Question about Countryman Isomax HS Microphone
Can I put a xlr conector on a contrymam isomax mic ? What the pinout? Do I need put a resistance?
    Scholar:
  • 52 Answers
Hello. You can put an XLR plug on but you will have to have a phantom power supply for the mic. If you are plugging into a mixer , check to see if it has phantom power (a switch marked as such) and turn it on . Mics that need it like the HS will use it, mics that don't will ignore it. Without phantom power though the mic will not function.
Standard mic wiring is pin 1 GRD, Pin 2 Hot, Pin3 Neutral. No resistance is needed. Good Luck
Posted on Mar 23, 2011
How do I troubleshoot this mic?
Check the coil resistance, first on the capsule (unscrew the front screen) and then on the No. 2 and 3 pins on the XLR.
Now you know....
Probably your membrane coil went away.
That happens, so sorry, but check...
Peace-
Apr 17, 2016 | Peavey Audio Players & Recorders
No sound from mxl 990 condenser mic
From the Micropower PS400 product description it states:
"routes the microphone signal to a mixer or a microphone preamplifier."
• these is just a phantom power supply.
One reason your former setup is OK , is that
tascam m-50 is a mixer preamplifier.
• phantom power supply is just a part of the mic preamp of the mixer
to power up your mxl 990 condenser mic
• What you may need is something like these:
X2u XLR to USB Signal Adapter
Sep 29, 2012 | MXL 990 Professional Microphone
Need xlr pin diagram for MArshall v67I 3 pin mic. I am wiring my own cable and need to know what is what. Thanks, Jim
Darn, OK.
First, check with a multimeter and find which pins give you around 200 Ohms.
Next, touch one tip to the chassis and find the GROUN pin on the cable (lowest resistance)
The GROUND goes to pin 1 on XLR
The other two go to pins 2 and 3.
Sorry I can't tell you which goes to which (phase), but you can check
putting it next to another one and seeing if they sum or cancel.
If cancel, invert them two...
Peace-
Feb 03, 2011 | Marshall MXL V67i Microphone
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
Shure 87a no sound
Send the mic to Shure for repairs. www.shure.com/service
Sep 12, 2009 | Shure Beta 87A Professional Microphone
Installation
First you must determine if the mic's output from the receiver is low or high impedence. Tip: high imp. is usually a 1/4" jack , low imp. is a 3 pin XLR Conector. It also depends on your amplifier input jacks.But really you should connect the mic to a mixing console and then connect the console to the amp.But you could connect a high imp. mic via a 1/4" to 1/4",cable into the 1/4" jack on your guitar amp.
Mar 23, 2009 | Naxa Electronics NX984 Professional...
Shure beta 58
Benimur, you are correct, except that the Beta 58 is a condenser mic that required phantom power. In that case all 3 lines are used. Included below are the connections.
Dan
Sep 11, 2008 | Shure Beta 58A Professional Microphone
Does the SE Mini use a standard cable or is there a special cable needed for use in an amp or computer?
you'll need an xlr (male) to xlr (female) to use the microphone with 48v phantom power (from a preamp). phantom power dosnt work with an xlr to jack, only both xlr.
Apr 22, 2008 | SE Electronics SE MINI Microphone
Won't stay in place
the rubber sleve on these mics are made to be adjustable...and you can shape and form these into the best shape for your ear. try forming it into a shape that is more snug around your ear, maybe put it on and then squeeze it a little tighter. Sometimes the arch in the mic. gets places too low and needs to be formed up a little further.
Hope this at least gives you some things to try.
Sep 28, 2007 | Countryman ISOMAX E6i (E6IOW5BC2)...
Need of codes....
Hi I hope this will help http://www.dvcentral.org/tricks.html Tricks 4 XLR ins: Get the Canon MA-300 adapter and get yourself 4 XLR inputs. Perfect for a couple of wireless lavs, a boom, and another mic. Sure, it's less data for the audio channels, but it's plenty for voice recording. Sure, you can't digitize audio 3&4 easily, but it is possible, and it's just so darn useful to have four audio channels in the field. (Also, you can easily mount the wireless lav receivers right on the back of the camera.) Using the Canon on-camera mic via an XLR input: Say you're using a single boom mic, inputting via XLR 1. You've got XLR 2 doing nothing, and the on-camera mic doing nothing. Seems a waste. Well, all you need to do is adapt the on-camera mic to input through XLR 2. A short female-mini-to-male-XLR adapter will do for the audio signal, but the mic needs power. Simple, just get a short micro-mini extender cable, plug one end on to the mic, and the other into where the mic's connector would normally plug, on the camera's handle. Make sure the mic is switched to stereo, and voila, you have a second XLR mic. Monitoring in the field: Though many people told me it couldn't, the XL H1 downconverts to NTSC on the fly during recording, so you can plug a little monitor or deck into the video and audio out jacks and have yourself a video tap. Perfect for the director who wants to see what's going on through the camera. I used a little DV camera, and recorded it all so we could have a playback tape if needed. Very useful. (Note that the output NTSC is anamorphic, stretching the 16:9 image over the whole 4:3 frame. A monitor with a 16:9 switch is useful, or something that automatically adapts, such as what I used, a Sony PD-100 DVCAM camera.) Native slow motion: In a 24F project, shoot 30F and use Cinema Tools to slow down the footage to 24fps for a slight slow motion effect. Use 1/60 shutter speed for a standard look, or 1/30 for a slightly dreamier feel. Good Luck.
Sep 15, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
88 people viewed this question
Top Countryman Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Countryman Audio Player and Recorder Expert? Answer questions, earn points and help others
