Question about Compaq Presario R3000Z Notebook
Why is my compaq presario r3000 running off the battery when it is plugged in? I replaced the power cord, but the problem is not solved and seems to be getting worse. the battery is not holding a charge, and only occasionally is the laptop recognizing that it is plugged in.
    Master:
  • 325 Answers
Loose power socket problem probably see the bottom left section of this website
(socket damage)
http://www.2pages.co.uk/laptops.html
Posted on Mar 17, 2011
  • 902 Answers
The little light on the power brick is it on? if its not you need a new power adapter but chances are teh power plug on the laptop itslef is loose this is farily common. it will need to be re opened and soldered back on tight. sorry for hte badish news hope it doesnt affect my rating for your solution.
I have a HP Compaq Pressario R3000 laptop that will not turn on. I recieved a message that the batter was low even though it was plugged in. I bought a new plug, still didn't turn on. Bought another...
This seems to be a common problem for this model. Some have reported a loose (or dry) solder connection on the mother board where the power socket is attached. Does it seem to work if you push the plug in harder, even for a second? . You should read this thread... http://www.tomshardware.com/forum/50946-2-compaq-presario-r3000-power-cord-issue It may not be your particular issue, but there is a likelyhood that it is. If you are not handy with delicate work, or a solder iron, I suggest a laptop repair shop. Maybe copy or print a part of the thread to clearly indicate what you want. Good luck
Nov 09, 2010 | Computers & Internet
Shutdown
if it is in a no power no boot situation you will have to replace the bios chip or replace the motherboard. if you update the bios ALWAYS MAKE SURE YOU ARE ON AC POWER AND HAVE A FULL BATTERY. if your battery is weak make sure the power cord is plugged in and secure . if your computer looses power during a BIOS update it is bad .
Jul 06, 2010 | Compaq Presario R3000 Notebook
Power cord has to be held inat an angle to run and
I would suggest it`s a bad solder connection to the board on your laptop or a small break inside the power chord wire right at the neck of the wire plug.If you can find an identical notebook to try the plug in...that may narrow your problem as to the power chord or the notebook plug,good luck:)
Apr 11, 2010 | Compaq Presario R3000 Notebook
Intermittant power when using the power cord.
yup probably the power cord. try replacing a new one if you have or try borrow from your friend just to test if the problem is really in the power cord
Dec 07, 2009 | Compaq Presario R3000 Notebook
It keeps turning off, I have tried my friends power cord incase that was the problem but even with her cord it turns off, and just before that says that I need to plug the charger in even though it is...
ok sounds like your battery has gone bad.
try this test: remove battery plug computer into the wall.
boot computer if it boots up and stays on you will need a new battery.
Nov 13, 2009 | Compaq Presario R3000 Notebook
My r3000 has a tempermental power supply. it
whatabout the lead that plugs into the laptop ? does the plug in the laptop move easily, with the lead in, Sounds like the actual plug in the laptop is breaking away, the solder around the connector. Sadly to fix that you will have to get it repaired for about £50 to £70, maybe more ?? please make sure the lead from power supply is not loose or a bad fitting.
Jun 14, 2009 | Compaq Presario R3000 Notebook
COMPAQ V2000 WILL NOT POWER UP WITH DC/ADAPTER OR BATTERY
Hve u tried a differnt adaptor , the adaptor might be blown too ,try replacing the adaptor , also check for the power cord if it has any kinks in it which may be interrupting the power supply , since the adaptor 18.5 v 3.5 a is the most common of all hp adaptors u should find one to try .
Aug 27, 2008 | Compaq Presario R3000 Notebook
The power plug won't charge the battery which prevents the computer coming on
There was a recent class settlement agreed to by HP regarding these models. HP failed to notify a ton of its customers and I've contacted Scott Kamber regarding.. (We were consultants for the suit).. Weve repaired a ton of these and you are not alone. Did you buy the machine new and register w/HP? Just curious...
Ken
Aug 02, 2008 | Compaq Presario R3000 Notebook
Presario r3000 shuts down
I have experienced similar problems. I found that if the fans were REALLY dirty, the system would overheat and shut down with no warning.
May 04, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000Z Notebook Logo
56 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
