Question about Fuji FinePix A330 Digital Camera
Formatting Type M XD Card for A330
I can't get it to initalize It will not format . Each attempt end with. notification Card in drive K (that's the A330) can't be formated.
Is there any way to solve this problem, & fix this thing.
My daughter is supposed to take it to Cape Cod from Western NC.
I just solved the same problem - it took a while. The original A330 camera was NOT set up to use with newer M type XD cards. But there IS a fix. You need to update the camera's "firmware". Go to:
http://www.fujifilm.com/products/digital/download/index.html
The scroll down to Firmware and find the A330 one. Download it to your computer's harddrive. Save it in a folder of its own.
Then EXTRACT the FinePix 330 file of about 604 KB that you will find in your new folder (do that by clicking it). It will produce a new file called FPUPDATE, a DAT file of about 1857 KB. LEave that.
Now either stick the old XD card into your computer (if it has an XD slot), or a Card Reader connected to your computer, or connect your camera with the old card to the USB port.
Once your computer recognizes the old XD card, just COPY the FPUPDATE file right onto the XD card by dragging it over.
Then insert the old XD card back into the camera (or disconnect the camera from the USB, turn it off).
Now here's the key: MAke sure your batteries are good. Turn on the camera WHILE HOLDING DOWN the DISPLAY/BACK button.
You will get a screen that says FIRMWARE UPDATE. Accept it, let it load, and it will upgrade to Version 1.77 that accepts M-XD cards!
Then put in the new card. Then FORMAT it by using the MENU screen on the camera.
Once you do that it will WORK (it took me 2 days to figure this out!!!!!). Good thing this is just a back up camera for me!
Posted on Aug 08, 2008
I formetted my memory card then i insite my card in camera it show card not initalized
Sounds like you're formatting the card in your computer. You need to format it in the camera.
Feb 21, 2011 | Fuji FinePix A330 Digital Camera
HOw do I initialize my card, I already formatted it
Initializing and formatting is the same thing. If your camera have an old firmwareversion, the camra can not use M or H type XD cards. You probably need to update the firmware. You can get the firmware here.
http://www.fujifilm.com/support/digital_cameras/software/#firmware
Make sure the batteries are fresh before updating.
Apr 24, 2010 | Fuji FinePix A330 Digital Camera
Memory cards in fuji a330
Yes it has to be an XD. They are physically different in size and shape. Although they both use JPEG photo formatting.
Sep 11, 2009 | Fuji FinePix A330 Digital Camera
Formatting what?
I hate to sau it but the reformating process does delete all files on the card. If you have either a xd slot on your pc (MAC) try to off load or make copies, Then follow the formatting directions in the owners manual. Good Luck
Jul 23, 2008 | Fuji FinePix A330 Digital Camera
Finepix a330
u need to upgrade your firmware for A330 as it is not compatible with cards over 512mb. go to fujifilm- accesseries-storage media-xd picture in left hand corner-xd type M. click on link under notice on compatibility. you will find your firmware upgrade here just follow instructions. worked for me
May 04, 2008 | Fuji FinePix A330 Digital Camera
No Image
Please read these/the 2 posts that I posted prior for a similar XD mem card problem, as I firmly believe you are "formatting" your mem card improperly using your home computer instead of "formatting" the card on your camera.
Also the XD type card & size are very important also!!
What you will have to do is read and download the photos you have on that XD card using the same "card reader" you used before and then properly "re-format" that card in your "CAMERA ONLY". This should solve your XD card problems.
PRIOR POSTS:
Kristina,
Not knowing what model Olympus camera you have, or how old it is - your new memory card "format" problem is one of 3 possibilities.
1st - If you have an older Olympus camera more then 4-5 years old the newer M & H series type cards over 256mb will probably not work in your older camera, as by the camera's internal firmware chip design of the camera itself. Some cameras were upgradeable some weren't as to the internal firmware chip as well as available software drivers depending on which computer OS system you were using ie: (WIN98SE, WIN2000, etc). Has to do with the memory card read/write chip speed as well, and also has to do with the physical storage size of the card itself. Some digital cameras were MAXED OUT at 512mb cards, some as low as 256mb. A 2gb card simple won't work in that/your camera in that case.
