Question about Acer Aspire One PC Notebook
Power light turns green then shuts off in 1 second or less
    Problem Solver:
  • 9 Answers
Get the battery out. Unplug the ac adapter. Push the on off button down for a few seconds. Plug the ac adapter back in without the battery. Try to boot the operating system. Did it help?
Posted on Mar 17, 2011
  • 69 Answers
Check that the computer is plugged in with power. (is the power bar actually on?, the power cord lpugged into the brick? plugged into the back of the computer? Is teh power port loose/broken?)
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Turns on for less than a second. then shuts off
Unplug fo a .5 hour let it reset then see what happens when I got mine to fire up the blue side to side convergane wouldnt adjust GOOD LUCK
Jun 13, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Monitor is bad for sure. Try another known good monitor on your computer and if the problem stops then you know for sure the original monitor is bad. Hope this helps.
Feb 01, 2009 | Dell Dimension 3000® Pentium® 4...
Emmerson HDTV f32
The failure with this LCD might be due to a failing power supply or backlight inverter board. Since your TV is less then a year old, I would suggest to call the manufacturer to get it fix under warranty.
Good Luck.
Jan 17, 2009 | Televison & Video
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
do you have an aftermarket video card. In the bios you have to tell the computer if it is looking for a agp/onboard or PCI video card. Either that or the video driver or settings are wrong Try safe mode to check
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
Intermittent lamp turn off
I was told by the repair service to unplug the power cord for about 5min. This resets the internal computer. I think this helps but does not cure the cause. Good luck.
May 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Red light
System does not power on and the LEDs on the front of the computer are not flashing.
System unable to power on.
Press and hold the power button for less than 4 seconds. If the hard drive LED turns green, then:
1.Check that the voltage selector is set to the appropriate voltage.
2.Remove the expansion cards one at a time until the 3.3 V_aux light on the system board turns on.
3.Replace the system board.
OR
Press and hold the power button for less than 4 seconds. If the hard drive LED does not turn on green then:
1.Check that the unit is plugged into a working AC outlet.
2.Open hood and check that the power button harness is properly connected to the system board.
3.Check that both power supply cables are properly connected to the system board.
4.If the 3.3 V_aux light on the system board is on, then replace the power button harness.
5.If the 3.3 V_aux light on the system board is off, then replace the power supply.
6.Replace the system board.
Jan 02, 2008 | HP Compaq Business d530 PC Desktop
Acer Aspire One  PC Notebook Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
