Question about Siemens Washing Machines
I have Siemens WD61430 Washing & Dryer maschine. During washing the mashine stops and 3 appears on the display. We always have to turn off and than on, for the mashine to continue washing. Every 10 minutes we have to do the same. How can I remove that 3 from display so the mashine can wash without interruptions? Thank you in advance.
techman
  • 3130 Answers
SOURCE: washing machine
sounds like a pump problem. see if theres a broken belt going to the pump. if its a direct drive unit then the clutch solinoid could be defective or the timer as well. What you need to do is if its a direct drive is measure the voltage on the solinoid or switch wehn its supose to dran if its there then the switch or solinoid is bad. If its not there then most likly the timer but I would need to see the wiring chart to be sure. good luck PS the wiring chart is inside on the back or on one of the sides in most washers and dryers.
Posted on May 03, 2006
jonniewalker
  • 1029 Answers
SOURCE: washing mashine
If there is a drain issue, sometimes there is an obvious solution. Check the drain hose for any kinks, as well as checking any lint filters in or on the drain hose. Is there a lint sock on the end that's full? Perhaps the drain line itself is plugged. You will want to make sure that the house drain system is not backed up or plugged. Always make sure that the washer drain hose is above the level of water in the drain tub. Some Whirlpool/Kenmore washers make use of a side-check valve near the tub outlet which may get clogged. A standpipe should be at least 1 1/4 inches in diameter, and never seal a drain hose into a standpipe. This can lead to back-siphoning. You also want to make sure that the standpipe is less than 96 inches in height. Pump problems show various symptoms. Sometimes the pump will lock up and seize. If the motor is running, it will continue to try to turn the pump. In the case of belt-driven pumps, the belt may break or burn through. The pulley may shear off. If there is enough tension on the belt, and the motor continues to try to turn it, you may wind up with a seized motor as well. The pump itself may have seized bearings, be jammed by clothing or another object; or the impeller blades may be broken off. The usual fix is to replace the pump.
If you think your pump may be jammed, drain out your tub and remove the hoses. Look inside the hoses and see if there are any obstructions. Feel around inside the pump inlets for anything that may be jamming the pump itself. You can also use long-nosed pliers to feel around inside the pump for any items that may be causing a jam. If you haven't found a jam, and you still believe there may be a jam in the pump, you can completely remove the pump from the washer and inspect it more closely.
Occasionally, transmission gears may become worn, or some other internal part may go bad. Some older washer models have an electric-mechanical shifter. If it won't shift, it's best to call a professional appliance repair person to address this issue. If your transmission is leaking oil, there are really only two options at this point, either run it until it dies completely, or replace it now.
Posted on Sep 27, 2008
  • 13 Answers
SOURCE: Siemens Siwamat c12 manual needed
This site says they have the manual. I see it is not free, no idea how much they charge for manuals etc. Hope that will help you.
http://www.manualsnguides.com/search.php
Posted on Jul 17, 2009
blueextc3221
  • 15935 Answers
SOURCE: hotpoint Aquarius+ WF740 washing mashine flashing F-05s
  • F05 - Pressure switch jammed on full
  • The pressure switch must be changed.
    For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
    I recommend both sites because ...
    FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
    PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
    RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
    If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
    In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
    Anything too complicated or beyond your scope should be handled by a professional.
    If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Posted on Sep 15, 2010
    supernova278
    • 1932 Answers
    SOURCE: Users manual for a Siemens combined washing
    You can get your user guide from below website
    https://www.2instructions.com/search.php?cmarque=SIEMENS&modele=SIWAMAT%20PLUS%205431
    Thank you
    Posted on Oct 14, 2010
    WHAT IS F12 IN A WASHING MASHINE ARISTON AQUALTIS AQXXF 129 H?HOW CAN I FIX IT?
    F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
    F12: Lack of Display card-Main Card Communication
    1. Check the effectiveness of contacts on CNC Connector Card
    2. Overhaul 8-way connector on Display card
    3. Check continuity of CNC-CN 8 way connector
    4. Replace Main Card
    5. Replace Display Card
    Dado
    Apr 24, 2014 | Ariston Technologies AWD 129 NA Washer/...
    F:80. My new siemens washing mashine IQ700 shows F:80 at the end of the program with the alarm. I can\t open the door normal way. What does it mean? We installed the mashine yesterday.
    It means that the machine register what's in there as too heavy.
    Can't understand for the life of me why this error code isn't explained in the user guide, but that's just how it is.
    To fix this, turn off the machine, make sure that you get out as much water as possible and then open the door manually by pulling the red plastic band to the right of the pump (remove lid first ofc), or you need a screwdriver or something like that on some models depending on the age of your product.
    I do know that this answer comes a little too late, but browsing for answers myself, I had to dip into the old noggin of myself as a former White Goods Consultant and I figured it all out.
    For future reference I therefor post it here anyway ;o)
    Jun 23, 2012 | Siemens Washing Machines
    My Siemens extraklasse xls140 isnt always doing the final spin and the water doesn't appear to be getting hot during the wash.
    I have a siemens ekstraklasse xls 140 and at the stadge it must spin and drain it says drain is blocked. Is there any way i can unblock it myself and where do i find it.
    Jan 27, 2011 | Washing Machines
    Model no wa80b3 samsung washing mashine
    My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
    May 02, 2009 | Washing Machines
    Washing mashine repair
    Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
    Sep 17, 2007 | Washing Machines
    Lavamat
    have youlooked in your manual it should have some codes in trouble shooting that will help you sort out the problem. hope this helps.
    Jun 01, 2007 | AEG Lavamat 12710 Front Load Washer /...
    Washing Machines Logo
    44 people viewed this question
    Top Siemens Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
