Question about Nikon COOLPIX S570 Digital Camera
How do I delete all pictures at once. I always have to delete each picture one at a time.
    Brigadier General:
  • 11,967 Answers
The easiest way to delete all the pics at once is to go into the camera menu and find "format". Follow the on-screen instructions.
Posted on Mar 17, 2011
How do I delete large numbers of pictures at one time
Method #1 Click and drag.
Click and hold the left mouse button and drag the box around all the pictures you want to delete. This will select any it covers. Right click and click Delete.
Method #2 Shift select
Click on first picture you want to delete, hold down shift, click on last picture you want to delete. This will select any between them. You can also hold shift and press the down arrow to select them one at a time. Then right click and click Delete.
Method #3 Ctrl click
Use this if you only want to delete certain pictures, as you have more control. Select first picture you want to delete, then hold down Ctrl. While holding Ctrl continue to click pictures you want to delete. It will select them as you click them. In this way you can select many non-sequential files. Again, once you have them selected, right click and delete.
***These methods work to select multiple files, so can also be used to move or copy multiple files as well. It's easy one you've done it a time or two.
Mar 26, 2015 | Toshiba Computers & Internet
Can i delete all pictures at once
connect it with the computer ..
open the folder with the pic..pres CTLR+A and press delete key
Jul 29, 2012 | Vtech Kidizoom Digital Camera
Delete many pictures from computer
Select the first picture you want to delete by clicking on it once to highlight it and make it turn blue, then go to the last picture you want to delete and and Press and Hold the Shift Key then Click it once to Highlight all the pictures between the first and last your selected. Right Click on either one of the Highlighted Pictures and select DELETE. All the pictures that were highlighted will be deleted.
May 09, 2012 | Computers & Internet
How can i delete videos and pictures?
To delete pictures in your camera at once, you can delete it using the computer. Plug your camera to your computer using the USB cable. Once your camera being detected go to My Computer, double click the drive of your camera, " I think it is drive E or drive F". Now your are opened the drive you can see all your pictures. To delete all the pictures, click one picture. Press control A at once int the keyboard, so all pictures are highlighted, press delete and Yes. All the pictures are deleted..
thanks.
Apr 07, 2011 | Cameras
I accidentally set the date imprint on my camera. I'm wondering if there is a way to get the date taken off of the front of the pictures I have already taken.
From the manual, "Imprinted dates form a permanent part of image data and cannot be deleted."
The best you can do it to make sure that Date Imprint is turned off for future pictures. The camera still records date/time info into each picture file, and many printing programs can imprint that onto the picture at printing time. The good ones print it on the back, so as not to interfere with the image. Either way, you can always add the date to the picture, but you can't remove it once it's there.
May 14, 2010 | Nikon COOLPIX S51 Digital Camera
Deleting pictuers
The best thing that you can do here if you want to delete all the data/pictures from the camera at once yu can simply use the format option from your camera menu... and that will delete all the pictures at once...
Sep 12, 2009 | Cameras
Deleting images
Generally your camera will have a main menu, which lists this as an option.
Look for a menu button on your digital camera. While the camera is on, press this button, and cycle through the options that appear, watching for a listing which says something like "Erase all".
Usually there will be another button or set of buttons that have arrows on them, and let you move up and down among the listed options. Press the up or down button (or the right/left button, whichever applies to your camera), until the "Erase all" option is highlighted.
There should also be a button on your camera that says something like "Ok" or "Function Set"; no matter what it's called, the important thing is that it is NOT one of the buttons which either opens the menu listings (the one I'm describing as the "menu" button, regardless of what your camera calls it), or moves between menu items (the up/down/left/right buttons). Once you have found the menu item for "Erase all", and have highlighted it, press this button.
You will probably get a message asking you to verify your choice, since once the photos are deleted from your camera, you won't be able to retrieve them, so most cameras will ask you to confirm any erasing you do, whether it's just one picture, or all the pictures in your camera's memory/storage. You confirm the deletion by pressing the same button that you used to start the deletion process.
So, to recap:
1) Turn the camera on.
2) Find and press the "Menu" button.
3) Find and press the arrow/next button until you see a menu item saying something like "Erase all".
4) Find and press the "OK" button -- or whatever button will get the camera to accept the menu item selection you've made.
5) If the camera asks you to confirm your choice, use the arrow/direction keys to highlight the "Yes" or "OK" option in the confirmation window.
6) Press the same button you used to start the process ("OK" or "Function Set"), one more time to confirm your choice.
7) The camera should now delete all of the photos in its memory.
WARNING: DO NOT DELETE YOUR PHOTOS UNTIL YOU'VE DOWNLOADED THEM, UNLESS YOU ARE ABSOLUTELY SURE THAT YOU'LL NEVER WANT THEM. It is always better to have an extra backup of your pictures than to permanently lose something you can't replace.
If anyone else has used the camera, it's best to check with them to make sure that they've downloaded their pictures off of the camera, before doing a full delete of all pictures on the camera.
Most cameras will also let you individually delete pictures that came out badly, or where you accidentally took a picture you didn't mean to take. If you're not sure what else is in the camera's memory, it's always wisest to use this method, instead of deleting all the pictures at once.
Apr 02, 2009 | Cameras
Delete all pictures at one time
to delete all the pictures at the same time all you have to do is to press the button that gets up you photos and then open up one of the menus and go delete pictures delete all then yes. to set the date make sure you are on the normal screen so you can see what you are going to take a picture of and then go onto the settings click date and time and you can then set the date and the time, once you have put the date and time in press ok and it is done. you can then go off the menu if needed.
Feb 26, 2009 | Vivitar ViviCam 4345 Digital Camera
XD card picture error
Try to use a card reader instead. They are only a few dollars. I use one all the time, and hardly ever will use the camera on different models I have.
Never delete from the PC to the camera. It can cause corruption. Once corrupted, you may lose all pictures on the card.
Always delete from the camera, unless you will format the card anyway.
Use the camera and try to delete the bad picture from the camera. this may fix the problem, if not, try to read from another camera or a card reader...don't ever delete from another camera or the card reader.
The last is not good, and that means to format the card, and you will lose all which is on the card.
You may try to copy to internal memory.
One more thing... take out the card. reset all in the camera menu. Then reset all the things you like. Put the card in and try to read each picture in play mode only. If one picture is very slow, delete it. This may take some time as corrupted files may read slowly. then try again.
Sep 01, 2008 | AOpen Olympus 64Mb xD-Picture Card (AX4C...
System Error
My experience in this issue is that you should never put too much trust in an SD card :-/ It seems to me that all cards are prone to fail once in a while, and my best advice is to keep spare ones handy. A dedicated SD card reader is a good thing, too...
Sep 01, 2006 | Konica Minolta DiMAGE Z5 Digital Camera
Nikon COOLPIX S570 Digital Camera Logo
349 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
