File-system error on screen sean - Computers & Internet
  • 27,725 Answers
You could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer hope this helps
Posted on Mar 17, 2011
Which software could run a swf file?
Hi Joanne,
.SWF are flash files and require Flash player. Check if your PC has flash player installed.
Go through the link and check the details. Play SWF Files How to Open SWF Files
Regards,
Sean
May 18, 2014 | Adobe Systems Adobe Flash Player
My Finedrive 400 GPS displays the following error message Error Wrong file version Data File az bin 1=aze2 if I manage to get out of that screen the home screen comes on and if I select the...
i would download the latest firmware update from the makers website for your model ok then test it sound like corepted system file so redo it thx nick
Mar 17, 2008 | GPS
Tip
Blue Screen of Death
The stop error screen or bug check screen commonly called the blue screen of death (also known as a BSoD, bluescreen, or "blue screen of doom.
In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
Often, if you're lucky, the problem will resolve itself with a simple reboot and you may never have to worry about it again. More typically though, the BSOD is a harbinger of trouble and you may find yourself faced with another and another until you throw up your hands in frustration... but all is not lost.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This is if you are able to boot into safe mode (Press and hold the F8 key during boot up). This will ensure that all driver bugs are fixed and that all hardware has the correct driver. If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name. There is a neat program on the net that can fix this problem, it's called DriverFinder, you can get it here.
If this doesn't work or you can't think or find the corrupt driver you could use System Restore (If it is enabled) to go back to a time where you didn't get the error. To use the system restore utility, go to 'start/all programs/accessories/system tools/system restore.
Sometimes though the blue Screen of death can be caused by faulty or loose rame cards. Check that your RAM modules are inserted correctly and arn't clogged with dust.
After using the computer for a few months or years, the hard disk gets fragmented with temporary files, or fragmented files. This will result in slowness of the hard disk and may even result in a computer crash eventually. You can maintain your harddisk by defragmenting your hard disk and deleting unwanted files frequently.
If you see Fatal OE exceptions and VXD errors then it is due to the video card. To solve this reduce the video display resolution. You can do so by going to the control panel and display settings. Choose the correct screen resolution to match your monitor.
on Nov 14, 2010 | Computers & Internet
I am trying to update my adobe flash player pro but it says s that I am missing a msvcr110.dll file from windows I guess?
If you want to download and install the msvcr11.dll file, click on the link below.
Once the link is open, click on HOW TO INSTALL and click on Download Zip file. Later extract the file and execute the file to be installed.
Click here to Download the DLL File msvcr110 dll free download
Regards,
Sean
Mar 19, 2014 | Adobe Systems Adobe Flash Player
My Macbook shut down during reserve battery power and now won't reboot...it is stuck at the gray screen with the apple and the twirling icon.
You can turn off the machine by pressing and holding the Power button until the display switches off.
Then, try resetting your 'PRAM' using the following instructions;
http://support.apple.com/kb/HT1379
I've used every version of OS X from 10.0 through to 10.5.6 and sometimes you get this problem after an incremental upgrade. It usually just goes away after a couple of reboots.
Please let me know how you go.
Thanks,
Sean
Apr 14, 2009 | Apple MacBook Mac Notebook
Mac OS X will not re-start
Hi there DocMerengue,
When rebooting at the bong press and hold the Alt key until the drives appear on screen. Select your main boot drive and off you go. Now in OSX goto the startup disk in the prefs and set it back to the hard drive instead of Network and you're done.
All the Best
Sean Cole
PiDigital
Dec 21, 2008 | Apple MacBook Pro Notebook
Photoshop cs3 install problem
First of all follow the instructions on this kb file:
http://support.microsoft.com/kb/315346
If you have previously installed cs3 you may have some residual files from the previous install still lurrking in the system files and registry which need removing. Or it may be that your cs3 installer files have become corrupt. to check this simply, do a file copy of the installer. If it copies ok it is likely not corrupted.
All the best
Sean
PiDigital.co.uk
Dec 16, 2008 | Adobe Computers & Internet
Error page when installing programs
Hi sean - does the error say you don't have permission to install programs? if not, what does it say? What operating system are you running please? Thanks.
Jeff
Jun 29, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
