Question about Target Saws
My saw has become very loud when i turn it on. Sounds like there is no lubrication on the moving parts. The saw is a 10" target, it use to be rental. Cuts fine just runs loud. Any ideas?
stug_57u
  • 99 Answers
SOURCE: My table saw will turn on, but sounds very loud
Possibly bearing wear, or the blade rubbing against the guard/housing. Unplug the saw and spin the blade slowly by hand, if it feels notchy then I would suggest bearing wear. if it only seems to feel notchy in places then it could also be damaged gears.
Posted on Nov 01, 2008
james3751
  • 614 Answers
SOURCE: outdoor unit fan making noise when running sounds
Bearing in fan going out. Let it run till it quits or call service tech to change motor. Fix cost about 250 to 300 dollars. russ
Posted on Jul 22, 2009
Dolfoff
  • 148 Answers
SOURCE: I am looking for a repair manual for my 10" ryobi
Takes a bit of navigating to reach it, but I'll try to help you get there.
Start at this page HERE.
Click "Repair Parts Catalogue"
Click "I HAVE READ THIS PAGE & AGREE TO THE TERMS PROVIDED".
Click the "Model" tab located at top left of page.
In the box labeled "Model Name/Number" type in the following without the brackets [TS1342] and click the "Search" button to the right.
One (1) Result should be found. To the right is a list of two available drawings.
The one you seek is "General Assembly"
Hope this helps,
Dolf-
Posted on Oct 15, 2009
heatman101
  • 43501 Answers
SOURCE: The dryer squeals extremely loud when drying. It
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 28, 2010
  • 22 Answers
SOURCE: My Grundfos MQ3-35 has become
The bearings fitted to this pump are lubricated for life - if the noise is bearing related they will need to be replaced. If the noise is not from the bearings you will need to establish the cause - possibilities are:
Cavitation (sounds like frozen peas inside the pump!) caused by restricted suction - check for blocked strainer etc.
Foreign matter in the pump....
Loose impellers
Sometimes a piece of wood or a large screwdriver used as a stethoscope can be very handy in determining where abouts in the pump the noise is coming from.
Given more specific information I can suggest the next course of action.
Good luck
Mike G
Posted on Sep 27, 2010
Makita LS 1000 miter bed does not turn freely; probably jammed up with saw dust. What is the best approach to cleaning the rotating bed?
PDF]TECHNICAL INFORMATION - Makita
www.makita.nl/images/files/onderdelen/nl/LS1020-TE.pdf MAKITA 255mm(10") Miter saw. Models No. Description. New Tool ... Optional accessories. The main specifications are common with #LS1000. Saw blade:.Missing: bed
Jul 22, 2015 | Makita Saws
The ZE5 elliptical has developed a loud annoying repetitive squeak. Any suggestions to get rid of that?
You could try lubricating the moving parts. Sometimes the bearings and the connecting parts can become dry. If lubing does not work, it may simply be time to replace a bearing or bushing.
Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
Jul 15, 2012 | Precor EFX 546i Elliptical Version 4
Icemaker making noise
check that there isn't any ice stuck inside the icemaker teeth.
Apr 24, 2012 | Whirlpool Ice maker 4317943
I have a small two-door whirlpool fridge which is the noisest fridge I have owned. Its a loud humming noise when it "clicks" on.
This sounds like the compressor is not healthy. The moving parts inside the compressor have become "tight" causing too much friction in the moving parts which you hear as a humming sound. This will gradually get worse untill the compressor completely fails.
A new compressor plus associated parts and labour will probably cost $550. It may be worth looking for a new fridge?
Mar 24, 2011 | Refrigerators
I have a Craftsman 10" 1/3 hp band saw, after
Looks like are the motor brushes.
Try open the motor and look for.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 23, 2010 | Craftsman Saws
My shower control valve has become hard to operate and squeaks when turned. It is only about 4 months old. Sounds like it need a lube job.
shut off the water. remove handle and unscrew the cover that holds the internal parts. inspect ball for wear. purchase some valve stem grease at the hardware store.lightly lubricate all moving parts. reassemble but only tighten it snugly. do not crossthread!
Sep 14, 2010 | Danze Home
Loud noise coming from ps3 after short while
sounds like youmay have something stuck in the fan or in another moving part you may want to take it apart and clean it.
Nov 29, 2009 | Audio Players & Recorders
The mirror on my D100 has suddenly become slow. It takes 2-3 secs to return. The exposures are good. What have I done please?
You will have to take it to a photograpic shop for fixing. Sounds like the moving parts are sticking. Had similar problem with old camera and all the rubber and lubricants turned sticky, causing slow movement.
Aug 05, 2009 | Nikon Cameras
Need Parts breakdown for this model on a Target brand Quickie Saw Model 12-65
fyi, target tile saws and felker tile saws are made by the same company, and you can find both of them on line. your best bet is to take your saw to a tile distributor that sells saws and they will get what you need , good luck
Jun 27, 2009 | Target Saws
Saws Logo
26 people viewed this question
Top Target Saws Experts
Tom Chichester
ray gallant
Are you a Target Saw Expert? Answer questions, earn points and help others
