Question about Peavey Vypyr 30 30watt 1x12 Modeling Guitar Combo Amp
My Peavey Vypyr 30 watt modeling amplifier has no sound coming from the speaker but the speaker is good.
  • 5603 Answers
SOURCE: my peavey vypyr 75w won't turn on
Check the power cable is properly seated. These CAN work loose due to vibration.
After that check the fuses.
After that take in for repair under warranty.
Posted on Sep 15, 2009
  • 101 Answers
SOURCE: PV 1500 Amplifier
The final out put amp stage is out. MOSFET transistors likely. Hope this is helpful.
Posted on Nov 03, 2009
djlaplaya
  • 74 Answers
SOURCE: are peavey pv 2600power amps loud
yes, that would be very loud.
Posted on May 06, 2010
  • 5603 Answers
SOURCE: i have Peavey Pv 2600
One side of the amp has failed and repair is NOT DIY. Take it in for servicing. This amp has many components in the power amp and repair is complicated. A failure can lead to 20 components being damaged. Failure to replace all damaged ones can result in immediate failure destroying the replaced ones.
Posted on Aug 29, 2010
  • 5603 Answers
SOURCE: I have been using two
Passive speakers with 1/4 inch jacks do not define either as input as they are wired in parallel...
Assuming the speakers you added were each no less than 8 ohms this should NOT have overloaded your amp.If you have no sound you have probably blown your amp some way.
Note some amps can be blown if they are on and EITHER side of the speaker cable touches a ground. If the amp is running and a 1/4 inch plug is pulled, it shorts and can blow the amp.
Posted on Jan 17, 2011
How do I set up my Peavey Vypyr 30 amp and my Sanpera 1 footswitch to sound right?
your best bet is to contact Peavey directly. they can provide you with the manual and discuss your application. Here is teir contact page-
Peavey com
Mar 01, 2015 | Peavey Music
No sound whatsoever.
You have a blown speaker. Try plugging in a cab or connect another speaker of any kind to to see if you hear anything at all real low. Speakers blow in 2 different ways, they can either overheat, warping the voicecoil and end up sounding like a tin can or overheat and burn out completely, severing the voicecoil, leaving no sound at all, dead silence.
Mar 12, 2014 | Peavey Vypyr VIP 3 100W Modeling Combo...
Peaveyvypyr75willnotturnon
Check power supply fuse inside cabinet, if this is ok you may have good reasons to suspect that your power module got fried.
Mar 30, 2012 | Peavey Electronics Peavey Vypyr 75 -...
Peavey Vypyr 30watt service manual
Have you tried requesting from Peavey directly? customerservice@peavey.com
Sep 23, 2011 | Peavey Vypyr 30 112 Guitar Speaker Cabinet...
This is on a 15 watt Peavey Vypyr. I have a buzzing at the bottom end of my amp, when playing on the low E string. I plugged in my headphones and the buzzing went away while playing. I have also raised my...
The voice coil on the cube speakers must be scraping against the magnet.Or the speaker cone must be damaged causing it to flutter at low frequency where there will be large cone movement. Try removing the phono jack from your musical instrument/ guitar and touch the tip of the jack with your finger. You will hear a hum, now turn down the volume and listen to the speakers very closely and see if you can identify the flutter. All the same you will have to fix the speaker or replace it. Have you ever dropped the speakers, if so the speaker frame could have warped causing the scraping noise.
Aug 08, 2011 | Peavey Vypyr 100 Guitar Combo Amplifier...
Peavey Vypyr 30 30watt 1x12 Modeling Guitar Combo Amp Logo
462 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
