Simple really the machine will cycle normally when it has no washing load in it but if you put even one item of cothing in it the belt will turn but the drum doesnt
    Brigadier General:
  • 6,277 Answers
I am assuming this is a front loader as you have not mentioned the make and model ;-0)
Your'e right, simple! This sounds very much like the belt is slipping. Don't be tempted to try tightening the old belt- purchase a replacement!
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
Good luck,
John C
Posted on Mar 17, 2011
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
Whirlpool Thin Twin model LTE5243DQ2 The washer will pump the water out but it wont spin unless i open the machine and rearrange the load. Then it spins but sounds like it's working very hard to do so
I'm not familiar with your model but on the surface it sounds like the belt is loose. If the load is not really well-balanced, a loose belt can't move the drum and when the load is balanced the motor turns really fast because the belt is slipping. Tightening or replacing the belt is fairly simple with normal tools and there are plenty of pages/videos out there on how to do it. Hope this helps! Good luck!
Apr 05, 2014 | Whirlpool LTE5243D Top Load Stacked...
My Defy Automaid DAW285 only works when you put in a small load of washing
It seems that the "start" winding of the motor is defective or the capacitor is defective
Peet
Nov 15, 2011 | Washing Machines
My washer is leval but continues to display ul code when spin cycle starts
UL does not mean the washing machine unit itself is unlevel, it means the load cannot be balance, possibly washing too small a load that the machine cannot distribute in drum evenly ( happens alot when only one or two items being washed), could be poor pump out (check filters if accessible) the machine tries to start spin with excess water or maybe it is a mixed load, lots of small items and maybe one or two large items that hinder the distribution. My machine is very temperamental when I do the sheets, because they get tangled during the wash part of the cycle and then the machine cannot get them balanced to spin. I sometime have to manual move the item about and then put it to the spin only cycle.Hope this helps
Oct 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
My GE profile WPDH8800J doesn't hit high speed
Your belt may be slipping and not spinning the drum to full speed to rid most of the water in clothes.
Sep 09, 2017 | General Electric WPDH8800J Front Load...
At the end of every possible cycle the cothes are still wet. What is the problem?
The problem is that your washing machine uses water to wash your clothes.  Have you tried washing them with air or maybe rocks?
I hope being a smartass helped!
Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Loud squeling noise during wash cycle
you have a weak or broken spring on the motor or the belt has stretched
Apr 09, 2009 | Washing Machines
Burning rubber smell
Even though manufacturers' love to advertise it, I personally would not load "too many items", as it may cause excessive normal ware and tear on your machine parts, motor, belt, etc.
Yes; the smell can be the belt and possibly your motor as well. The motor may be spinning, but the weight may be too much when the belt is engaging to rotate the drum. I would be careful not to burn the motor (About $120 - part only)
You should be able to access and inspect the drive-belt in the rear of the machine by removing an access panel (back of washer).
To replace the belt if fairly simple. Remove and re-install by wedging a long screw driver in between the belt and metal pulley (circular), while simultaneously rotating the pulley.
You may be required to make a belt repair if you start to have problems with your "washer not spinning" or "making a noise/not spinning"
Jan 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
