Is it the main PCB board if so where can get one ty
  • 30 Answers
See if you can find the board here: http://www.interliquidparts.com/products-page/lcd/
Posted on Mar 17, 2011
How to fix a E9F error code of EWF1282 FRONT LOADER ELECTROLUX WASING MACHINE
E9F - Communication error between main PCB and Inverter board.
Could be:
  • Faulty wiring between main PCB and Inverter;
  • Inverter PCB faulty;
  • Main PCB faulty
Dado
Feb 28, 2016 | Electrolux Washing Machines
I HAVE A JENNAIR JS42CSDBDA FRIDGE THAT WENT DEAD NO POWER,NO LIGHTS CHECKED OUTLET AND FOUND POWER GOING TO FRIDGE BUT NOTHING. IT ACTS AS IF IT'S NOT EVEN PLUGGED IN.
No one turned off your power switch up above the refrigerator, I trust. So, either your power supply or your main PCB is blown. Check the fuse on the main PCB (up on top of your refrigerator in the compressor area). The fuse will be right next to that round, black piezo electric speaker on the main PCB board as shown here:
If that's not it, then check to see if your power supply board is supplying power by measuring the voltage on JP11 of the Main PCB. You should see 26 vdc between pin 3 (GND) and pin 1. And, you should see 12 vdc between pin 3 (GND) and pin 2.
If you don't get those voltages, then you might have a bad Power Supply Board. It looks like this:
Also of note, your 120vac going into the Main PCB board comes in on JP8, pin 1 (WHT) and pin 5 (RED).
I don't know if you will be able to see the larger image of the schematic, or if Fixya will just give you a thumbnail, but I'll try to post it here, anyway:
Well, good luck and let me know if you need any more assistance.
Oct 20, 2014 | Jenn-Air Refrigerators
Hello experts, witch main pcb is built into Canon Powershot D10? Canon-repair told me main pcb and jack pcb assy have to be changed after corrosion. i found jack pcb assy for change but i couldn`t find...
Your camera is run by a program that is loaded onto the main board when it is replaced. This program is not available (Canon considers it propriety information) so the only way you could replace the main board would be with a used one (that already has the program installed) pulled from a salvage camera. However, this program also has color correction information and dead pixel information etc for the image sensor in the camera. You would have to replace the sensor from the salvage at the same time so that it matches. It would be cheaper to buy a used camera - check Ebay.
Sep 02, 2013 | Canon Cameras
WHATS A PCB?
pcb is a power control board
May 17, 2012 | Washing Machines
LED LCD. Is the Main PCB bad?
I'd try the main, its about all that is left if the rails are all good on the power board.
Feb 04, 2018 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
CANON IR 1600 COPIER IT WENT OFF AFTER REPLACING POWER SUPPLY BOARD STIL COULD NOT WORK UNTIL I HAD TO REPLACE MAIN BOARD THEN IT CAME ON BUT WITH ERR CODE 354 I HAVE TRYED TO CLEAR IT ALL IN VAIN
the counter PCB or the serial no. PCB is not matching.Did u got the main board with the counter pcb attached.if not then u have to get the counter pcb of the same board or attach the serial no pcb and the counter pcb of the old board . u will get it if ur a rep .if not then u have to consult one
Jun 28, 2011 | Canon iR 2016i Black and White Copier
Getting a problem with a canon ir 6000 error code E 350-001
ji guys I need ur help, I've error code on cannon ir6000 "000732-0001", please help me send to my mail ahlalrasyid@yahoo.com. ty
Feb 16, 2010 | Canon Office Equipment & Supplies
ZWD1471 S E90 ERROR MESSAGE WHAT DOSE IT MEAN ?
E90 means Communication error between user interface and main board. Verify the connector between the main board and user interface board by plugging and unplugging the connector few times on both sides... if still the same fault then main pcb board is replaced 1st tried then the user control pcb is still the same...
Jan 04, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
I have error 29 on my 210c
!!!! Magenta ink error !!!!
The ink has run out or the ink cartridge is not set into place.
26: Black ink
27: Yellow ink
28: Cyan ink
29: Magenta ink
1. Reload ink cartridges, referring to the Owner's Manual.
2. Ink cartridge PCB defective Replace the ink refill ASSY.
3. Cannot detect ink cartridges.Main PCB defective Replace the main PCB.
I know your machine was not originally showing signs of main board fault or Ink supply issues, although main board can be killed by incorrect use of maintence mode.
Nov 14, 2007 | Brother MFC 210C All-In-One InkJet Printer
Televison & Video Logo
Top Televison & Video Experts
