Question about Acer Aspire One PC Notebook
I have an acer aspire one its the net book error code 0x00000073 comes up when i try to log on BSOD comes up how can i fix this problem without logging on to my laptop when i cant get to the screen
  • 130 Answers
Well, here is the link that you may find more help:http://www.wiki-errors.com/wiki-errors.php?wiki=0x00000073 Good luck! var geo_Partner = '20df8a9f-0e62-447d-a13b-e4b279000c5f'; var geo_isCG = true;
Posted on Mar 17, 2011
Note book blue screen and report some type of error
This is BSOD short for Blue Screen Of Death, it is usually is a RAM or driver problem. Claim warranty support if available. If your notebook is out of warranty do the following:
Remove the screws that secure the RAM access panel.
Remove the RAM modules and clean the gold fingered connectors with tissue paper.
Now reinstall the modules in the correct orientation. Attention to the cut-out in the module for allignment.
Secure the RAM access cover with the screws and power on.
If it still gives you problems install the graphics driver for your notebook. Visit the Acer website and click their support button. Then select Netbook, then Aspire, then One Netbook, then click confirm. Download and install the graphics driver, latest one only.
Heat is another factor that pertains to BSOD, overheating of the Graphics card, RAM or Processor can also cause this error. Be sure to allow air into your Netbook. Try not to obstruct the intake and exhaust vents.
Take care!
damnor01
Oct 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
My net book was reformatted due to virus. remaining to be installed are PCI device and video controller but error code 28 appears and asking to see the maker's website for support. i'm far away...
IOBit.com has driver booster that will scan, identify, download, and install drivers. There's a free version and a paid version. This is assuming you're using Windows 7 or higher.
Dec 15, 2017 | Acer Aspire Notebook PC
0x00000073 error on my aspire one zG5
run registry cleaner it may help u, i will suggest u to use reginout cleaner
Dec 21, 2010 | Acer Aspire One PC Notebook
My Acer netbook will not boot all the way. The screen showing that Windows XP is starting shows up, but then it stops at the screen that asks me whether I want to go into safe mode. I tried pressing F8 and...
Hi, STOP Error 0x00000073: CONFIG_LIST_FAILED STOP error 0x73 means that one of the top-level registry keys, also known as core system hives, cannot be linked in the registry tree. STOP code 0x00000073 may also display "CONFIG_LIST_FAILED" on the same STOP message.
This can be either SAM, SECURITY, SOFTWARE or DEFAULT. One common reason for this to happen is if you are out of disk space on the system drive (in which case param 2 is 0xC000017D - STATUS_NO_LOG_SPACE)
This is a serious situation. What has happened to the PC? Was there a power failure? Sudden restart? I cannot say exactly that this is the problem. We have to analyze further.
Here are some steps and information to help you.
First of all make sure you have ENOUGH DISK SPACE in your SYSTEM PARTITION (Volume). STATUS_NO_LOG_SPACE means that logs and hive enumeration is not possible due to lack of the space. System drives has page files on it as well so First thing you have to do is to save some SPACE. If you have Windows DVD (or CDs - use CD1) just insert it and boot from CD/DVD. Go to Recovery Mode (Key is R). In the recovery mode Type DIR. If you receive an Error you have to type chkdsk PartitionName: /f /r As an example if your system drive is C that would be chkdsk C: /f /r ( Spaces between C and /, /f and /r ) Then the disk will be checked for bad sectors. Partition table will be fixed to normal.
If you do not receive an error and if you could see the files: Delete some files using DELETE command. (Use with caution - Try delete ? or delete /? for a list of OPTIONS). Create some space (If you use Vista make sure you have at least 1GB Empty Space. A calculation. You have to have at least 1GB + Space for the Page File. Page file uses 1.5 x your RAM Size GB space.). Then Boot the machine and check. That should work.
This post has two parts since its too long.
Jun 02, 2010 | Acer Aspire One PC Notebook
My Acer Aspire One hangs and brings up a blue
Blue screen with a message on it = BSOD  Find the number of the error and google for it, you will get a general idea of what is causing it.
The easiest way of fixing that is to backup your files and reinstall Windows.
May 31, 2010 | Acer Aspire One PC Notebook
My Acer Aspire 5920 won't do a recovery
BSOD is caused by hardware error or driver error. Disconnect all hardware except the basic. Motherboard, monitor, memory, hard drive. Unplug the wireless, cd/dvd drive.
Start the computer and see if the the BSOD returns. If not, one by one add components until you see the BSOD.
If you continue to see this screen without any hardware attached, then you most likely have an onboard component failing. (audio/video/memory failure)
Download and run the MS DART cd and check hardware starting with memory then hard drive.
http://www.microsoft.com/windows/enterprise/products/mdop/dart.aspx
This should determine what device is failing, except video or audio.
Jan 24, 2010 | Acer Aspire 5920-6727 Notebook
Will not boot up ( acer aspire with vista basic)
0xa 0000000 is a hard drive error .. either your controller or your hard drive has failed ..
Dec 28, 2008 | Acer Aspire 5315 Notebook
Acer aspire 5572 problem
your problem is called BSOD (blue screen of death).
many thing can cause this problem.
most common thing that cause BSOD are Operating system, memory and harddrive.
sometime motherboard+cpu can cause BSOD too, but not as often as memory+hdd+OS.
you should re-installed it first, if you still have BSOD,
ask your technician to check hdd and memory, if they can check motherboard + cpu, it would be good for you,
Jul 04, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire One  PC Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
