Question about M-Audio M AUDIO MOBILE PRE - USB MIC PREAMP Microphone
Problem with m-audio usb mic.
When i try to record there is a noisy sound ...... so my question is how can i stop that........ while i try to record a song with guitar
  • Anonymous Aug 30, 2008
    i have the same problem...
    Problem Solver:
  • 6 Answers
First u have to locate he noise but removing components such as guitar, amp, fx and a big one is usually florescent lights or bad ground
Posted on Nov 08, 2008
I installed the lexicon lambda with the disk provided but when i put my mic on the mic input it doesn't record... what should i do? please help!
first thing to do is check your sound and audio settings, goto control pannel,then, sound/audio setings and see if everythings set up properly
Sep 19, 2011 | Lexicon Lambda Usb Desktop Recording...
I'm trying to use my ION TTUSB1010 Turntable. I don't get any sound when I record or Playback. I've got Playback set to Sound max digital Audio and sound recording at USB Audio CODEC. I just get feedback...
http://dl.owneriq.net/b/b15dd636-9b8d-4d78-8fd0-4bb2d82774f3.pdf
Above is your user manual, perhaps this can help?
If you are getting feedback, that's because there is too much "Coupling" between the Mic & Amp, You may need to use a Mic, with LESS drive.
Are there any Firmware upgrades?
You also need to ensure the Recording CODEC is the same as the playback CODEC, that's a must do.
Nov 29, 2010 | Computers & Internet
ION TTUSB10 turntable plugged into Toshiba laptop,
Maybe the output is not good enough for line in on laptop try mic in, then double click the sound icon down bottom right where time is, goto options, properties, then recording inside of recording make sure all boxes are ticked so you have all options like mic wave stereo mix line and so on, click ok, now make sure what ever you have the turn tables pluged into is selected as your recording device and not muted try again, once this is all ok ., it should work. hope this helps. also make sure your software you use to record is also set up same. take care
Dec 03, 2009 | ION Audio TTUSB10 Turntable
The mic does not record stereo anymore. when playing back a stereo works fine but when recording in stereomodus only the left channel records, the right channel seems to record silence/noise
This Mic is not a stereo Mic. If you're using a windows computer, check your sound control panel to see if the mic wasn't suddenly set to two channel device.
Sep 30, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
The sound recording is noisy
try setting the options on the sound recording lower and try to find the wind audio correction selection. that should work.
~good luck
Jul 14, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Cannot record
Im having the same probz, got a Hp Pavilion Vista using mobile pre amp usb when i record using a condenser mic XLR nothing is picked up from the channels in Cubase or Nuendo. Im trying to record vocals but the Mic is not picked up and i cannot hear myself in the headphones and it wont transfere to cubase.
It has worked before when i had a desktop, but this only worked with a separate m-audio sound card inside the desktop and i plug in the output jax leads from the desktop (soundcard) to the m-audio usb pre amp
Is this why it is not working for the laptop do i need a Jax connection and where is this audacity
Sep 15, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
There is a crackling sound after I record.
The problem was the VIA chipset firewire card. I changed it with a Texas Instruments one. Works perfectly now.
Sep 04, 2008 | M-Audio Solo Audio External Sound System
No sound through M-Audio preamp and condenser mic
Hi micoach
The condenser mic you are using requires phantom power for it to operate. Pay to check that that is turned on m-audio. Just to be sure.you say you can get sound off the m-audio headphone socket. Just need to check that. You will need to check that you have selected the device for recording from the preferences--audio I/O options menu within audacity. Perhaps check these things and get back to me here if you still have problems.I can go into more detail with you.
regards
robotek
Jun 30, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
Usb mic in cubase sx3
you have a pci audio card so maybe you can add an extra input device by going to devices panel or press F4 shortcut.
and choose your usb mic.
also you can check your wavelab audio inputs. they must have the same config so if you can record woth your usb mic and your poci card in wave lave you must be able to do so in cubase sx
hope it works
Apr 01, 2008 | Steinberg Cubase SX3 (502010600) for PC,...
My mic doesnt work
to put that in cam microphone working, you need to see on audio settings properties and change the "recording device" to usb audio device, instaid of the soundcard as is. That means that the sound recording will be from the cam's microphone.
The steps are:
1- rigth mouse click on the speaker next to the clock OPEN VOLUME CONTROL
2- OPTIONS - PROPERTIES - RECORDING
3 - in MIXER/RECORDING DEVICE (where is your soundcard's name) change to USB AUDIO DEVICE and then OK
4- In the remaining volume control window, select MICROPHONE and then close all the volume control windows
5- you can test the mic settings in messenger (any version) because of volume and to a clearest voice sound in your pc.
ATTENTION: carefull with the distance between your cam and your sound speakers because of distorcing sound and feedback
Jan 23, 2008 | Logitech QuickCam Fusion Webcam
315 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
