Question about HP PSC 1410 All-In-One InkJet Printer
E in printer window even when disconected from computer. The light isI flashing next to the ink symbol. have tried swithcing on and off and putting the same cartridges in and out. I did get a test page printed, but the E remains.
  • Les H Aug 03, 2008
    The eventual solution I found was to replace the cartridge
  • 659 Answers
I have searched around and have not found this E error yet but still looking does it come up with any errors on the computer as well? Follow the steps below to reset the All-in-One.
  1. Turn off the HP All-in-One by pressing the Power or On/Resume button.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Plug the power cord back into the HP All-in-One.
  4. Turn on the HP All-in-One by pressing the Power or On/Resume button.
Posted on Aug 02, 2008
  • Wesley Gardner
    Wesley Gardner Aug 04, 2008
    awsome glad ya fixed it.
Printer won't print. Flashing lights under ink symbols and E. Have unplugged several times, taken ink cartridges out and put back in. Any suggestions?
Have you tried to possibly replace the cartridges one at a time till you find the problem one.. or perhaps its the contacts on the cartridge that need to be cleaned.
Dec 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | HP Laser Jet 1320 Printer
Red light flashing above ink symbol but plenty of ink
hello! the ink indicator is showing because the catrigde sensors could be coated by some dirt or ink . try cleaning the catridges slot with soft material .then put it on
Jul 10, 2009 | HP DeskJet 940c InkJet Printer
HP Laser Jet 1320. Orange light next to triangle symbol keeps flashing. This began after a paper jam. I cleared the paper jam but can not get the light to stop and so it wont print. I have shut it off...
You can also try:
Apr 09, 2009 | Office Equipment & Supplies
Lexmark z25 printer light keeps blinking, will not print
Have you used this printer before? Is it new? The flashing green light means that the ink cartridge needs to be replaced. Make sure you have the ink cartridge in correctly and seated down completely. Otherwise, it may be a defective ink cartridge.
Mar 29, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
iskandarsugandi@yahoo.com
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Put in new ink cartridges in flashing light on the ink symbol and large E illuminated on printer
Try to refresh the printer
Or it doesnot work
try to reinstall the printer driver
Nov 13, 2008 | HP Office Equipment & Supplies
Catridge won't go to right position
Please follow the steps below to replace one or more cartridges.
NOTE: It is necessary to have all four ink cartridges installed and supplied with ink in order for the unit to function properly. The unit will be in an OFFLINE state if the any of the cartridges are expended. This is a protection feature of the unit, to prevent air from being pumped through the print head.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
**NOTE** To avoid damaging the unit, NEVER move the print head by hand.
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the
CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
Jun 12, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Changing the ink cartridge in Epson Stylus CX4200
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
May 15, 2008 | Epson Stylus CX4200 All-In-One InkJet...
All lights flashing
may be need service i have software for new epsons and old epsons contact me
Mar 30, 2008 | Epson Stylus RX425 Multifunction...
HP PSC 1410 All-In-One InkJet Printer Logo
174 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
