Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster garage door opens and shuts but when it reaches the closed position on the floor of the garage, it automatically reverses and opens back up again.
  • 1 more comment
  • peppermint_a Sep 11, 2008
    One out of 3 times of closing the garage door it will open before it is in the fully closed position. Usually the second time it will close completely.
  • lmhngr Nov 07, 2008
    door goes all the way down untill it bottoms out, then goes back up. I have watched the limit switch and noticed that it will hit the limit switch and overtravel
  • yvey43 Nov 11, 2008
    I have the same probelm with the Liftmaster. The door will go up and down but will not stay in the down position. I have to manually close the door each time.
  • 476 Answers
Is there something jamming it travel of the door?
or does the travel distance of the door need adjusting?
How many remotes do you have?
do their batteries need a changing?
even with the power disconnected you should be able to close the door,
do this and check from there,
any of the switchs sticking down?
If it persists then call some one to fix it,
They are normally bullettproof if installed properly and servicing and lubracating them seems to be a good idea too,
some buildings shrink and contract more than others
Yours seem to be normal movement of the building structure.
winter and summer situtation.
check the adjustments on the travel,
Let me know the outcome thanks .....
Posted on Aug 02, 2008
Liftmaster 1265 closes and then immediately opens garage door. Pulling chain release does not release chain. Only way to keep door closed is power shut-off; performing very rapid return when reaches...
There are two possibilities here. First is if the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Second is if the door is reversing when it hits the floor. This is a problem with the door traveling too far in the down direction. Locate the 'down limit' located on the side of the motor unit and turn it a bit in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary.
To release the door with the rope - pull straight down and then pull the rope in the direction away from the door. This should lock the mechanism in the open position. To release this pull straight down and release.
Sep 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
When closing my garage door, the door reaches bottom and immediately reverses upward. Unfortunately, I don't have a manual...
If the door hits the floor, pauses for a couple of seconds and then reverses to the open position it is because it is traveling too far in the down direction. Locate the 'down limit' control on the side of the motor unit and turn this control in the opposite direction of the arrow printed on the cover. Some tweaking will be necessary.
Oct 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: Door goes down and when it reaches the bottom, it ...
If the door hits the garage floor and then reverses to the open position you need to adjust the 'down limit' which is on the side of the motor unit. Turn this control in the opposite direction of the arrow printed on the cover. Some tweaking will probably be necessary.
May 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
I cannot get the door to stay closed it cycles down the goes right back up after it reaches the floor
If the door reverses to the open position but the main light on the motor unit does not flash it is because the door is traveling too far. On the side of the motor unit you will find the 'down limit' control. Turn this just a tad in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary.
Jan 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opening when hitting close button
If the main light is flashing 10 times when the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit. Tweak them a little if necessary.
Sep 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cannot get chain drive to open or close position
What you need to do is adjust the down limit in the opposite direction of the arrow printed on the cover until the door stops before reaching the floor and the same with the up limit. Now that you have the door stopping in each direction you can tweak those adjustments until you have it right.
Aug 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR CLOSES TO THE FLOOR AND OPENS ALL THE
If the garage door is hitting the floor and reversing to the open position you need to adjust the 'down limit' which is on the side of the motor unit. Turn it in the opposite direction of the arrow printed on the cover. A little tweaking should get it just right.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens after closing
If the main light flashes 10 times when the door reverses it is a door sensor problem but if the door is hitting the floor and reversing and the main light is not flashing then the door is closing too far and the safety thinks it has hit something. On the side of the motor unit you will find 2 controls. One of these is the 'down limit'. Turn this in the opposite direction of the arrow printed on the cover until the door closes but does not reverse.
Jul 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door closes and then automatically opens half way
ADJUST THE DOWN LIMIT IT THINKS THERE IS AN OBSTRUCTION AND IS REVERSING LIKE IT SHOULD.
TURN THE LIMIT ABOUT 1/4 TURN AT A TIME.
HOPE THIS HELPS
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman door opener will not stay down
the sensor should shut door off whrn it reaches the closed position (adjust the shut off arm!
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
101 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
