Question about Cisco 861 Router
Port forwarding not working on router cisco 861w. ROUTER nat DHCP IS WORKING. I have used this command to add portforwarding: ip nat inside source static tcp 192.168.0.222 80 interface FastEthernet4 80 I have created an extended ACL with the following command: ip acces-list extended pfwd-acl please any help will be greatefully appreciated, Mariana I have added a permision like: permit ip any host 192.168.0.222
  • 902 Answers
Make sure you enable both tcp and udp port fowarding . worst case comes to worse reset it back to factory settings. or upgrade the firmware (i couldnt port foward until i upgraded my firmware on my wrt model)
Posted on Mar 17, 2011
Change NAT type 3 to 1 or 2
Not sure of the game console, but many routers have port forwarding, NAT config, or even DMZ bypass. Instead of getting all techy try this site. It has everything, and with pics.
Direct link for COD BO for Cisco Linksys-E1550.
http://portforward.com/english/routers/port_forwarding/Cisco/Linksys-E1550/Call_of_Duty_-_Black_Ops.htm
Dec 08, 2012 | Computers & Internet
Hello. I need to change my NAT type on my Xbox 360 from moderate to open using a Westell Versalink 7500 router.
Hello
Your router does not have moderate or open nat options.
Options that it does have are Public Lan - nat type and Private Lan -nat type.
Your router also has a DMZ feature and port forwarding options.
User manual for your router is available at http://www22.verizon.com/ResidentialHelp/HighSpeed/Networking/User+Guides/User+Guides.htm
To get your xbox live working properly, you can try using the public nat type, if that does not solve the problem, turn on DMZ for the address of the Xbox360. Now if that still does not solve the problem, then you would need to set up port forwarding for all the ports that xbox live uses.
I would personally recommend that you enable port forwarding for the required ports.
Ports that need to be open are
TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Together with the user manual and xbox360 portforwarding guides that are available here http://portforward.com/english/applications/port_forwarding/Xbox_Live_360/Xbox_Live_360index.htm
You will be able to get it working.
But since that is a lot of information for anyone that has not used port forwarding before I'll write down step by step how to get started.
First get on your computer, You need to connect to the routers own configuration page. By default this is http://192.168.1.1
So, open your internet browser and write HTTP://192.168.1.1 and press enter.
Now you get a a user and password prompt. the username is admin and the password is password. all lower case.
Now on the top menu, click on Firewall settings.
Now select Port forwarding. more information and pictures on the user manual page 98 and forward. You need to create a new rule or rules that forward the above ports - allow them to be open to the internet for the xbox 360.
Looking at page 112. You would create a new port forwarding service, you need to add all the ports one by one. And the host device would be the IP address of the xbox.
Now the DMZ option will be simpler, that is on page 118. You just need to find the xbox ip address from its network options and put it there, and turn on the DMZ. That will allow all traffic for that machine.
Let me know how far you get. I'll help if you get stuck, sorry if this post is a bit unclear, this is a very small box to write in, I can't easily see everything I've already written here.
Sep 27, 2010 | Computers & Internet
Dhcp setup on a Cisco 2851 router
Let's look at how to configure basic DHCP on an IOS-based router. For this example, we'll start off with the default configuration on a Cisco 2611 router running IOS 12.2. (The configuration should be the same—or very similar—on all IOS-based routers).
To begin, connect the router's Ethernet port to a switch, and connect the switch to a laptop, which will serve as the DHCP client.
To configure Cisco IOS DHCP, follow these steps, which include sample commands:
1.Configure an IP address on the router's Ethernet port, and bring up the interface. (On an existing router, you would have already done this.)
Router(config)# interface ethernet0/0
Router(config-if)#ip address 1.1.1.1 255.0.0.0
Router(config-if)# no shutdown2.Create a DHCP IP address pool for the IP addresses you want to use.
Router(config)# ip dhcp pool mypool3.Specify the network and subnet for the addresses you want to use from the pool.
Router(dhcp-config)# network 1.1.1.0 /8 4.Specify the DNS domain name for the clients.
Router(dhcp-config)#domain-name mydomain.com5.Specify the primary and secondary DNS servers.
Router(dhcp-config)#dns-server 1.1.1.10 1.1.1.116.Specify the default router (i.e., default gateway).
Router(dhcp-config)#default-router 1.1.1.17.Specify the lease duration for the addresses you're using from the pool.
Router(dhcp-config)#lease 78.Exit Pool Configuration Mode.
