Question about Numark TT200 Turntable
Right channel does not work. cables are all okay and amp is okay
    Scholar:
  • 72 Answers
Check the stylus or cartridge connections. Disconnect, then reconnect them to ensure good contact. You can swap them around to see if the problem follows a certain connection, and you can do the same to the RCA connections on the turntable.
If that is not the problem, you may want to try changing either the cartridge or stylus, or both of them out, if you have an older set. It may not be cheap to find turntable parts these days, however...
Posted on Mar 17, 2011
Audio coming through one channel only, was working a few hours earlier today. Could you advise on where to troubleshoot?? I've checked all cables which are okay, is there something I'm missing??
The good news is that you have one channel working. This means that since stereo amps are just two mono amps joined together, you can use the other channel as a guide to what the other should do. You don't need to look at the power supply as that is common to both channels. But you can troubleshoot by either taking voltage readings of the bad channel and comparing it with the same place on the good channel. Or you can do audio tests. By touching the bad an good channels with an insulated screwdriver (while the unit is on). The channel will buzz if is good. You can work either backwards or forwards from the output stages or the input sockets. Remember if it buzz's on the good channel, it should on the bad. You should be able to pinpoint the fault with this method.
Feb 05, 2016 | Yamaha P2500S Amplifier
Having problems with my highs amp
Use shielded cables.
BTW, how did you check the cables to determine that they are okay?
Nov 27, 2013 | Boss BV7334 3.2-Inch DVD/MP3 Receiver with...
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Right channel softer than left channel
reverse your cables at the amplifier if the sound changes if the sound changes the problem is not the amp. You can then take one wire and send the signal to one side of the amplifier if it is okay then take the exact same wire and try the other chanel. If there is no difference then take the other wire and repeat this should tell you if the sorce is okay and weather there is a bad cable. If there are more questions call 215-736-8055
Jan 15, 2010 | Marantz Audio Players & Recorders
I just purchased a GFA 5400 Amp and only 1 channel is working - Seller claims it worked when he Shipped. Is there a way to test the channel that doesn't work? Right Channel works Great!
Can I assume that you have input signals going to both channels and that you have SWITCHED the cables to make sure that both cables going to the power amp are actually sending signals to it?
That will rule out any cable / pre-amp problems.
After you have done that test, let me know.
Oct 26, 2009 | Adcom GFA-5400 2-Channel Amplifier
Only the right channel working on the amplifier
first check on all your cabling, speakers and input sources for loose/defective cables. can you tell me what brand is your amp and model? does it employs digital source switch or mecahnical switches only.
Aug 12, 2008 | Audio Players & Recorders
RCA cable use
You can plug into the left channel and it will feed both the left and right channels.
To confirm that it's feeding both channels, connect the speaker to one channel at a time. With signal fed into the left channel only, you should get sound when you connect the speaker to either channel.
Apr 18, 2008 | Sony XM-754HX Car Audio Amplifier
Help
I recommend you swap your left and right input cables to make sure it's not a source issue.
So from your headunit, plug the left channel output into your amps right input and your right channel output into your amps left input.
If the same side is still not working then disconnect both (or single speaker if it bridged) the speakers from the not working side at the amp. Connect the front and then the rear speakers individually and retest to see if one of them works.
If one does work then check the cabling and speaker connections on the one that doesn't. If it's shorting out anywhere it will stop your amp from powering that channel.
Failing that, it could just be that your amp has partly failed.
Feb 15, 2008 | Boss Riot 1500D Car Audio Amplifier
Numark TT200 Turntable Logo
143 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
