My sanyo tv will not show that the cable is there, even though it is hooked up. I tried adding/searching for channels but to no avail. What can I do to fix it?
    Scholar:
  • 167 Answers
HELLO. sounds like you need to go in the menu and find the setting for (air tv ant)/(cable tv ant), and reset.the setting to the cable ant setting. and see if that works "good luck"
Posted on Aug 02, 2008
Hooking up old Sanyo box tv with old magnavox vcr
You need a TV cable though ANY cable might work. But definitively the only way to connect a VCR co a TV is through the antena setting TV to channel 3 or 4.
Even if you can't see it, all old TV sets must have an antena input.
If you can't find it, call a TV repairman, should help to make a connection.
Jul 03, 2016 | Sanyo Televison & Video
TV is showing no signal. So I did a channel search and it stops and says unable to continue channel search due to error. I even unplugged - left for an hour and still does the same thing. I then hooked...
this could be a fault with the tv actual connector for the cable check the connection on the tv and try again or try a manual search to pick up one channel and then do a full scan also are you doing a scan to add channels to the current list as I would personally try and do a complete scan for all new channels list and see what happens
Sep 21, 2013 | Televison & Video
TV is not responding, turns on and off and does not show picture nor sound, does not move from channel 22-2
Couple of things.
  • Are you on an antenna or cable/sat box?
  • If you are on an antenna, the sub-channel of a local DTV station (22-2) was the only thing the digital receiver was able to pickup on the initial scan of channels.
  • If you are on an antenna, rescan for available channels.
  • If you are on a cable/sat box, and scanned for channels you probably picked up a like channel that is in the same bandwidth as 22-2. Probably not even a channel.
  • If you have a cable or satellite box, hook it up to one of the VIDEO channels using either a Composite AV cable (Yellow/Red/White) or a Component A/V Cable (RED/GREEN/BLUE with RED/WHITE for audio. If you are lucky enough to have HDMI for your source, use that.
  • Going forward, all of your changing channels will be from the SOURCE.
Mar 13, 2011 | Sanyo DP50747 50 in. Plasma TV
I have a 19'' older (approx 1999) Sharp tube TV that won't show the cable channels even though the cable is hooked up to the tv (the cable has been tested with another TV and works perfectly). There is no...
Even with the TV in the wrong mode, you should be able to see some channels lower than 12. Try that first and report here what you see. If you can get a few in that range (2-12) but nothing else, then the TV is in broadcast mode not cable. You will need to change it to cable mode to get the remaining channels. You should be able to locate a universal remote for $5 or so that will allow you to get into the menus.
Dan
Jun 18, 2009 | Sharp Televison & Video
Getting video form dav-dx to older sanyo TV with an S-video jack
Check what is input number of S-Video in TV and select that av input with TV remote.
Jan 23, 2009 | Sony Dream System DAVDX155 Theater System
No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
Sep 13, 2008 | Symphonic ST420FF 20" TV
CANT GET CABLE TV SIGNAL
When you hooked up the VCR or the Sat did you use patch cables? Sanyo had a lot of problems with tuners going bad. if you used patch cables you by pass the tuner so it will work
Apr 18, 2008 | Sanyo DS20425 20" TV
Digital tuner
Try this!
The manual states the TV is designed to search for channels.
turn the power on
then hit menu
(if it doesn't start searching for channels)
then hit channel up -let it run a complete channel search
hit menu again
hit channel up- let it run a second channel search
hit menu again after it finishes it's 2nd search cycle
if it doesn't go to a channel, hit the input button.
it worked for me!
hope it helps
Dec 08, 2007 | Sanyo Vizon LCD-15A2 Television
Sanyo ds325390
Intermittent loss of lower frequency channels ie Ch:36, higher channels ok
Dry joints in UHF tuner, resolder the PCB to casing earth connections inside tuner
Nov 23, 2007 | Sanyo AVM-3259S TV
Tv not working
Can you confirm that you didn't have any input signal? My wife once accidentally pressed the reset button on the remote and the TV was stuck in this state. I tried to hook up an antenna to the digital antenna input and let the TV search for a channel. It did find a station and got out of the channel search mode, which was all I needed. Then, I unhook the antenna and continued to enjoy my DVD movie. I didn't check the manual. So, it's possible that there is a better solution. My TV was working fine and I think it just has a terrible user interface. I'm not sure about your TV's condition, though.
Sep 17, 2007 | Sanyo DP26746 26 in. LCD Television
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
