Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
0x139 blue screen error after reboot. system will not boot to safe mode and there's no option to access system restore
  • 977 Answers
Hi!
You'll have to reinstall (NOT format) Windows XP, as suggested and instructed here!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & Best regards,
Pelu.
Posted on Mar 17, 2011
Blue screen
Which operating system you are using??
You can follow the given steps to avoid blue screen error..
Start Windows in Safe Mode:
Step1: Turn on your computer and press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
Step2: From Advanced Boot Options screen, choose Safe Mode option then press Enter.
Step3: If Windows loads and works fine in Safe Mode, a bad driver is probably causing the error. Uninstall device drivers and reinstall them. If Windows experiences issues in Safe Mode also, repair your hardware.
Startup repair:
Step1: Shut down your computer and then restart it in Safe Mode (see step1).
Step2: From Advanced Boot Options screen, select "Repair Your Computer" and hit Enter. Choose your preferred keyboard layout and then click "Next."
Step1: Click "Startup Repair", and follow the on-screen instruction .Startup repair can solve this problem.
System Repair:
Step1: Follow step1 and step2 from Startup repair section.
Step3: Now select system restore from the System Recovery Options menu. And follow the on-screen instruction to select a restore point.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 24, 2013 | Acer Aspire Computers & Internet
I install windows xp profetional in g62_b39se it installed compeletly but when insatll completed, an blue screen apeared whith stop massage
Power on Laptop & Click F8 Button then Safe Mode Menu Visible Select "Disable Restart After System Failure" Then U Wacth And Reply Error Msg And Error Code Fully.
Best Of Luck
May 07, 2011 | Computers & Internet
When i start my computer it displays a blue screen. i can't access it; i'm using another computer right now
  • fix-computer-blue-screen-error-1.1-800x800.jpg Advanced Boot Options Menu
    Restart or press on power button of the computer and keep pressing F8 until the "Advance Boot Options" menu comes up.
  • 2
    Use up and down arrow buttons to navigate the menu, select "Safe Mode" and hit Enter.
  • 3 fix-computer-blue-screen-error-1.3-800x800.jpg Windows XP Welcome Screen
    This time you won't see the computer blue screen error.
    When the welcome screen comes up select Administrator and enter administrator's password(if you have one).
  • 4 fix-computer-blue-screen-error-1.4-800x800.jpg Launching System Restore
    Click on the START button and navigate to the Accessories folder. There you will see a folder entitled "System Tools," navigate to that folder and click on System Restore.
  • 5 fix-computer-blue-screen-error-1.5-800x800.jpg System Restore 1
    In the System Restore program, make sure "Restore my computer to an earlier time" is selected and click NEXT.
  • 6 fix-computer-blue-screen-error-1.6-800x800.jpg System Restore 2
    Choose a date on the calendar that you want to restore your computer and click NEXT.
  • 7 fix-computer-blue-screen-error-1.7-800x800.jpg System Restore 3
    The last page of the System Restore will pop up with your date that you have chosen and click NEXT. The system will reboot and the computer blue screen will be gone.
  • Mar 25, 2011 | Computers & Internet
    We have a Gateway Laptop running on Vista. Turned it on this morning and got the "blue screen of death" that said it had a Fatal Error KnownDLL 000021a and a bunch of other numbers. We read that...
    Just press and hold F8 on startup (before the Windows logo appears). You should get the screen with the title Advanced Boot Options and the following menu. (which I get on my Gateway NV5915h)
    Choose Advanced Options for: Vista (Windows 7 on my Gateway NV5915h)
    (Use the arrow keys to highlight your choice.)
    Safe Mode
    Safe Mode with Networking
    Safe Mode with Command Prompt
    Enable Boot Logging
    Enable low-resolution video (640x480)
    Last Known Good Configuration (advanced)
    Directory Services Restore Mode
    Debugging Mode
    Disable automatic restart on system failure
    Disable Driver Signature Enforcement
    Start Windows Normally
    Description: View a list of system recovery tools you can use to repair
    startup problems, run diagnostics, or restore your system.
    ENTER=Choose ESC=Cancel
    Mar 18, 2011 | Computers & Internet
    Blue screen error
    The most frustrating blue screen computer errors are basically caused by some physical faults such as faulty memory, power supplies, overheating of PC components, or hardware running beyond its limits, device driver conflicts etc.
    If you see the blue screen and halts occur in boot process, and also notice some specific error message appear on your screen, this indicates a serious issues most probably due to inappropriate device driver or firmware .Blue screen is really an annoying issue and creates a lot of trouble to the end user.
    Follow these steps to fix a Blue Screen in Safe Mode
    Once booting start, select "Safe Mode" from the boot menu.
    Scan your hard drive by running your antivirus software . If the program locates an infection, move it to your vault or follow the on-screen instructions. After program completion, if a virus was removed, attempt to reboot your computer and see if this clears up the problem. If not, restart your computer in safe mode.
    Restore your computer to a previous point. Click on the "Start" button. Select "All Programs", "Accessories", "System Tools" and finally "System Restore". Choose a restore point on or before the last day your computer worked without error. Finally Reboot your computer to see if it loads correctly.
    Aug 27, 2010 | Microsoft Windows XP Professional SP2
    I was just on my ibm t43 and it froze so i manually turned it off now it wont turn back on. it acts like it is going to then it pops up a screen that say an problem has been detected
    Hello, Meagan.
    Sounds like an operating system problem.
    Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
    If you can't access System Restore by Safe Mode, try Offline System Restore:
    1. Boot from the DVD
    2. Select the Language
    3. Click on "Repair your Computer" on the Install now screen
    4. Click next on the System Recovery Options screen
    5. Click on System Restore.
    6. Choose the date to which you want to restore
    If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
    If still not resolved, you'll probably need to reinstall your operating system.
    Hope this helps.
    Apr 19, 2010 | IBM ThinkPad R40 2722 Notebook
    I have a Toshiba Satellite L355-S7811 laptop that will not boot. It keeps going to a blue screen that says fatal error and before I can read it,it restarts. I dont have a recovery cd so I dowloaded 2 from...
    See let me talk with you from experience...
    The only thing that can be done is system restore to factory default and remember to backup your documents.
    This is the only way to resolve the problem you are going through.
    Cheers.
    Oct 11, 2009 | Toshiba Satellite L355-S7811 Notebook
    Lenovo X60 Laptop blue screen error wont boot up
    Try to go into safe mode by pressing F8 as soon as you turn on the laptop.
    If you get into safe mode then go into system restore and choose a date when the laptop was working properly. Let it rollback to that date and reboot the computer and let it go and see if it goes back into windows.
    If you get a blue screen even when trying to go into windows then the operating system is corrupted and you'll need to do a factory restore on the laptop, meaning the hard drive would have to be wiped out and the operating system put back onto the hard drive.
    Aug 27, 2009 | Lenovo ThinkPad X60 Notebook
    Zd8000 wont boot up
    try to get into SAFE mode... tap F8 repeatedly when you first power on. You should get a safe mode boot menu, select last known good profile and press enter.
    If this does not work reboot go into SAFE mode and select Safe Mode from menu and see if it will boot up.
    You may get a pop up to use system restore, say yes, select restore to an earlier date (or similar) then use the calander to select a restore date that is PRIOR to the problem starting.
    If this does not work boot to safe mode again and say NO (cancel) to use system restore and see if you can get to the desktop
    post back results for further troubleshooting
    Jul 16, 2008 | HP Pavilion zd8000 Notebook
    Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
    222 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