If you read the camera's user manual it will possibly tell you this, or else go online to www.olympusamerica.com and use this link:
View which cameras are compatible
Select camera model series and scroll down the model # and research the max card size & type you can use (3 basic XD card speed types available - regular XD - M type - H type).
If you are using the wrong type & size card you will need to return that card (if you can) and get the right XD size & type for your camera.
2nd - You should always FORMAT (same as ERASE ALL and FORMAT modes on most Olympus cameras) the new card, or any XD card for that matter in your camera itself. NOT THE HOME COMPUTER!!! The 2 format procedures are not the same!!
If you are re-shooting (re-using) the same XD card over and over again and then downloading the JPEG pix directly to the computer using a USB interface cable there usually is no need to re-format the card again as long as the XD card stays the camera and is not downloaded into a home computer via a "card reader". If you do the latter "card reader" then I would advise doing a card re-format in the camera again just to be safe!!
And lastly - If your home computer recognizes the XD card via a good "card reader" (do not FORMAT the XD card here btw, as you are just checking the card out to see it is GOOD is all), but the camera will not then that is a good sign your camera is OK, but it's just the wrong type & size XD card.
Hope this helps solve your camera XD problem not knowing which model you have.
Best regards,
Frank
AND:
Follow up to previous post:
I didn't have the time to access the exact link below to check on your specific 2004 model year camera because I missed the Fuji camera model part, as I'm brand new to this site - so please forgive my previous oversight here.
I was right though in my initial posted assumption that you bought the wrong XD memory card based on your Fuji FinePix A330 Digital Camera - as to it's older model year - in that your camera is limited to a 512mb memory card.
Make sure you buy the 512mb standard card if you still can find them. Otherwise check with Fuji Corp to make sure the M type card (faster read/write chip) will work in your specific model. The M type cards work just fine in my Olympus C-740 even though it was told to me they wouldn't work at all, but each digital camera is slightly different as to it's internal firmware (BIOS) chip.
See the following camera info for your specific model at the link below under Storage Media:
Steves Digicams - Fujifilm FinePix A330 - User Review
I hope this now clears up any prior confusion from the previous post.
Best regards,
Frank
Feb 06, 2008 | Fuji FinePix A330 Digital Camera
Finepix a330
What type of xD card did you buy?  It needs to be a plain xD card with no letters before the file size or a type "M" card.  For type "M" you will need to upgrade the camera's firmware.
http://www.fujifilm.com/products/digital/download/a330/fupd.html
This type of camera can't use type "H" cards, so cards like "H512mb" aren't going to work.
To initialize a card choose Menu. Arrow over to "Set", then arrow up to choose "Set-up". On screen "1" of the Set-up, arrow down to choose "Format".
This will ask you to erase all the images from the card, and format it.
Just today I upgraded my camera firmware to accept a type "M" card, initialized the type "M" card after that - and now it's working fine!
Reply back if you need more help. -Kelly.
Nov 21, 2007 | Fuji FinePix A330 Digital Camera
Memory Card Problem
I've solved it.
I'll bet a buck you also bought a memory card reader.
If you hook the memory card (or camera) to a computer, you'll see a directory with a name like fuji_999.
After you download the pictures delete that directory from the memory card, and the problem's solved.
I just did it with a 1 gig xd card in my daughter's fuji 480. It had a main directory on the card called DXsomething, and 2 subdirectories, fuji_100, and fuji_999.
I deleted all three directories (after saving the photos), and the problem is gone.
Hope it works for you.
Jun 27, 2007 | Fuji FinePix A330 Digital Camera
Memory Problem
have you tried formatting the card first within the camera, as it may be corrupt, or try it in a card reader and format that way.
May 18, 2007 | Fuji FinePix A330 Digital Camera
Fuji FinePix A330 Digital Camera Logo
279 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