Router(dhcp-config)#exit
I hope this is helpfull for you.
Thanks
Vikrant
Oct 26, 2009 | Computers & Internet
I would like to configure port fowarding on the Cisco 857 router using the http interface rather than via any coding. Is it possible and what do I need to do? In my scenario, the router must be configured...
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 24, 2009 | Cisco 857 Router (CISCO857K9)
Low id with dlink wbr 1310 usuing emule
Short answer? hmmmm
To successfully use port forwarding you must know the IP address of the computer on the INSIDE of your network BUT
your router is most likely using DHCP. This means your internal IP address isn't necessarily static. The "D" in DHCP is for dynamic.
First you need to ensure the the inside IP address of your machine isn't going to change. This can be accomplished 2 ways. 1) assign a static IP to your machine 2) Force specific DHCP IP address assignments by MAC (Hardware) address of your network port - this is the easiest way. Your router does NOT support this option (according to the manual) :-(
So #1 it is...
1) Your router defaults to allocate ALL inside address to DHCP - This will have to change. Alot of routers only use a subset of your internal range (eg: 192.168.0.100 - 192.168.0.150.) Yours will too!
Determine how many addresses you wish to reserve for DHCP (for a house 50 should be more than enough). Figure out the range (say 192.168.0.100 - 192.168.0.150.)
Also find out the DNS (Domain Name Servers) of your ISP, as you'll be needing them later.
Log into your router and go to Network settings / setup (pages 26 & 27 in the manual) make the changes and restart your router (and computer) you will now be using a DHCP address in the range you just specified! :-)
Now you will need to go to your network settings on your computer and change you r network setting from DHCP to manual. Enter a IP address such as 192.168.0.10, and your gateway (eg: 192.168.0.1) and your DNS server information that you got earlier.
Now restart your computer to make the changes take effect. We could do something from the command line but I'm trying to keep this short ;-)
If everything is working and you can use the web, check email etc. and your network settings show you are using the manual address you assigned. If you don't have internet review your earlier work (especially the DNS servers) you can always change your computer to use DHCP until your get it resolved.
Congrats most of the tough work is done!
Now you will be using the port forwarding option (Page 28 in your manual) to assign which incoming ports to map to your IP address
Rather than regurgitate other peoples work... see:
http://www.portforward.com/english/routers/port_forwarding/Dlink/WBR-1310/eMule.htm
I hope this was helpful!
Feb 16, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Router no connecting to the internet
You need to configure NAT on the router to permit the entire LAN to access internet
Example.
LAN Segnment is 192.168.1.0/24
1. Create an access-list to identify the local segment
2. Configure the Nat interfaces properly (NAT-INSIDE, NAT-OUTSIDE)
3. do the NAT configuration
i.e ip nat inside source list (ACLNUMBER) .....
Dec 08, 2008 | Computers & Internet
Changing nat on xbox live
I had this issue, and solved it recently. Everyone on the internet will tell you to forward ports, or disable the NAT setting, but these never worked for me. As I was about to give up and buy a new router, as a last resort I decided to call tech support. In about 3 minutes they fixed my problem, and it is much easier then port forwarding.
-First go into your 360 network settings and find its mac address.
-In the router settings move to the LAN tab.
-Then go to "dhcp leases".
-Under "current dhcp leases" your 360 should be listed (match the mac address)
-Make a note of the IP address listed for the 360, then delete that lease.
-Now Reserve a new IP address, enter in the MAC address and IP address you wrote down for the 360.
-Check the bypass firewall option (and give it a name if you want) and then add the new entry.
-On the same page, move up to "DMZ Host" find your new entry and click "apply"
-Click the option to reboot your SBG900, then restart your 360, and the NAT should be open.
I hope this helps, if I described it correctly it should be much easier then port forwarding, and more importantly, it should work.
Sep 14, 2008 | Arris SURFboard SBG900 Wireless Router...
3com router dmz doesnt allow to ssh to the asa
undo the dmz and forward the ports 22 for ssh and any other services you need to the cisco. Ok dmz is not good... 3com calls port forwarders virtual servers just add what you need there... hope that helps.
Mar 20, 2008 | 3Com OfficeConnect Router
RCA Modem DCM315R
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
Feb 25, 2008 | RCA Cable Modem DCM315R (11603540)
Nat
try portforward.com if that doesnt wark try www.techieguides .com
Feb 07, 2008 | NetGear WGR614 Wireless Router
Cisco 861  Router Logo
473 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
