Question about HP Officejet J5780 All-In-One InkJet Printer
Close door print error - HP Officejet J5780 All-In-One InkJet Printer
    Master:
  • 325 Answers
If all the doors are firmly closed then you have a sensor error.
Posted on Mar 17, 2011
Open Door Error Sony Up DM150 Printer
The door closes onto a micro switch. I suspect there will be your fault.
Mar 01, 2017 | Office Equipment & Supplies
10.1002 supply error
This error indicate the affected cartridge...
10.1002 = Magenta e-label is missing..
you need to reinstall the printer..
Are you sure that the print cartridges are genuine!!
->Open the front access door completely.
->Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
->Grasp the center of one of the print cartridges, and then pull it straight up to remove it.
->Hold the print cartridge so that the imaging drum faces the bottom of the print cartridge drawer, and then insert the print cartridge into the correct slot.
->When you are sure that you have genuine print cartridges installed, close the print cartridge drawer completely.
->Close the front access door completely.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 26, 2012 | Office Equipment & Supplies
Hp cp2025 error reads "front door open" when front door is closed
pront door liver switch open not work it ,or it displace.you should check it or service need
Sep 12, 2012 | HP Laserjet Cp2025n Printer
Problem : 10.92.00 cartridges not engaged. The front door do not close probably I removed all cartridges the front door closed and the printers worked. Reinstalling the cartridges failed with same error...
10.92.00 The Black print cartridge are not engaged correctly.
? Open and then close the front door.
? If the message persists, make sure all the print cartridges are seated correctly.
? Clean the contacts on the memorycontroller PCA.
? Make sure that connectors J302, J303, J304, and J305 on the memorycontroller PCA are seated correctly. Also make sure that connector J1020 on the DC controller is seated correctly.
? Replace the memory-controller PCA if it is damaged.
? Check the gears on the print-cartridge drive motors. Replace defective motors.
? Replace the DC controller.
Aug 10, 2011 | HP LaserJet 3600n Printer
What does error code 3501 and 3502 mean on advent AWP10 printer
Printer error code "3501" occurs right before a print job. A flashing screen will tell you that the printer cannot print due to error code "3501". These error codes are generally experienced when you use diagnostic sheet to print and change the ink over them. This error code could also indicate that buffer length of a print was not valid.
Jan 08, 2011 | Office Equipment & Supplies
Close print cartridge access door. It is closed
try to use a pin to click on the switch for the door and see it may be not working
Nov 08, 2009 | HP OfficeJet J4580 All-In-One Laser...
My esp5 all in one printer says there is an error a paper jam but there isnt one please help
1. Take out both the ink cartridges, wait for 5 seconds.
2. Take out the printhead, and close the printer access door
3. Take out the power cable without turning OFF the printer, and wait for 30 seconds.
4. Now connect the printer with the power cable, and turn ON the printer.
5. If the printer is giving an error” printhead missing”, now put the printhead back.
6. Closing of the printer access door brings up error message “missing cartridge.”
7. Insert both the ink cartridges into the printhead.
8. Close the printer access door, and wait until printer gets ready for printing.
9. Give a print command after loading paper in the upper tray.
Best of Luck
Saj
Oct 27, 2009 | Kodak ESP 5 Printer
52 saccaner error
52 Scanner Error Perform the following to troubleshoot a 52 scanner error:
  1. Verify that the toner door is completely closed. If the door is not closed, the printer will not allow the laser shutter to operate and will present the error “52 Scanner Error” or “Door open or no print cartridge”.
  2. Verify that the black connecting link to the toner door hinge is properly attached. If the latch is not properly attached (Figure 1), snap the hinge in place, close the toner door, and power-cycle the unit. Figure 5: Black toner door latch c00162195.jpg
  3. Verify that the inner toner door is properly positioned. Snap the door back into place at the two inner door-locking mechanisms (Figure 2). Figure 6: Inner door locking mechanisms c00162197.jpg
  4. Verify that the door hinge and upper ring are not broken. If either are broken, the unit will need to be returned to HP or a local service provider for service using the applicable warranty, support pack, or contract option. Figure 7: Door hinge and upper ring c00162200.jpg
May 28, 2009 | HP LaserJet 3055 All-In-One Printer
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
HP Officejet J5780 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
