Question about Logitech Cordless Mouse
Logitech M205 - Left button sometimes double clicks when I only single click, or does not click at all. Does other strange things. Acts like it might be dirty -how do I clean it?
jyvibar
  • 148 Answers
SOURCE: Logitech MX610 problem.
best thing to do is to replace your mouse
Posted on Mar 23, 2008
Templarius
  • 83 Answers
SOURCE: Left-click of optical mouse is sticking
Yes open the mouse and clean the left click that should help if not is time to buy new mouse
Posted on May 26, 2008
SOURCE: G7 Wireless Mouse keep double clicking
Same Problem, use canned air to clean it. bash the button a few times. seems to help for a while. Dont bash it to hard or you'll break it. love the mouse but this is a crappy issue within 3 months of use. in a clean environment.
Posted on Jun 19, 2008
antiochpc
  • 1314 Answers
SOURCE: Logitech Cordless Mouse clicks too fast!
Try going into control panel, mouse, and set a longer delay for the double click.
Thanks and please take a moment to rate as FixYa. Thank you.
Posted on Jul 23, 2008
SOURCE: mouse double clicks when i single click. sometimes doesn't click.
If this is the same problem that the Microsoft IntelliMouse Explorer 3.0 is susceptible to, it can be fixed! It is a hardware issue that is caused by corrosion on the metal contacts inside the buttons. The corrosion prevents electrical signals from passing between a copper plate and terminals above and below it. You can carefully scrape the contact points with a knife to expose the clean copper.
Follow these instructions at your own risk.
To get into the mouse, peel off the pads on the bottom and unscrew the screws, then carefully pry the shell apart. Do I need to say disconnect your mouse from your computer? Attached to the circuit board inside the mouse, you will see a couple of black boxes.
Look closely at one of the boxes and see that there is a cap with ears that clip onto the bottom half. Wedge a blade into one of the seams between the ears and the bottom half and it should pop up a little. The dull side of the blade should be touching the circuit board. Be careful to not bend the ear. Pop the other ear up and the top of the box should come away.
Study the internals of the black box. At rest, the copper plate is held in place by three contact points: at one end by a pivot point; in the middle by the end of a flex-spring; and at the other end by the upper terminal. When the mouse button is clicked, the copper plate is pressed at its center until the spring gives way and the plate pops down to the lower terminal. This is called a "mousedown" event. When it pops back up to the upper terminal, this is known as a "mouseup" event. In quick succession, mousedown + mouseup = click. If the plate or one of the terminals is corroded, the mouse can become confused, and single-clicks get registered as double-clicks.
Warning: the plate is tricky to put back in! To remove the plate, pivot it to one side, away from the terminals. Be careful to maintain control of the plate. It is tiny and springy, so it likes to fly away. Unless you have very small hands, you need to use tweezers to handle the plate.
Check the contact points on the top and bottom of the plate for corrosion. You can use isopropyl alcohol and a toothpick to rub the corrosion away. Be careful to not bend the plate. If the toothpick and alcohol are not enough to expose the copper, scratch gently and evenly with the tip of a knife blade.
Do the same with the upper and lower terminal.
Now is the time for the most frustrating part. Due to its tiny size and being spring-loaded, the plate can be extremely frustrating to reposition. In my experience, it seems that the easiest way to put the plate back in place the terminal end under the top terminal, then position the spring in the middle (there is groove where the spring is supposed to rest), then use tweezers to pull the opposite end against the force of the spring and seat that end in its groove. Meanwhile, I hold a finger against the top of the plate so it does not fly away if the tweezers slip.
When the plate is successfully positioned, press on the middle of the plate to make sure it clicks up and down the way it is supposed to. Clip the cap back on the black box. You may have to turn the mouse upside-down to do this so the white piece does not fall out. Screw the shell back together and stick the pads back on.
Now, if you didn't break anything, you just saved $30.
Posted on Jun 19, 2009
My logitech mouse started to behave as is I double click when i mean to single-click
http://forums.logitech.com/t5/Mice-Hardware/G7-Wireless-Left-click-inputs-a-double-click/m-p/265663
in short: take it apart, or return it
May 26, 2010 | Logitech 9311570403 Mouse
My logitech click plus mouse has a mind of its own. it seems to get stuck alot too.
May be its battery is weak just charge it or replace the battery and press the connect button.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | Logitech Cordless Click Plus Rechargeable...
Left click double-clicks. how can i get it to single-click?
Go to control panel, select Mouse, double click on that icon, choose from top Buttons, change the setting there or you can restore it to default.
Thanks for using fixya
Oct 14, 2009 | Logitech MX1000 Laser Cordless...
My Logitech wireless acts like I have double-clicked it when I have only single clicked it when playing sol. This only started a month ago; prior to that it worked perfectly. Do you have any ideas or do I...
First make sure your settings have not changed. Click on Start>Control Panel>Mouse and you will be in mouse properties. Check Buttons tab to make sure it is set with double-click speed as slow..
Please rate this solution
Jan 07, 2009 | Computers & Internet
Mouse inconsistent
Other than checking with the manufacturer for updated drivers or known issues - or attempting to roll-back the driver if a new one has been installed recently, I can't think of anything, seems to be a sticking button or otherwise faulty mouse.
Jan 05, 2009 | Computers & Internet
Left Mouse Down Doesn't Maintain Selection
Check the CCORNELL posting for the solution. Your mouse is double clicking when it should be only single clicking.
Dec 06, 2008 | Logitech Cordless Mouse
Mouse has lost its grip! (electrical grip, that is)
ok. i see your having great time using that mouse and you cared that device for several years. Try open your mouse and carefully remove these buttons of your mouse to clean those dirty stuff stacked on those linings( I believe that you haven't done this before, right?). I believe that this will need to clean a bit to give it back on track again.
Feb 23, 2008 | Logitech Cordless Mouse
Trouble single clicking
The screwholes are usually hidden underneith of labels, or underneith the little padded feet.
Jan 27, 2008 | Logitech MX 1000 Laser Cordless...
Logitech Cordless Mouse Logo
302 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
