What canI do about a sticky volume button on a toshiba led tv?
  • 4,889 Answers
Is this the button on the tv or the remote that you are talking about?
Posted on Mar 17, 2011
  • 1 more comment
  • eagle338
    eagle338 Mar 17, 2011
    On the tv the buttons are attached to a board known as input control board. It is the small board that you can locate at the lower left section of the tv once you remove the back cover. The board is inexpensive and only has a few connectors on it. Would you like to replace it yourself or is the set under warranty?
  • eagle338
    Ok. I found 2 different versions of the board and I would like to be sure that you get the correct one. So remove the back cover locate the board and get me the part number off the board so that I can compare and link you to the correct one.
  • eagle338
    No problem. Do it when you are free and let me know
Why does the volume on my Magnavox TV immmediately go to 0 as soon as I turn it on, and then after I turn it up and take my hand off the volume button?
it would appear Volume down button is either shorted or something is constantly pushing on it forcing the volume to go down. You could try to press on the down button and see if it feels like it pushes back a little bit. The most common thing is that it gets sticky from grimy, sticky fingers, try to un-stick it using some alcohol on a cotton swab. Other that the only way to fix this is to take the tv apart and figure out the button problem that way!
Good Luck!
Rich Lilja
Apr 02, 2015 | Funai Magnavox 32md301b/f7 32-inch 720p Tv...
TOSHIBA LED 46L5200U TV where picture stoped working and the volume is working
Check and replace its back-light inverter board. Contact any service technician. Gopakumar Gopalan Google
Feb 24, 2014 | Toshiba Televison & Video
Volume control not working properly on my remote control, all other buttons are fine, do I need a new remote or canI get it repaired if so where? Onkyo HT550 unit
Did u tried disassemble remote control and clean PCB with clean cloth? Also u can take rubber part of remote and wash it carefully in soaped water . While u have it disassembled check for bad solder connections at IR LED on remote controller . Regards .
Oct 01, 2012 | Onkyo SKS-HT500 System
How can I program my remote to a Toshiba 60"?
Here are the codes for you Toshiba TV: 631, 617, 635, 744, 615, 667, 590, or 688.
I have provide instructions on how to program your remote to your TV.
  • Remotes: Basic (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press #. Note: The LED will flash three times.
    5. Test functionality with the TV.
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 18, 2011 | DISH Network 135899 Remote Control
The volume on the TV keeps going down by itself. What should I do?
Dont know what tv you have but. You can remove the batteries from remote and if volume still goes down you ruled out the remote as the problem.. Or just take remote to another room. If the problem still exists then Im guessing either a sticky button on the tv volume down or as I have seen to many times.. People clean their tvs with windex or some cleaner and it drips down into the tv messing up the control buttons. Hopefully its just a sticky button..
Oct 19, 2010 | Toshiba CT-90157 Remote Control
I want to set the remote to change volume on TV,we can change the channels using the Time Warner remote but cannot change the volume using thesame remote, we have to change the volume on the Toshiba...
I am not familiar with the Time Warner remote, but Tivo remotes require pressing "tv power" and the "Tivo" button at the same time to program them.
Maybe you are pressing one a little ahead of the other.
Oct 18, 2009 | Toshiba 26 26AV502R 26 in. LCD HDTV
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
The volume control won't work on my sky remote
for a toshiba tv,
press tv
press and hold select and red until the led blinks twice
type in 0 1 5 6
press the power button on the remote
If the tv turns off press select and hey presto you're done, if the tv doesn't turn off, press tv then press the power button and keep doing this until the tv turns off. When the tv turns off press select.
Nov 17, 2008 | Universal Remote Control Remote Control
Volume automatic decreases. Have no control of volume
Ensure nothing sticky has been spilled on the TV or the remote, causing the volume down button to stick. Remove batteries from remote to rule it out. Carefully inspect TV volume control for a sticking button. If you find it is sticking, get electrical contact cleaner from Radio Shack and spray the button. Ensure TV is unplugged first.
Oct 27, 2008 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
