Question about Maytag Refrigerators
Mr refrigerator leaks water out of the front of the machine on the corners, the bottom tray is solid ice. The model is MBF2255KEB with the freezer on the bottom.
  • Maytag Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 18, 2011
Why is my Viking refrigerator/bottom freezer leaking water out bottom of door? There is a layer of ice on bottom of freezer.
The ice on the bottom of the freezer is blocking a drain hole. When the freezer defrosts automatically, water drains out the bottom into a tray, where it evaporates away and you never see it under most conditions.
The solution is to either defrost the freezer manually and let the ice melt, or pour some hot water into the bottom of the freezer to thaw out the ice and clear the blockage.
If the drain is plugged because of some foreign matter, either method will make a mess, so have some towels at the ready to sop everything up if need be. If it is blocked, a can of Air Duster (like for cleaning electronics) might be able to blow the blockage out, if you seal the nozzle tube up as it is stuck into the drain.
Most likely it is just ice blockage.
You can access the drain tray (where the water goes to evaporate) by removing the grille on the front bottom of the fridge and peeking / poking around. You might want to keep an eye on it as you defrost the freezer or pour hot water in the bottom - it can over-fill quickly.
Jul 20, 2014 | Viking Refrigerators
Why is water leaking from front of bottom freezer?
Your refrigerator defrost on the average about every 8 hours so the water that accumulates during defrost has to go somewhere right? You have a defrost drain blockage.
We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! Not all blocke drains act the same when your refrigerator leaks so please ask should you have questions. Please provide the model number found around the fresh food section door frame. Kenmore model numbers look like this example=> 321.1234567 If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Jun 26, 2013 | Whirlpool Refrigerators
I have an Electrolux EW28BS71IS and I have water dripping from the ice maker. When I take the ice maker tray out it has water sitting in the bottom of it. I can't tell if it might be overfilling the...
i have an elecolux ice maker leaks water into the bottom trays from the back of the fridge and water always drips from the front dispenser. the ice freezes in a solid block can anyone help me please. ew23bc71is3 is the model double door freezer on the bottom tks.
Mar 31, 2011 | Refrigerators
Have a TFX26ZPDA that occassionally leaks from front freezer corner. notice of leak anywhere, but find water under the fridge on the floor (facing fridge left bottom)..........why is this
I would check the bottom of the freezer. If its a solid block of ice then you have a frozen drain line. You may have to remove the back panel to access the drain or on some models there is a gap there its located in the back. If you take a turnkey baster and fill it with hot water and keep shooting it down the drain line it should eventually thaw out. The water is coming from your evaporator coils when they defrost.
Hope this helps _MJ_
Feb 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
54 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
