Question about Car Audio & Video
Hello, I have a delphi 21003872 radio/cd reciever. the wiring harness that i have has 1 white wire,1 blue and the rest are green. the wires are labeled with numbers. could you tell me which is the ground and which are the power wires?
2 Suggested Answers
  • 3 Answers
SOURCE: Kenwood kdc-248u. Installing into a
From the installation instructions: Ant Cont - Motor antenna control wire (Not used) P. Cont - Power control wire - To the power control terminal when using the optional power amplifier or to the antenna control terminal in the vehicle. Mute - Mute control wire - To the terminal that is grounded when either the telephone rings or during conversation (this would be to the telephone that is purchased separately.
Posted on Jul 27, 2011
I have a 97 toyota tocoma ext.cab. and am putting in my new cd player although my wires are not the same colors could you tell me what wires i need to match
Hello... I will try and help you with your problem. I am assuming that you have cut the factory harness off in the truck? If you have and you can reconnect it, I would recommend doing this and then you can purchase a wire harness adapter and then just match the colors. The benefit in using an adapter harness is the ease of the installation, and the more you change the radio in the truck, the shorter the wires will get. If you do not have the factory harness, or cannot reconnect the old one, here is the hardwire code:
Wire purpose: Truck color: Alpine harness:
Constant 12V+ Blue/Yellow Yellow Switched 12V+ Gray Red Ground Brown Black Illumination Green N/C Dimmer n/a N/C Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Pink White Left Front (-) Purple White/Black Right Front (+) Light Green Gray Right Front (-) Blue Gray/Black Rear Speakers 6 1/2" Rear Corners Left Rear (+) Black Green Left Rear (-) Yellow Green/Black Right Rear (+) Red Purple Right Rear (-) White Purple/Black
Hope this helps!
20 year car audio/video installer
Bay manager
Apr 06, 2011 | Alpine 16 Pin Original Head Unit Harness
I would like to see a wiring dieagram for a 2005 tahoe sterio speakers
Radio 12v red/white + radio harness Radio Ground black - radio harness Radio Ignition (GMLAN Serial Data) Radio Illumination yellow (dimmer) + radio harness Factory Amp Turn-on same as power antenna wire Power Antenna white + radio harness LF Speaker +/- tan - gray +,- radio harness or amplifier Notes: If equipped, the amplifier is under the rear of the center console.
At the amplifier, the left subwoofer wires are dk. blue/white (+) - lt. green/black (-). The right subwoofer wires are dk. green (+) - lt. blue/black (-). RF Speaker +/- lt. green - dk. green +,- radio harness or amplifier LR Speaker +/- brown - yellow +,- radio harness or amplifier RR Speaker +/- dk. blue - lt. blue +,- radio harness or amplifier clear.gifthat should be it **** if u need more help feel free to email me at bertman285@hotmail.com
Oct 05, 2009 | Car Audio & Video
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Ok, here is a list of the factory wires coming from the car that I have for hooking up a radio and there colors. Red wire with blue stripe, red wire with yellow stripe, brown wire with white stripe, brown...
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Aug 12, 2009 | Car Audio & Video
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
Need a stereo wire color code for 2000 subaru outback limited
The sell a nifty little invention at Wally-World. Its called a wire harness...look for it in the auto parts section. it will wire directly to your stereo wires and then just plug & go... if your subaru wires are missing the harness on the end, its a whole different ballgame, and its gonna be fun...try this...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Red/Yellow
Right Front Speaker Negative Wire (-): White/Black
Left Rear Speaker Positive Wire (+): White/Red
Left Rear Speaker Negative Wire (-): Red/Green
Right Rear Speaker Positive Wire (+): Blue/Green
Right Rear Speaker Negative Wire (-): Red
Let me know how it goes!
May 17, 2009 | 2000 Subaru Outback
Need color code for radio harness
Hello Mexicano1037,
Here are the colors for the radio harness on your '91 Escort.
1991 Ford Escort Radio Color Codes
Battery Constant 12v+ Wire: Blue/Red
Accessory Switched 12v+ Wire: Blue/Black
Ground Wire: Black
Illumination Wire: Red/Black
Left Front Speaker (+): Violet
Left Front Speaker (-): Blue/Orange
Right Front Speaker(+): Blue/White
Right Front Speaker(-): White
Left Rear Speaker (+): White/Blue
Left Rear Speaker (-): Red/Blue
Right Rear Speaker (+): White/Green
Right Rear Speaker (-): Blue
Hope this helps.
Apr 12, 2009 | Car Audio & Video
NEED TO KNOW WHICH WIRE ARE WHAT ON DELPHI TRUCK RADIO
You may wish to consider purchasing a wiring harness that will allow you to plug directly into the vehicle harness without tapping or splicing. Here's a link to one such item: This one appears to be for your vehicle.
http://www.sonicelectronix.com/item_5944_PAC+ADD-GM24.html
Installer.com shows the following color code for the radio and speaker wiring for the 2007 GMC Sierra.
Speakers
White: (LF+)
White/Black: (LF-)
Violet/Black: (RR-)
Violet: (RR+)
Green: LR+
Green/Black: LR-
Gray: RF+
Gray/Black: RF-
Radio
Black: Ground
Red: +12volt Acc Switched
Yellow: +12volt Battery Constant
Blue/White: +12v Remote Output (Amp Turn On)
Red/White: Reverse Light Trigger
Yellow/Black: Parking Break Trigger
Orange/White: Auto Illumination
Blue: Powered Antenna
Orange: Illumination
Brown: Phone Mute (optional)
I would recommend that you verify the speaker wires before doing any splicing.
Attach a speaker to a pair of test probes and leaving the harness in and working, probe the back of each pair as coded above to insure that they really are the correct wires. Most likely you will want to convert the rears to low-level, so start with those. Probe the Violet(+)/Violet Black(-) pair and you should get sound in your test speaker. Likewise, do the Green(+)/Green Black(-) pair.
The only other wire you would need from the stock radio for an external amp would be the blue/white turn-on lead and if your LOC has audio sensing turn-on, you may not even need that. Bring power to your amp directly from the battery (fused according to amp manufacturer recommendations) and find a ground within 3 ft or so of where you intend to mount the amp.
Hope this helps.
Mar 28, 2009 | Car Audio & Video
Ford focus 1999
Pin --- Color --- Stripe --- Function
Harness 1
1 --- White --- Black --- Left front +
2 --- Gray --- Black --- Left front -
3 --- White --- Purple --- Left rear +
4 --- Gray --- White --- Left rear -
5 --- White --- Red --- Right front +
6 --- Gray --- Red --- Right front -
7 --- White --- (none) --- Right rear +
8 --- Gray --- (none) --- Right rear -
Harness 2
1 --- (not used)
2 --- Black --- Green --- Radio Ground
3 --- (not used)
4 --- Orange (thin) --- Black --- Radio Illumination
5 --- Green --- Yellow --- Radio switch
6 --- Black --- Yellow --- Radio Ground
7 --- Orange (thick) --- Black --- Radio 12V
Harness 3
1 --- White --- Green --- Speed sensor
2 --- (not used)
3 --- (not used)
4 --- (not used)
5 --- (not used)
6 --- (not used)
Dec 22, 2008 | 2003 Ford Focus
WIRING COLOR CODE
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Apr 07, 2007 | Clarion DRX5575
Car Audio & Video Logo
241 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
