Question about HP Office Equipment & Supplies
I have a F2100 three in one printer. What thickness paper is the best to use for making business cards. I have used 200 gsm and I think it is too thick. I also want to use my 1310 series printer for the same thing. Please advise. John Oakes.
  • 659 Answers
I just use glossy cards from Avery. seems to do the best for me. not sure the thickness. I personally like thicker just cause I know cards get put in places they should then they have a better chance of survival in their life span haha.
Posted on Aug 02, 2008
Duplex printing with card stock paper jams in back on Brother MFC-9840CDW
I would try manually inserting the paper for the back side. Most of the time it's best to wait a few minutes before trying the back side to give it time to cool so it will lie flat.
Sep 08, 2017 | Brother MFC-9840CDW Laser Printer
I wish to use my HP Photosmart C8180 to print heavy weight cardstock... is there a setting that I can select to do this?
Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
  • Plain paper, 20 to 24 lb (75 to 90 gsm)
  • Legal size paper, 20 to 24 lb (75 to 90 gsm)
  • Card stock, up to a maximum of 110 lb (200 gsm)
  • Envelopes, 20 to 24 lb (75 to 90 gsm)
  • Photo paper, 145 lb (236 gsm)
NOTE: Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
If you use card stock up to a maximum of 110lb then there should be no special mode to enter to print on this type of paper. Photo paper weighs in at 145 lb maximum which is heavier and can be printed on without selecting any special 'mode.'
Good luck on printing on heavy card stock.
Jan 21, 2011 | HP Photosmart C8180 InkJet Printer
The printer wont print on heavy paper is there a special setting i need to do
Paper types you can use:
Plain paper - 20 to 24 lb / 75 to 90 gsm
Photo paper - 6.5 to 12 mils (up to 290 gsm)
Card stock - 110 lb / 200 gsm, max
Envelopes - 20 to 24 lb / 75 to 90 gsm
Transparencies - inkjet variety with white stripe
Labels - all commercially available inkjet varieties on 8.5 x 11-in. or A4 sheets
There is no setting to allow printing of thicker paper stock.
For more information on your printer, please see the ESP 7250 All-in-One Printer Knowledge Center:
http://wwwcaen.kodak.com/global/en/service/products/ekn036791.jhtml?pq-path=2300285
Dec 20, 2010 | Kodak ESP 7250 All-in-One InkJet Printer
I want a print on card thickness paper , will a hp-5600 series print ?
Theoretically yes, but it's too close to limit. Try, but you have a 50% chances of paper blockage inside the unit.
Nov 29, 2009 | HP Officejet 5610 All-In-One InkJet...
What is the heaviest weight paper I can feed through my Office Pro 7680?
Aug 09, 2009 | Office Equipment & Supplies
I cannot get the Samsung CLP-310 color laser printer to print on glossy card stock (business cards). I have tried putting just one page in the paper tray. The printer starts to take it and then I get paper...
Printers are only able to use paper that is within their thickness threshhold. Simply put, the stock you are using is too think for your printer. Try getting some thinner paper and see if that works
Jun 16, 2009 | Samsung CLP-315W Laser Color Printer
I have a konica minolta c350. All day long, the cardstock I use to make business cards out of has been getting jammed. Regular paper seems to go through without any problems, but then I put the thicker...
When setting the paper in the by pass/manual tray did you select the thickness settings example thick 1 thick 2 think 3 ??? based of the weight of the paper you will need to select a thickness. If you still have an issue with this than I would inspect the fuser for damage.
Apr 07, 2009 | Office Equipment & Supplies
I am printing business cards and I am using thick paper but colors come out dull looking but if I change the paper to PLAIN then the colors come out just perfect, full, vivid and rich but I am afraid that...
Its most likely the paper you are printing on. It sounds like this is an ink printer. The way ink works is that it is absorbed into the paper you are printing on. Some paper pulls the ink too far into the paper causing it to look dull and faded. You need to make sure you are printing on paper that is designed for inkjet printers. There are a lot of companies that make special paper designed for printing your own business cards. I prefer Avery products since they have a guarantee.
Check this link out for some options on InkJet business card options.
http://www.avery.com/avery/en_us/Products/Cards/Business-Cards/_/Ns=Rank%7C1%7C%7CProduct%20Number%7C1
I hope this is solves your issue....Violet
Jan 23, 2009 | Office Equipment & Supplies
Paper thickness allowed
Type Paper weight Input tray capacity Plain paper 70 to 90 gsm (20 to 24 lb) 100 Cards 200 gsm (110 lb) 20 Envelopes 75 to 90 gsm (20 to 24 lb) 10 Transparency film N/A 20 Labels N/A 20 10 x 15 cm (4 x 6 inches) Photo 236 gsm (145 lb) 20
Dec 27, 2008 | HP PSC 1315 All-In-One InkJet Printer
Print Garbage
The reason your pictures come out dark and grey is that you have not set the paper thickness on your printer. On the back you will see a flip switch change this setting then feed your business card sheet in there and see the diffrence. Plus make sure your settings for your printer are set for a thicker paper this will fix your problem. Make sure though when done printing your cards that you set it back to the normal or you will have problems printing regular paper documents.
Sep 15, 2007 | HP OfficeJet 7310 All-In-One InkJet...
43 people viewed this question
Seeker5211
Seeker5211
