Question about Rowenta Irons
Dropped my proffesional iron and it stopped working. I replaced the cord / circut part and still does not work. did i break something in the soleplate? fuse i cant find? thanks, Brad
  • 3 Answers
Chances ar you broke the resistance that is inside the iron
Posted on Mar 17, 2011
I have a B&D 2030 steam iron which I really like, but recently it isn't always turning on when plugged in. I think there may be a short in the cord somewhere, possibly the plug?? It seems to work...
Likely the wire inside the cord is broken from lots of use. You can usually tell where by turning the iron on while plugged in and bending the cord. You will hear a spark when you bend the spot with the break. It isn't very difficult to replace the cord with a new one.
May 31, 2011 | Black & Decker D2030 Iron
Iron heating sporadically and sensor lights working sporadically
It looks like the cord has a loose connection and will need to be replace.
Mar 29, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
I have a rowenta proffesional luxe iron but the cable keeps turning it off so when i move the cable it goes back on and when i am ironing it shuts off
you have a open circuit that occurs due to a wire loose at the plug end or a loose connection within the iron. a break in the cable will also display the systems you discribe. check for loose connections before you decide to replace the cable. by keeping the cable stationery when the iron is on at the plug end check wether it switches off when you move the cable near the plug end.if it switches off the loose wire is in the plug if it does not the try the moving the cable nearer the Iron end.
Apr 10, 2011 | Rowenta Professional Luxe DM880 Iron
I have two irons. one if them won't turn on anymore and i noticed the light kept fading out. the light on the other one flickers and it stops working halfway through straightening. any solutions?
Most likely it is the power cord. We have the same iron and the power cord has a break in it just as it comes out of the swivel. You can turn it on and hold the power cord tight up against the swivel and it should stay on. I was able to fix it by stripping the cord down to the wire soldering and adding shrink tubing to the connection. That lasted for about 1 year and it has done it again. I may have to replace it but not sure how to take it apart.
Sep 19, 2010 | Conair Infiniti Instant Heat Ceramic Hair...
I replaced the badly worn cord on a Phillips steam iron and everytime I switch it on it throws the circuit breaker. I am assured that the iron was working OK before I replaced the cord, but because it is a...
There is a break in the insulation somewhere and tge wires are getting crossed or the active wire insulation is broken and it is shorting to the eaarth ground.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jan 23, 2010 | Micro Pro 7599 Iron
Oreck Cordless Speed Iron
Try an Oreck store or customer service.
If not I would suggest Ebay or something of the sort that would have odd and end parts
Sep 06, 2009 | Oreck Cordless Speed JP8100CA Iron
T-fal ultra glide easy cord iron stopped working while ironing
heatman101
Jun 03, 2009 | Tefal UltraGlide 1569 Iron
Turns on, flashes yellow but never heats up
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jan 12, 2009 | Rowenta Effective DX1900 Iron with Auto...
Iron not staying on
Jun 27, 2008 | Rowenta Professional DE880 Iron
Shark iron
I bought this Shark iron last July and I even saved the receipt!!But I threw the box away. The water is leaking out of the bottom. I bought the expensive Rowenta before that, and that one leaked all over my ironing. And I cleaned these irons faithfully every month. I need a toll free number for Shark
Nov 13, 2007 | Euro-Pro Shark GI490 Iron
Irons Logo
55 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
