounding or earthing of one or more of the bulbs or lamps.
I suggest you pay particular attention to any wiring you disconnected or disturbed in the process of fitting the led lights. Multiway connector terminals are often electroplated steel prone to attack by dirt, water or damp air and such things often cause trouble after being disturbed.
Mar 28, 2016 | Rover Cars & Trucks
Tip
How to make ur pen drive long lasting
1. try to always keep ur pen drive mouth cover with the cab when nt in use, in order to prevent the steel surface to get rust.
2. always try to delete the files inside the pen drive than formatting, in order to nt decrease the volume the size of the pen drive.
3. dnt use pen drive when it is vry hot, in order to prevent it frm getting damaged.
For more tips, vote me
on Mar 24, 2010 | Computers & Internet
2000 camry electrical short?
Michelle, I would recommend taking your vehicle to a local Car Stereo Shop or the dealer. It sounds like your son may have tapped into the incorrect wire in the harness when putting in the new stereo. It sounds like a problem of ignition wire is going to ground. Or the constant power wire is going to ground. Either of these issues would cause this problem.
Mar 01, 2014 | Cars & Trucks
Wil not start( replaced battery )
Be sure the battery terminal connections are not loose or corroded. Check. For broken, loose or disconnected wiring in the starting circuit. Inspect all wirings and connectors @ the battery. Make sure the battery ground wire is still grounded. Ur starter solenoid. N neutral start switch could be responsible too, ur ignition switch. If all these are fine ur starter motor pinion might be jammed. Be sure ur new battery is working well. Put the key to the on position. Switch on ur headlights or windshield wipers. If they do not work, it means d battery s discharged. So be sure its not the battery.
Sep 08, 2011 | 1991 Honda Accord
When i am calling or receiving a call the person on the other handset cannot hear what i am saying
Kindly check your cellphone's microphone.... it might be defective or inoperative. If your cellphone is equipped with a handsfree system, try it. This could solve or confirm your problem.
Jun 01, 2011 | Cell Phones
When i ring people they cant hera me talking bu i can hear them
Hi
If a problem like this occur it means the mouth of the phone is faulty.
You can use a hands free to make calls until you have money to change the mouth piece.
To change the mouth piece piece open the the phone and bring out the mouth piece and the tale end of the phone were you normally put your mouth when making call. Replace The mouth piece with a new one and the problem is solved.
Regards.
Aug 28, 2010 | Cell Phones
My schwinn scooter wont charge, ive just put a new rear wheel on it and now it wont charge, ive tested the charger and its fine???
Probably a wire disconnected. Check the wiring harness for loose connections, disconnected wires, dirty connections pinched wires, broken wires. Also check and add water to the battery if needed. Check the battery connections and fuses.
Apr 22, 2009 | 2004 Factory bike Chrono SM 250
Is there a emergency shut off switch for a 1994 Buick Century?
yes it will be in the trunk on the same side as the gas cap pull back the panle and its a little black box with a red or yellow button press it in and it should be fine
Dec 10, 2008 | 1994 Buick Century
Broken wire from power inlet socket
I finally managed to remove the cover and solder the broken wire. Works fine exept the keyboard, but that is a result of old soda spill. This computer has been used with external keyboard for some months. I cleaned the keyboard with luke warm water and placed it for dry for 36 hours, but there are still som keys that dont work and Fn seems to be constantly on.
May 10, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Vtech Whiz Kid Learning System by Logo
329 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
