Question about Westinghouse L2046NV Monitor
Monitor turns then shuts off...will not stay on
  • 902 Answers
Sounds like your power board is going bad. you will probably need to replace it. also try unplugging it for about 20 minutes see if it turns on for longer if it doesnt then it is your power board. sorry for the bad news how that wont affect my rating
Posted on Mar 17, 2011
Screen stays on for about 20 minutes than shuts off after that..if you turn off and turn back on..it comes on then immediately shuts back off Its item #1704FPT 17" Monitor for 4700 Dimension...
On your Desktop, Right Click the mouse and Select Properties.
Click Screen Saver tab and Select Power. Change Turn Off Monitor
to Never. Your monitor should stay ON forever, until you turn its
power OFF.
Jul 21, 2011 | Computers & Internet
How do I turn off yellow on my hp monitor? yellow light on monitor stays onm after computer uis shut down.
Push the power button. The yellow light it to indicate that the monitor is idle or that it has no signal, and will stay on as long as the power is on to the monitor.
Jan 30, 2011 | Computers & Internet
THE MONITOR WILL NOT STAY ON. IT KEEPS SHUTTING OFF. WE CAN TURN IT BACK ON AND IN FEW SECONDS IT SHUTS BACK OFF. WE TRIED A DIFFERENT MONITOR AND THAT ONE DID NOT SHUT OFF. SO, THE PROBLEM HAS TO BE IN...
Whenit power up and stays if the display picture is good, the fault can be a dry soldering, poor joint or a thermal runaway of one of the power circuits.
In all the above you can open the monitor , tap and see or look with a magnifier for visible dry joints.
You can also check if any semiconductor or IC is heating up beyond to shut off.
Sep 29, 2010 | Dell E193FP 19" LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Monitor will not stay on
I am having the same issue. Stays on for 2 seconds then goes black. If I find a solution I'll let you know.
Apr 07, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Screen seems to be not working properly
try using a different monitor, borrow one if you have to, if the monitor works on your computer, then it simply means you need a new monitor. As far as the computer shutting down, it may be recording the bad monitor as an error in the loading process and automatically shutting down.
Mar 15, 2009 | HP TouchSmart IQ770 PC Desktop
Dell e770 Monitor
It sounds like the picture tube in the monitor has burned out. Time to replace.
Feb 03, 2009 | Dell E770 Monitor
Monitor (viewsonic e70fb) keeps shutting itself off
the screen has begun vibrating and is very hard to read.
it sounds me that there is some sparking in power supply or high voltage section (FLYBACK) due to loose contact,
your problem of  shut off, I would turn it back on and it would stay on
.might be also due to that only.
please call tech if you are not a tech person.
it is not a major one & simple to fix.
good luck.
Oct 11, 2007 | ViewSonic E70fb (Black) 17 in.CRT...
Westinghouse L2046NV Monitor Logo
76 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Iqbal Husain
Iqbal Husain
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
