Question about Troy Garden
I have a walk behind rear wheel drive mower. it is a 2007 year model. The transmission has to be replaced. I disassembled the mower and have the parts on order. My issue is where the extension spring attaches. When I took the shrouds off the spring was just laying in the shroud. I think it connects to the transmission but am not sure about the other connection point. Can you help?
  • 4 more comments
  • grumpy58945 Mar 17, 2011
    The model number is 12AV835Q711. According to Troy Built parts site it is a 830 series. The part number for the spring is 732-0320. I hope this helps in your research.
  • grumpy58945 Mar 21, 2011
    Thank you. I just found your reply and am grateful to you. I ordered a transmission only to have the wrong one shipped. Seems that the number listed in the Troy Built exploded view was not the correct number. I had a local business research it and together we found the right transmission. Should have it this week.Thanks again for your assistance.
    Thanks again.
  • grumpy58945 Mar 22, 2011
    Is the hole in the deck the same hole that the control cable goes in. I can not find any other place on the under side of the deck that this spring might go into.
    The control cable fits through a bracket on the transmission and the cable end goes into a slotted hole in the read of the deck. Is that where I put this spring?
    This mower has a drive pulley on the crankshaft and a pulley on top of the Transmission. Those are the only pulleys on this mower. Both pulleys are mounted horizontally. The belt fits around the crankshaft pulley and around the transmission drive pulley. The cable seems to tighten the belt when the handle is pulled.
    As for the hole in the deck. There is a large hole that allows the control cable to go through the deck to the bracket on the transmission. The the cable continues to the only other hole in the deck. The cable has a lead slug on the end which fits through the hole and then anchors the cable. This hole is somewhat like a key hole one round part and then a slot.
    Is that where this spring attaches to the deck? I have been out and cleaned the under side and can find no other points to attach it. My other thought was that perhaps the spring attaches the the main shroud, that covers the belt.
    Ok. However there is a factory made slot in the shroud that would be in about the right position for the spring to fit. I am going to continue to work on this ******. It was given to me on the agreement that if I fix it I can have it. Thanks for your time.
SOURCE: Wheels do not freely roll backwards
SOUNDS LIKE THE PINONS ARE ON BACKWARDS. THE KEY SHOULD SLIDE OFF THE PINIONS WHEN PULLED BACK AND LOCK WHEN ENGAGED. YOU HAVE THE OPPOSITE PROBLEM OR ITS BACKWARDS!
Posted on Oct 16, 2008
  • 205 Answers
SOURCE: Need wheel nuts and bolts for a Ryobi 21 inch
A good hard ware store will have the shoulder bolts you are looking for, take a wheel with you, the solid bolt part should be just a 1/16 of an inch longer than the wheel hub
Posted on Mar 23, 2009
harlan301
  • 205 Answers
SOURCE: i am looking for the cable for a Craftsman Eager 1
go to the sears web sit. on the top right side, says parts direct click that on. ty-ip in your model and it well give you a parts brake down. good luck
Posted on Oct 23, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Drive stopped working
There is an idler pulley inside the deck with a spring. The belt probably jumped of the idler which would result in the drive cable being slack. You can probably fix this yourself by re-routing the belt so that the idler with spring engages the belt. Depending on the condition of the belt you may have to losen all of the engine mount bolts so re-route the belt properly. I have had to take out all but ONE engine bolt (left loose) to install a belt.
If you need details on bolts / covers that need to be removed I need the whole model number to be of further asistance.
Thanks for using FixYa.
Kelly
Posted on Jun 17, 2010
Testimonial: "Thanks to all the expert advice givers...very helpful info."
  • 640 Answers
SOURCE: Have a walk behind 22"
Sounds like the rewind spring is broken in the recoil starter.
Posted on Aug 04, 2011
The self propel system slowly stopped working and now doesn't work at all, what could it be?
You didn't specify the make or model of your mower, but generically speaking for self-propelled walk-behind mowers, the drive belt or the front wheel gears can wear out after several years of use. The drive belt could also be loose or off the pulley. The belt and the front wheels can usually be replaced.
You can remove the drive pulley cover and see if the belt is off.
The other components that make up the drive system are the gearbox and the engagement cable. Sometimes the cable can get get out of adjustment or come loose.
Jul 23, 2015 | Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Why did my Lawn Boy Platinum self propelsion quit?
I believe there is a V-belt that drives the front wheels,it may have broken,or the gears in the gear box have failed !
Jun 22, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Why isn't Lawnboy lawn mower model NO. 10604 drive not working
Inspect the pulley where the belt loops on the wheel transmission. There is a tension spring, that when you pull the level, it puts tension on the belt. If that spring is missing or the pulley does not provide tension the wheels will not turn because the transmission is not being engaed..
May 23, 2014 | Heavy Machinery
My john deere js30 walk-behind mower will not drive.
either the belt do not have enough tension or the plastic gears on the drive wheels are worn down or eaten away
Jul 02, 2012 | Garden
The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
Jun 22, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
My two year old flymo self prop. rotary mower is now making a grinding and screaching noise coming from the drive box how do i get the rear wheels off , this model is the large rear wheel type model...
Have you tried looking at www.flymo.com. Select the country you are in. Looks like you are going to need to find a different model number to find whatt you are looking for. But maybe this site will get you headed in the right direction.
Good Day.
Sep 10, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
No drive
Hello orlywooldrid:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers (20622) and Click Search. Now Select View Assembly Drawings for your Year Model.
Everything you Asked is at the Above Site Addy.
Parts can Also be Purchased from this Site Addy;
http://www.outdoordistributors.com/
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 08, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
158 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
