Question about Toshiba REGZA 47HL167 TV
Where is CableClear Qam-Tuner Activation - want to activate Westinghouse LD2657DF?
Activate QAM Tuner
QAM tuner fault. Contact any service technician to replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 28, 2014 | Westinghouse LD-3235 32in LED 720p Flat...
How do I get to the screen to enter the tuner activation code in an Element TV
Open up the menu. Press 0000. It will open another menu. Select others. Select Other Settings. Select QAM. Select On. Then re run the autoscan and you'll get the digital channels.
Work for a technical troubleshooting team and deal with element and westinghouse television a lot.
Nov 29, 2013 | Element Electronics Televison & Video
Westinghouse Model vr3225 qam activation code wont work
CALL WESTINGHOUSE CUSTOMER SERVICE AT 1-800-701-0680. THEY WILL GIVE YOU A CODE. HAVE MODEL NUMBER, SERIAL NUMBER.
Jun 13, 2011 | Televison & Video
My Brand New 40" westing
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals:
http://en.wikipedia.org/wiki/QAM_(television)
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
Dec 30, 2010 | Westinghouse SK-40H520S 40 in. LCD TV
Obtain Tuner Activation Code Serial Number: 6200Y04102884
Westinghouse.com/support then go down and click tuner activation put your serial number in to your right and hit enter and you got a code
Dec 05, 2010 | Westinghouse Electric LD-2655VX 26 in. TV
I just bought a LD-325 Series TV. I need to get a tuner activation code. can you help me
Navigate to the following URL: http://wdsupport.net/WDEOnlineService/tunercode.aspx . Then provide your model and the serial number provided in the Setup Wizard's "Obtain Tuner Activation Code" window as well as the type of input (OTA or QAM). Then when prompted by the Setup Wizard, input the activation code using your HDTV's remote control and press enter. Your channel scan will begin. Alternatively you can call 1-800-701-0680 and navigate the voice mail system.
The website can either display the code or send you a copy by e-mail. I strongly suggest that you print out the code and save it. Keep it with your manual and warranty documents if you can keep everything together. Then if you have to reset the TV to the factory settings, you will be able to reuse the code.
I hope this helps.
(for more information see page 22 in the manual. For a digital version, go here: http://westinghousedigital.com/products/led/32-40/ld325/ . The link for the User's Manual is on the left side of the page.)
Nov 14, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Toshiba REGZA 47HL167 TV Logo
169 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
